Barry Allen Support thread
You have to split the USB flash drive into two partitions.
2 partitions: vfat 1%, 99% ext4.
One must then mount the ext4 partition only
I don't think that this is the solution: I've tried BA with VTi image and the same usb stick and it runs correctly.
The problem is somewhere else...
Yes now ba works with latest bh image thx petry and prlisofnver for useful info
Sent from my LG-D802 using Tapatalk
Just one of my friend having truble can you letme know have you got hdd installed and what size usb stick u using thx i cant test my self coz dont have duo1
Yes i have hdd installed and 4 Giga usb stick size.
