xxxx
vamas
I think that I have correctly installed ***** in my vu solo bh 1.7.8,
My blue panel is showing the following:
***** 2.30 - OK
2 cams installed < set default Cam>
Active ***** 2.30
channel details...
ecm info not active
Can any one point out to me if this is correct or should i be doing something to get all to work?
I have tried .lines to no avail
thanks for an answer
