which driver are used with meoboot?
ihavu
Hello !
I have a question to the funtion of meoboot:
I use VTI with BH in flash.
If I only use VTI in flash my DVB-T stick doesn´t work.
with BH in flash the Stick works.
and with meoboot the stick is also running with VTI.
So it seems VTI is using the usb-drivers of BH in meoboot image.
Is this true and if so are all drivers of the image in flash are used from image in meoboot?
Thanks for answering
bogdanm
Moderator
Yes you have right this is suprice to all who used DVB-T sticks.
I think first made in image 1.7.x
