JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an
alternative browser .
Youtube for OpenBH 4.3 / BlackHole 3.0.9
Youtube for Open Black Hole 0.1 - 1st Update 15/11/2015
Support new base.js html5 player
Youtube for Open Black Hole 0.1 - 1st Update 24/11/2015
YouTube Video Url: fix player config JSON extraction.
Youtube for Open Black Hole 0.1 - 1st Update 20/12/2015
Youtube for Open Black Hole 0.1 - 1st Update 26/12/2015
Fix help_window hide when use VirtualKeyBoard on some skins.
Youtube for Open Black Hole 0.1 - 1st Update 17/01/2016
Fix PEP8 W391 blank line at end of file
Youtube for Open Black Hole 0.1 - 1st Update 12/02/2016
YouTubePlayer: use showSecondInfoBar to show YouTubeInfo
Youtube for Open BH / BlackHole / Open BlackHole - 1st Update 25/06/2016
YouTubeUi: try fix video download
Replace / in download file name
Remove comments in German translation
Do not use duplicate code in def Plugins
Fix some PEP8 style guide errors in plugin.py
YouTubeSearch: add SD sreen
Note: This was tested and works in all BlackHole Team Images ( BlackHole 3.0.2F, Open BlackHole 01, OpenBH 04 and OpenBH 06 )
Youtube for BlackHole 303 / Open BlackHole 06 - 1st Update 30/12/2016
Added Languages ( LV and PT )
Fix Youtube icons ( FHD and HD )
Remove history and watch later ( feature remove by google )
Note: This was tested and works in all BlackHole Team Images ( BlackHole 3.0.3C, Open BlackHole 06 ) and may work too on older images.
Youtube for BlackHole 303 / Open BlackHole 06 - 1st Update 21/02/2017
Fix extraction for domainless player URLs
YouTubeSearch: hide Help Window on menu
Note: This was tested and works in all BlackHole Team Images ( BlackHole 3.0.3G, Open BlackHole 06 ) and may work too on older images.
Youtube for BlackHole 303 / Open BlackHole 1.0 - 1st Update 27/05/2017
[jsinterp] Add support for quoted names and indexers
Note: This was tested and works in all BlackHole Team Images ( BlackHole 3.0.3I, Open BlackHole 1.0.017 ) and may work too on older images.
Youtube for BlackHole 303 / Open BlackHole 1.0 - 1st Update 31/05/2017
YouTubeVideoUrl: Fix identitation
YouTubeVideoUrl: Fix DASH manifest signature decryption
Youtube for BlackHole 303Q / Open BlackHole 1.0.028 - 1st Update 05/09/2017
*** THIS IS A LARGE UPDATE ***
YouTubeVideoUrl: parse player_url if format URLs are encrypted, thx y…
Add aditional stream videos formats
YouTubeVideoUrl: implement additional Dash MP4 Audio link for youtube…
YouTubeVideoUrl: remove forgotten unned test code
YouTubeVideoUrl: set second url_map_str as None
YouTubeVideoUrl: update some formats
Add Hungary po
Merge pull request #25 from chipcard/master
Remove comments in Hungary translation
Add YouTubeVirtualKeyBoard
Remove not used keywords in GoogleSuggestionsConfigText
Some PEP8 style fixes in YouTubeSearch
Small typo change in YouTubeVirtualKeyBoard
Always assign the searchRegion and searchLanguage in GoogleSuggestion…
YouTubeSearch: remove class GoogleSuggestions
Remove error callback from SuggestionsQueryThread
Remove param from SuggestionsQueryThread keywords
YouTubeVideoUrl: move Dash MP4 format to the end of the priority list
Introduce a difference search history for each search list
Increase the search history up to 40 entries
YouTubeSearch: fix entry delete in search history
YouTubeSearch: fix GSOD if history is empty
YouTubeVirtualKeyBoard: fix GSOD on exit with ok
Change YouTube icons to new branding style
Change also icon.png to new YouTube branding style
Add choice Play previous in video ends config
Regenerate translations after config changes
Fix latvian translation
YouTubeUi: use exception for all searchResponse results
Note: This was tested and works in all BlackHole Team Images ( BlackHole 3.0.3Q, Open BlackHole 1.0.028 ) and may work too on older images.
Youtube for BlackHole 304A / Open BlackHole 1.0.037 - 1st Update 24/09/2017
*** UPDATE ***
YouTubeUi: fix DASH MP4 video download
YouTubeSearch: fix search from history if suggestions not available
YouTubeVirtualKeyBoard: hide text in header if suggestions not available
Note: This was tested and works in all BlackHole Team Images ( BlackHole 3.0.4A, Open BlackHole 1.0.0037 ) and may work too on older images.
Can be downloaded from BH and OBH plugins server.
YouTube Git 350 (IPK Packages)(Black Hole E2)
If you have problems with the first video clip
exit and play again.
That's what I believe, only once.
Maybe registration.
Youtube for BlackHole 3.0.5.K / Open BlackHole 4.1.0.25 - 1st Update 13/04/2018
*** UPDATE ***
YouTubeVideoUrl: add 300 and 301 HLS format
YouTubeVideoUrl: try fix live streams extraction
YouTubeSearch: use Exception for HTTPConnection exceptions.
YouTubeSearch: remove functions showHelpWindow and hideHelpWindow
YouTubeSearch: intruduce HelpWindow move
Add bulgarian language to plugin
Note: This was tested and works in all BlackHole Team Images ( BlackHole 3.0.5.K, Open BlackHole 4.1.025 ) and may work too on older images.
Youtube for BlackHole 3.05 / Open BlackHole 4.1
Git >
https://github.com/Taapat/enigma2-plugin-youtube
Update from Git version 369 until 25/09/2018
*** UPDATE ***
YouTubeSearch: fix suggestions on OpenPLi develop
YouTubeVideoUrl: fix extraction
YouTubeVirtualKeyBoard: use also "prompt" in updateSuggestions
Added French language translation
Added Slovakian language translation
Added Italian language translation
YouTubeVirtualKeyBoard: try fix GSOD if youtube search is not available
Added Hungarian language translation
Added Bulgarian language trasnlations
Note: This was tested and works in all BlackHole Team Images ( BlackHole 3.0.5, Open BlackHole 4.1 ) and may work too on older images.
Youtube for BlackHole 3.06 / Open BlackHole 4.2
Git >
Update from Git version 370 until 29/09/2018
*** U P D A T E * * *
YouTubeVideoUrl: use DASH video on all resolution ( fix )
Note: This was tested and works in all BlackHole Team Images ( BlackHole 3.0.6, Open BlackHole 4.2 ) and may work too on older images.
Enigma2 Youtube taapat plugin git372 from 10-11-2018
Git -->
What´s new :
YouTubeVideoUrl: Add another JS signature function name regex
