Barry Allen Support thread
Habe BH 2.0.4 auf einer solo² und bei mir läuft BA 10.0.3 auch nicht.
Ist installiert und ich sehe es auch unter Erweiterungen.
Habe aber kein Bootmenü und installierte Images starten nicht.
Immer nur das Flashimage.
Ein .log wird leider nicht in /media/ba abgelegt...
Wollte BA testen, da meoboot unter BH 2.0.4 auch nicht richtig funzt.
Only English in International Support, please!
ok, sorry... (i triy it in english)
i have a solo² with black hole 2.0.4 and i tried to use barry allen 10.0.3
plugin is installed, i see it in plugins.
but there is no ba bootscreen and no other installed images will boot.
only the flash image.
and there is no .log in /media/ba like gutemine says.
i would try barry allen because meoboot doesn´t work correctly with blackhole 2.0.4
many installed images doen´t work ...
Barry Allen 10.0.4
Here is the changelog for the current kit of Barry Allen:
* This kit is ONLY for all current OE 2.0 images and also supports v2 boxes and their images to extract and boats
* Image ZIP file with the root as UBIFS are now also supports things without additionally installed
* Images with lzo UBIFS compression or can be backed up again now
* Now there is a new setting in the plug to remove for better performance on the 800se 500hd and squashfs images in Barry Allen Images.
* Bainit 90 in the flash file system check but still makes bainit 99 images in Barry Allen makes on the 500hd and 800se now a squashfs recovery.
* Automatic Swapen on boot is enabled again and created also equal to 256 MB large swapfile itself
* Wally West 8.0 kit is now released (but does NOT work with the old 800, so even a mips32el ipk) and UBIFS he is not yet tested, we will probably need to 9.X new.
* The install of Debian is now used instead of wheezy sid.
* It now comes nfidump 0.10.X for use in extracting the foreign images has been improved and you can now also only the root with UBIFS as zip save image
* Barry Allen now has a guest mode and you will have to find out what the.
LG
gutemine
you should not only corsspost, but also check if the situation on the bootmanager frontier improved.
i have installed latest BA on my duo2 and solo2 with bh image every thing all ok till trying to boot from any installed image on BA never boots from installed image all ways boots image from flash pls when u got free time have a look for me thx very appreciated for all your work
Barry Allen 11.0.4
Please try 11.0.04 - but once more, this is a testkit for making the v2 boxes work, if you don't give any input it will expire again without getting a released 11.1
Thx @ gutemine
Barry Allen 11.0.4
Thx @ gutemine
duo 2 :plugin list barry ok.
extract zip image ba files ok.
vu+ duo2 machine open not barry.not boot not work
