Matrix10 Administrator Jan 21, 2016 #21 oldgraf said: I tested to with Solo2 and is OK Any chance for cooperation with @marko861 and set 15.2 in OBH ? Click to expand... I can not answer this but I think it would be good that 15.2 is in all images.
H Harley Vu+ Newbie Feb 1, 2016 #22 Why even work on a Kodi 15.x port when Kodi 16.0 (Jarvis) will be released any day now? http://kodi.tv/kodi-16-0-jarvis-release-candidate-2/ http://kodi.wiki/view/Kodi_v16_(Jarvis)_changelog https://github.com/xbmc/xbmc/tree/Jarvis Kodi 16 has more portable code / less dependencies and is better optimized for ARM. This new release also has a updated PVR client addon for VuPlus, see: https://github.com/kodi-pvr/pvr.vuplus It would be best to spend time porting the v16 Jarvis branch instead of the older version. Last edited: Feb 1, 2016
H Harley Vu+ Newbie Feb 1, 2016 #23 Even better for Vu+ will be the upcomming v17 (Krypton) which will have a new VideoPlayer core: http://forum.kodi.tv/showthread.php?tid=237686 Kodi 17.0 new internal video player (called "VideoPlayer") should be easier to port to Vu+ https://github.com/FernetMenta/xbmc/commits/vplayer Porting and using Kodi's new internal video player nativly on Vu+ will bring the best experince. Alternative could be to update this old "GSTPlayer" video player for XBMC based on GStreamer: https://github.com/theuni/xbmc/tree/cex-abandoned/xbmc/cores/gstplayer That GStreamer player code ("GSTPlayer") was abandoned but could perhaps be updated for Kodi. Though I believe that Kodi have moved away from seperate players to using "codecs" instead, see: https://github.com/xbmc/xbmc/tree/master/xbmc/cores/VideoPlayer/DVDCodecs/Video/ There are "codecs" for OpenMAX, VAAPI, VDPAU, so you could make a new "codec" for GStreamer. Maybe you could port "GSTPlayer" into "GSTcodec" following the above examples?
medamine60 Vu+ User Feb 2, 2016 #24 Hello, very nice initiative, will test asap on duo² It's will help the newbies if you make a backup of your bh including kodi 15 Thank you Amine
