fabrizio432
Just one thing, do you edit this script via windows or linux ? There can be problem with EOL.
Since I use kubuntu, I wrote the script with kate.
Here is the file:
root@vusolo2:~# sh /home/komodo/test.sh
interface wlan0 does not exist!
ssh 192.168.2.201 -l root
root@192.168.2.201's password:
root@vusolo2:~# ifconfig
eth0 Link encap:Ethernet HWaddr 00:1D:EC:04:8F:FF
inet6 addr: fe80::21d:ecff:fe04:8fff/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:2322 errors:0 dropped:146 overruns:0 frame:0
TX packets:2187 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:182927 (178.6 KiB) TX bytes:296865 (289.9 KiB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:79 errors:0 dropped:0 overruns:0 frame:0
TX packets:79 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:7192 (7.0 KiB) TX bytes:7192 (7.0 KiB)
mybridge Link encap:Ethernet HWaddr 00:1D:EC:04:8F:FF
inet addr:192.168.2.201 Bcast:192.168.2.255 Mask:255.255.255.0
RX packets:73 errors:0 dropped:0 overruns:0 frame:0
TX packets:65 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:8304 (8.1 KiB) TX bytes:9450 (9.2 KiB)
root@vusolo2:/home/komodo# cat test.sh
#!/bin/bash
brctl addbr mybridge
brctl addif mybridge eth0
brctl addif mybridge wlan0
ifconfig eth0 0.0.0.0
ifconfig wlan0 0.0.0.0
ifconfig mybridge 192.168.2.201 netmask 255.255.255.0 up
dos2unix bridge.sh
sh bridge.sh && ifconfig > /home/root/ifconfig.out
brctl show >> /home/root/ifconfig.out
sh bridge.sh && sh testscript.sh
I said that it can be EOL issue![]()
This is ifconfig.out:And what's actual status ?
After you run this script then you can't acces box via 192.168.1.99 ?
Try this
Code:sh bridge.sh && ifconfig > /home/root/ifconfig.out
and then restart the box and check the ifconfig.out file if there is all ok, or if there is some missing setting.
eth0 Link encap:Ethernet HWaddr 00:1D:EC:01:86:EB
inet6 addr: fe80::21d:ecff:fe01:86eb/64 Scope:Link
UP BROADCAST RUNNING PROMISC MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:38 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:5992 (5.8 KiB)
Interrupt:16
RX packets:942 errors:0 dropped:0 overruns:0 frame:0
TX packets:942 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:60366 (58.9 KiB) TX bytes:60366 (58.9 KiB)
mybridge Link encap:Ethernet HWaddr 00:1D:EC:01:86:EB
inet addr:192.168.1.99 Bcast:192.168.1.255 Mask:255.255.255.0
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:2 errors:0 dropped:0 overruns:0 frame:0
TX packets:4 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:76 (76.0 B) TX bytes:731 (731.0 B)
wlan0 Link encap:Ethernet HWaddr 98:FC:11:CC:6B:03
inet6 addr: fe80::9afc:11ff:fecc:6b03/64 Scope:Link
RX packets:0 errors:0 dropped:78 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:1862093 (1.7 MiB) TX bytes:46542 (45.4 KiB)
Or maybe better, you should make some script testscript.sh whith this
Code:ifconfig > /home/root/ifconfig.out brctl show >> /home/root/ifconfig.out
and run
Code:sh bridge.sh && sh testscript.sh
to see if address and bridge is set up.
TX packets:32 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:5087 (4.9 KiB)
Interrupt:16
RX packets:692 errors:0 dropped:0 overruns:0 frame:0
TX packets:692 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:46044 (44.9 KiB) TX bytes:46044 (44.9 KiB)
RX packets:1 errors:0 dropped:0 overruns:0 frame:0
TX packets:2 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:36 (36.0 B) TX bytes:144 (144.0 B)
RX packets:0 errors:0 dropped:50 overruns:0 frame:0
RX bytes:1076668 (1.0 MiB) TX bytes:37117 (36.2 KiB)
bridge name bridge id STP enabled interfaces
mybridge 8000.001dec0186eb no eth0
wlan0
I connect via wifi. My ip is 192.168.1.54This looks ok, but how brctl show looks like after change ?
And you are connecting via wlan or via wired connection ?
What's your IP address ?
And what do you mean with Ican't connect ? That your connection is closed after this script, or you can't connect from new console ?
And via wired network ? Are you able to connect ?
Maybe you shoul try to enable STP.
Try add at the end of the sript this
brctl stp mybridge on
If no, i will really borrow some wifi. I'm courious why is not workingbecause we are using bridges everyday at work witthout problems.
TX packets:33 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:5149 (5.0 KiB)
Interrupt:16
RX packets:1559 errors:0 dropped:0 overruns:0 frame:0
TX packets:1559 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:94442 (92.2 KiB) TX bytes:94442 (92.2 KiB)
TX packets:3 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:36 (36.0 B) TX bytes:222 (222.0 B)
RX packets:0 errors:0 dropped:165 overruns:0 frame:0
RX bytes:3846973 (3.6 MiB) TX bytes:55554 (54.2 KiB)
mybridge 8000.001dec0186eb yes eth0
wlan0
#!/bin/bash
ifconfig eth0 promisc up
ifconfig wlan0 promisc up
ifconfig mybridge 192.168.1.99 netmask 255.255.255.0 up
echo ""
exit 0
Is it possible setting vuplus to bridge wlan between lan, so the wireless network is on the same as lan network?
At the moment I can enable only one network at a time:
+Explain better, what you want to do. Maybe Wireless Acces Point to make Vu+ to act like WLAN acces point to your LAN ADSL Modem?
No, it will not work. Vu+ is running Linux based enigma2. And not Linux distribution for PC. It can act as an Acces Point, but in your case the acces point is your modem. You should make WLAN-LAN bridge on your PC or change your LAN router to WLAN-LAN.+
This is my goal:
