XMBC WORKING BRILLIANT
ant23man
Having problems with my blackhole XBMC setup on Solo2. Getting this error message "You need a tuner, backend software and add-on for the backend to be able to use PVR, please viisit xbmc.org/pvr to learn more" Can anybody help. Any advice would be very much appreciated. Thanks in advance.
ant23man
Having problems with my blackhole XBMC setup on Solo2. Getting this error message "You need a tuner, backend software and add-on for the backend to be able to use PVR, please viisit xbmc.org/pvr to learn more" Also no video or music plays. I'm getting this error message "import failed metahandler" "Script failed". Can anybody help. Any advice would be very much appreciated. Thanks in advance.
james81
You could try TSmedia
  • enigma2-plugin-extensions-tsmedia-oe2.0_7.95_light_all.ipk
