Announcements All about PrismCube
Processor : ARMv7 Processor rev 1 (v7l)
processor : 0
BogoMIPS : 996.14
Features : swp half thumb fastmult vfp edsp thumbee vfpv3 vfpv3d16
CPU implementer : 0x41
CPU architecture: 7
CPU variant : 0x1
CPU part : 0xc09
CPU revision : 1
Hardware : NXP BL-STB platform
Revision : 0000
Serial : 0000000000000000
total used free shared buffers cached
Mem: 323456 293168 30288 0 43336 24556
-/+ buffers/cache: 225276 98180
Swap: 1048572 568 1048004
Some time ago you have stated, that the BH team will support Prismcube.
I am sorry but i have to correct myself.
We are not sure that we can support PrismCube. It will be a huge amount of work and it will require a good amount of support from Marusys.
Without adequate support we cannot help because the system is new and totally different.
Yes I agree with this opinion
We already have a lot of work around the images.
We expect a different approach for XBMC PrismCube
We should not forget that this is a new system, and if all parties involved in the development want to be developed this require much more effort and work.
And of course our time .
So let's wait for the development of the situation because it is not yet clear.
And we can not guarantee anything at this point.
  • Like
Reactions: CHL
Please write more info ; whot satelite you suport ? will be version rotor your setting ?
Im ask becouse im never see your settings.
astra+hotbird+nilesat
my settings is here...
http://www.premium-sat.com/services.php?cont=prismcube
NO EXTERNAL LIVE LINKS PLEASE!
Angelofsky1980
Angelofsky1980
ok but no favorites :(, it's the resul of a simple scan of this three sat
Is there a soft to manage settings or to import them from dream or vu+ ?
how to acces to internal folders ? what soft can i use ? what's the log : root ? and pass: 0000 ?
how to config a H-H discq motor ?
setting prismcube is not compatible for dream+vu+ is diferent
All these information are currently private...
new setting astra hotbird nilesat hisapasat bader atlanticbird3
and wait 4 days for new setting+favorites channels
sorry for my bad english admin
Finally I received a prismcube for test :)
What I directly saw is there is no power switch on the back of the box and it has 1 USB port which is pretty poor.
The 2,5inch HDD is nicely covered at the bottom.
The remote controller looks good and basic navigation works fine.
Recording up to two channels and timeshift works smoothless.
PiP I cannot find it how to activate, maybe it will been add later as the chip supports it.
XBMC combined with DVB is very poor. It's actually two seperate GUI menu or your in XBMC mode or in DVB mode.
Booting time is poor compared to simular chipset. It takes 53 seconde to get first picture and over 90 seconde to get access to GUI like infobar.
XBMC mode functions good I noticed that some options in menu and buttons are removed.
DTS is not working as you cannot activate it (Can been heard through software) as this option is removed from menu and forward and backward spooling is removed, however jumping is working.
The prismcube has must better graphical GUI menu and picture quality then ever seen on an E2 box.
Channel changing is average
Overall menu scrolling is a bit slow
how to hardreset xbmc ? returning in usine parameters ?
In STB menu you have by Install Configuration when scroll down the option Factory reset.
many Thanks To Clear that Cos I've post the same thing some time ago and got some Criticisms about that :) good to see I was right ;)
