Black Hole Vu+ Solo 1.7.9
yes I boot bh 1.7.9 but my solo after sae seconds play freeze the picture and the sound play. can you tell me why?
Thanks for great work.
I would like to help for the french menu translation. There are still mistakes.
In the main menu, "Paramètres" is better than "Paramétres" for instance.
"Connection" is English. In French, it's "Connexion".
Here we are!!! Another one thanking for a Jurrasic version of BH! Fantastic! 7th December 2012 the post with this image.
I really wonder how is possible such a thing.
Simply to increase the number of posts.
This is done when you are a newly registered newbie.
You choose an old TRD and you answer with "thank you", "well done" or similar things.
And that's why I proposed some days ago to close threads like this, when it's too old or, above all, it's a thread not specific (you'll never know if and when a technical issue might be useful again to go on with the discussion) but is generic and often contains an announcement about a "new" release.
Black Hole 1.7.9​
What's new?​
  • Vu+ drivers: 20121025
  • Enigma2 ver: 20121202
  • New skin: Army Touch HD
  • New: Support to 32 bit png
  • New MyTube fix
  • Update: HbbTv
  • New New New: Black Hole Speed Up
About Black Hole Speed Up:
As you know a large number of plugins are installed by default in our images.
During startup Enigma2 has to scan and check all the installed plugins.
Many of us don't use all of these plugins.
The new Black Hole Speed Up feature allows you to disable/enable the default plugins without having to completely remove the plugin.
By disabling all the plugins we are not using without having to remove them enables you to reinstate them at any time.
This will speed up the image performance.
WARNING: This Image is not compatible with the previous skins
Black Hole can not support images not installed in the flash.​
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Time Shift
Addons​
Infobar / OSD​
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel​
Addons (added)
Red Panel
Black Hole
Avalon
Chaos
Ghost
Credits
DISCLAIMER​
THE BLACK HOLE IMAGE IS BASED ON THE OFFICIAL FIRMWARE PUBLISHED BY VU+ AND IN ACCORDANCE WITH THE LAW IT CONTAINS ONLY SYSTEM ADDITIONS & GRAPHIC CHANGES.​
LASTLY, THE BLACK HOLE IMAGE DOES NOT CONTAIN ANY SYSTEM TO DOWNLOAD PLUGINS OR EMULATORS FROM EXTERNAL SERVERS OR SOFTWARE THAT MAY BE USED FOR ILLEGAL PURPOSES SUCH AS CARD SHARING.​
LICENSE (TERM OF USE)​
Where is download ?
