youtube and audio problem with hd_channel
svarog22
1. youtube movies do not run smoothly. mostly the hd ones. i do not use wifi.
2. when changing the volume on the remote control nothing happens. but only in 5.1.-hd. in sd-stereo works ok.
black hole 1.7.3
Ev0
Admin
For the volume, press audio then red and it will turn downmix on, then volume control should work ok.
As for hd on you tube, can't comment on it, as it could be many things causing a problem.
Ev0
Admin
Then you use the volume on your 5.1 reciever to control how loud it is, as the vu+ just pass's the audio through to your amp.
a911
The BH Lover
i use it, but dif. in volumen is very big. sd is very low and hd is much louder. it is anoying
Try to adjust the settings for HD reception on your receiver (amplifier).
And this usually happen from the channel transporters,,,,and nothing to do with image!
