Barry Allen Support thread
the last update for Barry allen 18/19/20 not support VU+ just dreambox
yes I can see now gives this error
Collected errors:
* satisfy_dependencies_for: Cannot satisfy the following dependencies for enig
a2-plugin-extensions-barryallen:
* dreambox-secondstage *
ba 11.3 doesn´t work under solo² and bh 2.9.0.1
message at install:
* satisfy_dependencies_for: Cannot satisfy the following dependencies for enigma2-plugin-extensions-barryallen:
* setopbox-secondstage *
Is it possible to use 2 USB sticks - 1st for meoboot and 2nd for Barry Allen? I already use 1 usb with meoboot (and I'm unable to install Barry Allen at all), but if I add second USB and format it in ext4, how will Barry Allen determine to use the second USB to install its files?
This is what is written in small tutorial on Howto Barry Allen on Bh image : " 1) Upload your image zip file into the folder /media/ba/backup" But after installing Barry Allen there is no such directory as backup in /media/ba/ Where else can I FTP image.zip file to install with Barry Allen?BA folder 2.jpg
Installed on my Vu+ solo2 with
Black Hole Vu+ Solo2 2.1.0
no errors during installation but at reboot the box displays "Starting..." forever.
I must remove the usb stick to boot.
