Youtube
A couple of weeks ago I wrote about problems with YouTube TV. I installed OBH 0.1 VUSolo2_usb 20150525ae31ecg and after I updated the software YouTube TV didn’t work anymore. Everything seemed allright but YouTube TV did not download the videos and so you can’t play them.
I read that the problem with YouTube was solved. That is why in decided to install OBH 0.1 VUSolo2_usb 20150619-78a407f. All worked good even YouTube TV. But after updating the software I had the same problem as mentioned before. Is there a solution?
Now I use the software again without updates.
I use the software without multibooting. I also have the YouTube plug in and it works good but I prefer YouTube TV.
Because of this problem I tried OPLi 0.4 VUsolo2. There I had the opposite problem. After installing the software YouTube TV didn’t work. But after updating YouTube TV worked properly. However I got so many of the “famous” green screens that I concluded that Blackhole is much more reliable.
Greetings
Peter
