Zapping Mode Selection
Seth_72
hello , how can i get this to work Zapping Mode Selection, to get a list to apear with zap history
Moderator
Hi @Seth_72
I don´t have now BlackHole 3.0.2 in order to test it.
Can you test it for me and reply that if it matchs your needs?
Test it and reply.
  • enigma2-plugin-extensions-historyzapselector_2.2_all.ipk
Seth_72
Thanks , will do that tomorrow ang give you feedback. i seeking zap history like obh and i tried hmm new vti just for fun and they also use vuplus hit like blackhole and liked that they have with zap history and that was the only thing i liked , you press exit and a window apears with zap history and picons to just like obh. will give screen tomorrow after work.
Regards seth_72
Moderator
Regards seth_72
Ok, no problem.
thanks
regards
Moderator
tried on bh 2.17 before work and it crashed when i press a channel in the list in zap plugin
On Black Hole 3.0.2 it works, even in Black Hole 3.0.2 used in OpenMultiboot.
Probably and i don't know, maybe any dependency needed that is not present in Black Hole 2.1.7.
What i noticed is only the menu size that are not skinable for FullHD skins.
I will repack later with the lastest commits on git ... and wiill see what's going on, but only for Black Hole 3.0.2.
Seth_72
i still use bh 2.17 because some thing dont work for me in 3.02. so i have to wait for new blackhole comes out Before i upgrade and the thing i use will work.
thanks for the help
Seth_72
Hello Nunigaia. its crashes for me in bh 3.02 J
Regards Seth_72
  • enigma2_crash_1480536795.zip
