why Black Hole Not Fix WirelessLanSetup bug (Cannot generate Passphrase) .
I hope fix this problem in next update .
Which type of wireless security isn't working?why Black Hole Not Fix WirelessLanSetup bug (Cannot generate Passphrase) .
Should you have problems inputting the preshared key or password, have you tried to connect a USB keyboard (only needed during the wireless setup)?
commited in the next 2.1.4
you test this method !!Try using a USB keyboard.
Otherwise remove those characters from the preshared key used by your wireless router (at least until the bug fix).
you can testI hope and waiting that Shiro :\
you can test
unzip file
upload in /usr/lib/enigma2/python/Plugins/SystemPlugins/WirelessLanSetup
restart enigma2
Let me know if it works
