Zero box help
yobo0
Plug the dongle.
Turn on the box
Go to into Menu-Setup-System-Wireless LAN Setup
Setup your network
Hi. I'm having the same issue setting up my WIFI dongle on my vu+ zero box running Black hole 3.0.1.
Not sure if I'm missing a step here, but when I go to Menu-Setup-System, there is no option for Wireless LAN setup.
I have my wifi dongle plugged in, however this dongle was taken from my old F5 skybox, and has skybox written on it. I'm therefore unsure if this compatible with my vu+ zero, and if this is why the menu option is not visible.
I've tried adding the driver using the 'rt3070_2.5.0.3-r4-bh0_bm750.ipk', however still no menu option. Unsure if I perhaps need some sort of WIFI plug-in, or if I need a new WIFI dongle.
Any guidance would be much appreciated!
angelofsky1980
BlackHole Driver Specialist
If the menu entry is not shown, the device has not beed detected correctly and add (or try to add) the Duo1 driver is not a good idea.....
Open thread in the Wireless Devices sections with debug file attached (http://www.vuplus-community.net/boa...images-debug-script-per-le-immagini-bh.21512/)
yobo0
Plug the dongle.
Turn on the box
Setup your network
Hi. I ended up buying this wifi dongle following a recommendation on this forum:
GigaBlue USB 2.0 WiFi 300Mbps adapter
It seems to be a RTL8192EU
However, same issue with the dongle not being recognised, as there is no "Wireless LAN Setup" menu. I have tried my friends Belkin dongle, which is quite old but actually worked. Can't understand why my dongle is not recognised, as I thought the drivers were built in to Blackhole 3.0.1F, Kernel version 3.13.5.
I've run the WIFI debug, but it wont let me attach as I haven't been a member long enough. I can see the dongle listed under Device 005: ID 0bda:818b. Is there a particular section of the debug I can paste here for you to see?
Many thanks!
