hi i have tried deleting the xbmc folder and reinstalling but its just the same ,the problem about xfinity i cant open xbmc to remove it, i even borrowed a second vu+solo2 and deleted my files and transfered the files from the second one back
i have tried differant images and have found one on a back up image that works xbmc, but when i reinstall a new image again it wount boot up
i have a copy af myxbmc crash log if this is any help
thanks rhond49
############## XBMC CRASH LOG ###############
################ SYSTEM INFO ################
Date: Thu Jan 1 01:12:59 CET 1970
XBMC Options:
Arch: mips
Kernel: Linux 3.13.5 #1 SMP Tue Oct 20 18:36:40 KST 2015
Release: lsb_release not available
############## END SYSTEM INFO ##############
############### STACK TRACE #################
gdb not installed, can't get stack trace.
############# END STACK TRACE ###############
################# LOG FILE ##################
01:12:57 T:1974710272 NOTICE: special://profile/ is mapped to: special://masterprofile/
01:12:57 T:1974710272 NOTICE: -----------------------------------------------------------------------
01:12:57 T:1974710272 NOTICE: Starting XBMC (13.2 Git:20150206-ed2750e). Platform: MIPS Linux 32-bit
01:12:57 T:1974710272 NOTICE: Using Debug XBMC x32 build, compiled Oct 20 2015 by GCC 4.6.4 for MIPS Linux 32-bit 3.13.0
01:12:57 T:1974710272 WARNING: Unable to determine Linux distribution
01:12:57 T:1974710272 NOTICE: Running on Linux 32-bit (Unknown, 3.13.5 mips)
01:12:57 T:1974710272 NOTICE: Host CPU: BCM7346B2 STB platform, 2 cores available
01:12:57 T:1974710272 NOTICE: special://xbmc/ is mapped to: /usr/share/xbmc
01:12:57 T:1974710272 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/xbmc
01:12:57 T:1974710272 NOTICE: special://masterprofile/ is mapped to: /media/hdd/.xbmc/userdata
01:12:57 T:1974710272 NOTICE: special://home/ is mapped to: /media/hdd/.xbmc
01:12:57 T:1974710272 NOTICE: special://temp/ is mapped to: /media/hdd/.xbmc/temp
01:12:57 T:1974710272 NOTICE: The executable running is: /usr/lib/xbmc/xbmc.bin
01:12:57 T:1974710272 NOTICE: Local hostname: vusolo2
01:12:57 T:1974710272 NOTICE: Log File is located: /media/hdd/.xbmc/temp/xbmc.log
01:12:57 T:1974710272 WARNING: Unicode properties are not enabled in PCRE lib, support for national symbols may be limited!
01:12:57 T:1974710272 NOTICE: Consider installing PCRE lib version 8.10 or later with enabled Unicode properties and UTF-8 support. Your PCRE lib version: 8.21 2011-12-12
01:12:57 T:1974710272 DEBUG: ConsoleKit.Manager: org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.ConsoleKit was not provided by any .service files
01:12:57 T:1974710272 DEBUG: UPower: org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files
01:12:57 T:1974710272 DEBUG: DeviceKit.Power: org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.DeviceKit.Disks was not provided by any .service files
01:12:57 T:1974710272 NOTICE: load settings...
01:12:57 T:1974710272 DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/settings.xml
01:12:57 T:1974710272 DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/linux.xml
01:12:57 T:1974710272 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
01:12:57 T:1974710272 NOTICE: Loaded settings file from special://profile/advancedsettings.xml
01:12:57 T:1974710272 NOTICE: Contents of special://profile/advancedsettings.xml are...
<!-- zerocache -->
<advancedsettings>
<network>
<cachemembuffersize>0</cachemembuffersize>
<curlclienttimeout>45</curlclienttimeout>
</network>
<gui>
<algorithmdirtyregions>3</algorithmdirtyregions>
<nofliptimeout>0</nofliptimeout>
</gui>
<videoscanner>
<ignoreerrors>true</ignoreerrors>
</videoscanner>
</advancedsettings>
01:12:57 T:1974710272 NOTICE: Default DVD Player: dvdplayer
01:12:57 T:1974710272 NOTICE: Default Video Player: dvdplayer
01:12:57 T:1974710272 NOTICE: Default Audio Player: paplayer
01:12:57 T:1974710272 NOTICE: Disabled debug logging due to GUI setting. Level 0.
01:12:57 T:1974710272 NOTICE: Log level changed to 0
01:12:57 T:1974710272 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
01:12:57 T:1974710272 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
01:12:57 T:1974710272 DEBUG: CPlayerCoreConfig::<ctor>: created player DVDPlayer for core 1
01:12:57 T:1974710272 DEBUG: CPlayerCoreConfig::<ctor>: created player oldmplayercore for core 1
01:12:57 T:1974710272 DEBUG: CPlayerCoreConfig::<ctor>: created player PAPlayer for core 3
01:12:57 T:1974710272 DEBUG: CPlayerCoreConfig::<ctor>: created player E2Player for core 4
01:12:57 T:1974710272 DEBUG: CPlayerSelectionRule::Initialize: creating rule: system rules
01:12:57 T:1974710272 DEBUG: CPlayerSelectionRule::Initialize: creating rule: rtv
01:12:57 T:1974710272 DEBUG: CPlayerSelectionRule::Initialize: creating rule: hdhomerun/myth/mms/udp
01:12:57 T:1974710272 DEBUG: CPlayerSelectionRule::Initialize: creating rule: lastfm/shout
01:12:57 T:1974710272 DEBUG: CPlayerSelectionRule::Initialize: creating rule: rtmp
01:12:57 T:1974710272 DEBUG: CPlayerSelectionRule::Initialize: creating rule: rtsp
01:12:57 T:1974710272 DEBUG: CPlayerSelectionRule::Initialize: creating rule: streams
01:12:57 T:1974710272 DEBUG: CPlayerSelectionRule::Initialize: creating rule: aacp/sdp
01:12:57 T:1974710272 DEBUG: CPlayerSelectionRule::Initialize: creating rule: mp2
01:12:57 T:1974710272 DEBUG: CPlayerSelectionRule::Initialize: creating rule: dvd
01:12:57 T:1974710272 DEBUG: CPlayerSelectionRule::Initialize: creating rule: dvdimage
01:12:57 T:1974710272 DEBUG: CPlayerSelectionRule::Initialize: creating rule: sdp/asf
01:12:57 T:1974710272 DEBUG: CPlayerSelectionRule::Initialize: creating rule: nsv
01:12:57 T:1974710272 DEBUG: CPlayerSelectionRule::Initialize: creating rule: radio
01:12:57 T:1974710272 DEBUG: CPlayerSelectionRule::Initialize: creating rule: dgb
01:12:57 T:1974710272 NOTICE: Loaded playercorefactory configuration
01:12:57 T:1974710272 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
01:12:57 T:1974710272 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
00:12:57 T:1974710272 INFO: creating subdirectories
00:12:57 T:1974710272 INFO: userdata folder: special://masterprofile/
00:12:57 T:1974710272 INFO: recording folder:
00:12:57 T:1974710272 INFO: screenshots folder:
00:12:57 T:1974710272 INFO: load language info file: special://xbmc/language/English/langinfo.xml
00:12:57 T:1974710272 DEBUG: trying to set locale to en_US.UTF-8
00:12:57 T:1974710272 INFO: global locale set to C
00:12:57 T:1974710272 INFO: load English language file, from path: special://xbmc/language/
00:12:57 T:1974710272 DEBUG: POParser: loaded 3162 strings from file /usr/share/xbmc/language/English/strings.po
00:12:57 T:1974710272 NOTICE: Running database version Addons16
00:12:57 T:1974710272 DEBUG: SECTION:LoadDLL(special://xbmcbin/system/libcpluff-mips.so)
00:12:57 T:1974710272 DEBUG: Loading: /usr/lib/xbmc/system/libcpluff-mips.so
00:12:57 T:1974710272 INFO: ADDON: cpluff: 'XML parsing error in /media/hdd/.xbmc/addons/plugin.video.aaastream/addon.xml, line 21, column 3 (unclosed token).'
00:12:57 T:1974710272 INFO: ADDON: cpluff: 'Plug-in descriptor in /media/hdd/.xbmc/addons/plugin.video.aaastream is invalid.'
00:12:57 T:1974710272 INFO: ADDON: cpluff: 'XML parsing error in /media/hdd/.xbmc/addons/plugin.program.xbmchub.notifications/addon.xml, line 16, column 3 (mismatched tag).'
00:12:57 T:1974710272 INFO: ADDON: cpluff: 'Plug-in descriptor in /media/hdd/.xbmc/addons/plugin.program.xbmchub.notifications is invalid.'
00:12:58 T:1974710272 INFO: ADDON: cpluff: 'Could not read plug-in directory /usr/lib/xbmc/addons: No such file or directory'
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.tknorris.beta
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.thongld
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository superrepo.kodi.helix.video
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repo.hybrid
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.HalowTV
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.queeup
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.googlecode.bogs-xbmc-addons
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.ptom
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.Rodrigo
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.divingmule.addons
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.aresproject
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.NJMSoccer
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.team.expat
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.lunatixz
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.aj-addons
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.googlecode.krysty-xbmc
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.MisterX
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository superrepo.kodi.helix.all
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository superrepo.kodi.helix.downloads
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.Vinnydude
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.BlazeRepo
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repo.natko1412
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.OperationRobocop
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.featherence
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.cocawe
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.googlecode.apple-tv2-xbmc
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.schismtv.addonsdev
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.smoothstreams
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.anonymous.adults
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.addonscriptorde-beta
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.zeus
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.TheYidXXX
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.pcd
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.kodipopcorntime
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.CanadaOnDemand
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository net.rieter.xot.repository
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.Kinkin
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.xbmchub
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.VinManJSV
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.icanuck
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.bunkford
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.kodiunderground
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.thehighway
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.mdrepo
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.tva.common
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.xbmc.org
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.MaxMustermann.xbmc
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.rayw1986
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.googlecode.sparetime
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository superrepo.kodi.isengard.video
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.The_Silencer
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.xbmcplus.xbmc-plugins
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.pulsar
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.nitrocsia
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.SportsMania
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.leopold
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.Mr-Smiths-Repo
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.istream
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.superrepo.org.helix.all
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.dk-xbmc-repaddon
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository superrepo.kodi.jarvis.external.repositories
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository xbmc.repo.tecboxtvguide
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.xxxadultxbmc
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.japanese
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.xunitytalk
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.bromix
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.popey
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.surmac
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository superrepo.kodi.helix.live-tv
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.googlecode.xbmc-catchuptv-au
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.bbtsip.tv
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.dss
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.eleazar
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.superrepo.org.gotham.others.adult
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.mx
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.husham.com
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.mash2k3
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.github.anilkuj-xbmc-addons
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.rawmaintenance
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.smokdpi
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.FTV-Guide-Repo
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.tvcatchup.addons
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.spoyser
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository superrepo.kodi.helix.movies
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.arabic.xbmc-addons
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository superrepo.kodi.helix.tv-shows
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.boogie
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository superrepo.kodi.isengard.external.repositories
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository Tugafree.repositorio
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository superrepo.kodi.helix.external.repositories
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository superrepo.kodi.helix.repositories
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.o9r1sh
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.k3oni.xbmc
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository superrepo.kodi.jarvis.all
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.dudehere.plugins
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.p2p-streams.xbmc
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.totalinstaller
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.googlecode.anarchintosh-projects
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.angelscry.xbmc-plugins
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository superrepo.kodi.isengard.programs
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.shani
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.podgod
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.xbmcadult
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.tknorris.release
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository xbmc.repo.leopold
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.RenegadesTV
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.googlecode.achilles-projects
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.eldorado
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.unofficial.addon.pro
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.entertainmentrepo
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.huball
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.pulsarunofficial
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.dextertv
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.byalongshot
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository xbmc.repo.elmerohueso
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.d0f21
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.crzen
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.bstrdsmkr
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository superrepo.kodi.jarvis.movies
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.bluecop.xbmc-plugins
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.xbmc-israel
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.lambda
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository superrepo.kodi.helix.podcasts
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.legends
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.pipcan
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.metalkettle
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.ddurdle
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.entertainmentrepobackup
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.Halowrepo
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.xbmc.tvm
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.jas0npc
00:12:58 T:1974710272 NOTICE: ADDONS: Using repository repository.SportsDevil
00:12:58 T:1974710272 DEBUG: LoadMappings - loaded node "Motorola Nyxboard Hybrid"
00:12:58 T:1974710272 DEBUG: LoadMappings - loaded node "CEC Adapter"
00:12:58 T:1974710272 DEBUG: LoadMappings - loaded node "Pulse-Eight CEC Adapter"
00:12:58 T:1974710272 DEBUG: LoadMappings - loaded node "iMON HID device"
00:12:58 T:1974710272 DEBUG: CPeripheralBusUSB - using libusb peripheral scanning
00:12:58 T:1974297760 NOTICE: Thread PeripBusUSB start, auto delete: false
00:12:58 T:1974710272 DEBUG: UDisks: org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UDisks was not provided by any .service files
00:12:58 T:1974710272 DEBUG: DeviceKit.Disks: org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.DeviceKit.Disks was not provided by any .service files
00:12:58 T:1974710272 DEBUG: Selected Posix mount as storage provider
00:12:58 T:1974710272 NOTICE: InitWindowSystem: Using EGL Implementation: dvbbox
00:12:58 T:1974710272 DEBUG: EGL initial desktop resolution @ 50.00 - Full Screen
00:12:58 T:1974710272 DEBUG: EGL initial desktop resolution 1280x720 @ 50.00 - Full Screen 3DSBS
00:12:58 T:1974710272 DEBUG: EGL initial desktop resolution 1280x720 @ 50.00 - Full Screen 3DTB
00:12:58 T:1974710272 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 50.000000 Hz
00:12:58 T:1974710272 NOTICE: Previous line repeats 2 times.
00:12:58 T:1974710272 NOTICE: Found (
1280x720@50.000000) at 16, setting to RES_DESKTOP at 16
00:12:58 T:1974710272 NOTICE: Checking resolution 16
00:12:58 T:1974710272 DEBUG: CreateWindow: Created surface of size 1280x720
00:12:58 T:1974710272 NOTICE: GL_VENDOR = Broadcom
00:12:58 T:1974710272 NOTICE: GL_RENDERER = VideoCore IV HW (V3D-410)
00:12:58 T:1974710272 NOTICE: GL_VERSION = OpenGL ES 2.0
00:12:58 T:1974710272 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
00:12:58 T:1974710272 DEBUG: GLES: Extension Support Test - GL_NVX_gpu_memory_info NO
00:12:58 T:1974710272 NOTICE: GL_EXTENSIONS = GL_OES_compressed_ETC1_RGB8_texture GL_OES_compressed_paletted_texture GL_OES_texture_npot GL_OES_depth24 GL_OES_vertex_half_float GL_OES_EGL_image GL_EXT_discard_framebuffer GL_OES_rgb8_rgba8 GL_OES_depth32 GL_APPLE_rgb_422 GL_OES_packed_depth_stencil GL_EXT_debug_marker GL_EXT_multisampled_render_to_texture GL_EXT_texture_format_BGRA8888
00:12:58 T:1974710272 DEBUG: GLES: Extension Support Test - GL_EXT_texture_format_BGRA8888 YES
00:12:58 T:1974710272 DEBUG: GLES: Extension Support Test - GL_IMG_texture_format_BGRA8888 NO
00:12:58 T:1974710272 DEBUG: GLES: Extension Support Test - GL_APPLE_texture_format_BGRA8888 NO
00:12:58 T:1974710272 DEBUG: GL: Vertex Shader compilation log:
00:12:58 T:1974710272 DEBUG: GL: Vertex Shader compiled successfully
00:12:58 T:1974710272 DEBUG: GL: Pixel Shader compilation log:
00:12:58 T:1974710272 DEBUG: GL: Fragment Shader compiled successfully
00:12:58 T:1974710272 DEBUG: GUI Shader [guishader_frag_default.glsl]- Initialise successful : 0x14e0e48
00:12:58 T:1974710272 DEBUG: GUI Shader [guishader_frag_texture.glsl]- Initialise successful : 0x14c5c18
00:12:58 T:1974710272 DEBUG: GUI Shader [guishader_frag_multi.glsl]- Initialise successful : 0x14be240
00:12:58 T:1974710272 DEBUG: GUI Shader [guishader_frag_fonts.glsl]- Initialise successful : 0x14d7a30
00:12:58 T:1974710272 DEBUG: GUI Shader [guishader_frag_texture_noblend.glsl]- Initialise successful : 0x14cfb98
00:12:58 T:1974710272 DEBUG: GUI Shader [guishader_frag_multi_blendcolor.glsl]- Initialise successful : 0x14c7730
00:12:58 T:1974710272 DEBUG: GUI Shader [guishader_frag_rgba.glsl]- Initialise successful : 0x14f8210
00:12:58 T:1974710272 DEBUG: GLES: Extension Support Test - GL_OES_EGL_image_external NO
00:12:58 T:1974710272 DEBUG: GUI Shader [guishader_frag_rgba_blendcolor.glsl]- Initialise successful : 0x14f1120
00:12:58 T:1974710272 DEBUG: CWinSystemEGL::CreateNewWindow: No need to create a new window
00:12:58 T:1974710272 INFO: GLES: Maximum texture width: 2048
00:12:58 T:1974710272 DEBUG: CRenderManager::UpdateDisplayLatency - Latency set to 0 msec
00:12:58 T:1974710272 INFO: load user splash image: /media/hdd/.xbmc/media/Splash.png
00:12:58 T:1974710272 DEBUG: SECTION:LoadDLL(special://xbmcbin/system/ImageLib-mips.so)
00:12:58 T:1974710272 DEBUG: Loading: /usr/lib/xbmc/system/ImageLib-mips.so
00:12:58 T:1974710272 INFO: load keymapping
00:12:58 T:1974710272 INFO: Loading special://xbmc/system/keymaps/appcommand.xml
00:12:58 T:1974710272 INFO: Loading special://xbmc/system/keymaps/gamepad.xml
00:12:58 T:1974710272 INFO: Loading special://xbmc/system/keymaps/joystick.Alienware.Dual.Compatible.Controller.xml
00:12:58 T:1974710272 INFO: Loading special://xbmc/system/keymaps/joystick.AppleRemote.xml
00:12:58 T:1974710272 INFO: Loading special://xbmc/system/keymaps/joystick.Harmony.xml
00:12:58 T:1974710272 INFO: Loading special://xbmc/system/keymaps/joystick.Interact.AxisPad.xml
00:12:58 T:1974710272 INFO: Loading special://xbmc/system/keymaps/joystick.Logitech.RumblePad.2.xml
00:12:58 T:1974710272 INFO: Loading special://xbmc/system/keymaps/joystick.Microsoft.Xbox.360.Controller.xml
00:12:58 T:1974710272 INFO: Loading special://xbmc/system/keymaps/joystick.Microsoft.Xbox.Controller.S.xml
00:12:58 T:1974710272 INFO: Loading special://xbmc/system/keymaps/joystick.Nintendo.Wii.U.Pro.Controller.xml
00:12:58 T:1974710272 INFO: Loading special://xbmc/system/keymaps/joystick.PS3.Remote.Keyboard.xml
00:12:58 T:1974710272 INFO: Loading special://xbmc/system/keymaps/joystick.Sony.PLAYSTATION(R)3.Controller.xml
00:12:58 T:1974710272 INFO: Loading special://xbmc/system/keymaps/joystick.WiiRemote.xml
00:12:58 T:1974710272 INFO: Loading special://xbmc/system/keymaps/joystick.xml
00:12:58 T:1974710272 NOTICE: No Joystick name specified, loading default map
00:12:58 T:1974710272 NOTICE: Previous line repeats 35 times.
00:12:58 T:1974710272 INFO: Loading special://xbmc/system/keymaps/keyboard.xml
00:12:58 T:1974710272 INFO: Loading special://xbmc/system/keymaps/mouse.xml
00:12:59 T:1974710272 INFO: Loading special://xbmc/system/keymaps/remote.xml
00:12:59 T:1974710272 INFO: Loading special://xbmc/system/keymaps/touchscreen.xml
00:12:59 T:1974710272 INFO: GUI format 1280x720, Display @ 50.00 - Full Screen
00:12:59 T:1974710272 DEBUG: guilib: Fill viewport on change for solving rendering passes
00:12:59 T:1974710272 DEBUG: SECTION:LoadDLL(libcurl.so.4)
00:12:59 T:1974710272 DEBUG: Loading: libcurl.so.4
00:12:59 T:1974710272 NOTICE: Running database version Addons16
00:12:59 T:1974710272 DEBUG: Initialize, updating databases...
00:12:59 T:1974710272 NOTICE: Running database version ViewModes6
00:12:59 T:1974710272 NOTICE: Running database version Textures13
00:12:59 T:1974710272 NOTICE: Running database version MyMusic46
00:12:59 T:1974710272 NOTICE: Running database version MyVideos78
00:12:59 T:1974710272 NOTICE: Running database version TV22
00:12:59 T:1974710272 NOTICE: Running database version Epg7
00:12:59 T:1974710272 DEBUG: Initialize, updating databases... DONE
00:12:59 T:1974710272 INFO: DPMS: not supported on this platform
00:12:59 T:1974710272 DEBUG: CAnnouncementManager - Announcement: OnClear from xbmc
00:12:59 T:1974710272 DEBUG: GOT ANNOUNCEMENT, type: 2, from xbmc, message OnClear
00:12:59 T:1974710272 ERROR: Default skin 'skin.confluence' not found! Terminating..
00:12:59 T:1974710272 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0x144a500 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
00:12:59 T:1974710272 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0x13b0f88 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
00:12:59 T:1974710272 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0x1475398 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
00:12:59 T:1974710272 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0x145fb98 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
00:12:59 T:1974710272 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0x14a3328 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
00:12:59 T:1974710272 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0x147c328 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
00:12:59 T:1974710272 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0x144a4a8 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
00:12:59 T:1974710272 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0x1485730 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
00:12:59 T:1974710272 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0x14a3238 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
00:12:59 T:1974710272 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0x13227b8 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
00:12:59 T:1974710272 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0x13ee240 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
00:12:59 T:1974710272 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0x1386b40 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
00:12:59 T:1974710272 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0x1410540 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
00:12:59 T:1974710272 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0x1485548 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
00:12:59 T:1974710272 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0x149f250 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
00:12:59 T:1974710272 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0x1449658 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
00:12:59 T:1974710272 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0x145fad8 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
00:12:59 T:1974710272 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0x144ca60 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
00:12:59 T:1974710272 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0x14712e0 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
00:12:59 T:1974710272 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0x144a568 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
00:12:59 T:1974710272 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0x13b6870 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
00:12:59 T:1974710272 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0x14802f0 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
00:12:59 T:1974710272 DEBUG: PVRManager - destroyed
00:12:59 T:1974710272 NOTICE: special://profile/ is mapped to: special://masterprofile/
00:12:59 T:1974710272 DEBUG: SECTION:UnloadAll(DLL: special://xbmcbin/system/libcpluff-mips.so)
00:12:59 T:1974710272 DEBUG: Unloading: libcpluff-mips.so
00:12:59 T:1974710272 DEBUG: SECTION:UnloadAll(DLL: special://xbmcbin/system/ImageLib-mips.so)
00:12:59 T:1974710272 DEBUG: Unloading: ImageLib-mips.so
00:12:59 T:1974710272 DEBUG: SECTION:UnloadAll(DLL: libcurl.so.4)
00:12:59 T:1974710272 DEBUG: Unloading: libcurl.so.4
############### END LOG FILE ################
############ END XBMC CRASH LOG #############
