XBMC and Strereoscopic player for sat channel viewing
NickZ
There is a remarkable thing called Tuner Server (double press blue button in BH 2.03). When enabled it creates folder tuner on HDD with m3u files corresponding to the bouquets. The files are named according to the channel names. Copy the folder to a USB flash. Now you can use the flash for viewing channels on your PC, Mac or other devices. For example, install XBMC for windows , add the m3u to media sources and enjoy the bouquets in XBMC. If you have Nvidia stereoscopic glasses, transmitter and a suitable 120 Hz display, you can watch Sky 3D or similar 3D channels. In this case you should install Stereoscopic Player , then use the URL containing in m3u file and from Stereoscopic Player menu Open URL .
