Youtube TV - Loading Failed (BH 2.1.1) Duo2
jwlalek
I'm having the problem with starting the Youtube TV. I'm using BlackHole 2.1.1. I never had that problem before using the previous BlackHole images. On VFD i'm getting info: Loading Failed. Any ideas?
jwlalek
Sorted. I've had to reflash BH 2.1.1. Before that the box seemed to be a bit slow. I had to wait quite long time to get to "speed up the Black Hole". Now is working fast again.
brainmolester
Gents, is there a way to install YouTube TV on my Vu Uno?i have searched for the plugin but didn't find it! Apparently one can only find the pluging in speed up section on the BH on solo2 and others new machines. Your help is much appreciated.
angelofsky1980
BlackHole Driver Specialist
You must enable Opera+HbbTV from BH SpeedUp to get YoutubeTV plugin.
jwlalek
Two more things:
1.
There is a "Loading..." displaying on the screen while playing a movie. Is there any chance you could get rid of it?
2. Why the sound bar is not displaying during using a volume buttons?
bogdanm
Moderator
Two more things:
1.
Youtobe change big number time his algo i think mast be fix for this .
Im used other plugin to have youtobe [ please look to IPTV Plugin ] in last 3 weaks youtobe was fixed 3 time
brainmolester
He IPTV plugin is in polish....I want something in English and reliable...I've loaded opera n hbbtv but still cannot find YouTube TV ..... I want it so bad....please help.. Thanks
