Also, when I stop the USB tuner process with /etc/init.d/usbtuner stop and then restart it with /etc/inint.d/usbtuner start command, my box freezes and have to manualy on/off it...
Ok, I will create a swap file on a usb drive.I've made a very quick test with another device who uses the same chipset of your device and the results are not good.
I think I've some problems with my Vu+Duo box used for tests and i hope friday to make new tests with a Solo box that seems more stable.
I'll kepp informed you.
Also, create a swapfile into a USB flashdrive to avoid memory problems (at least 128Mb)
Good morning,
As I wait for your tests, I ould also like to point out another issue with the dvb-t. More often than not, it loses the channels, saying "no SID in PAT" or something like that. I have to re-scan the dvb-t frequencies and all is ok, until the next time.
Yes, but after rebooting, still no SID in PAT... Only with a re-scan all is ok for some days...Did you try only to reboot your box?
Good Morning,I've made a very quick test with another device who uses the same chipset of your device and the results are not good.
Just to help you find out what happens, I mostly have the problem when changing from the satellite channels to the digital terrestrial ones. It's as if changing hardware receiver disrupts something...I've made a very quick test with another device who uses the same chipset of your device and the results are not good.
Good evening,I haven't made tests becuase my daily work take me a lot of time.
Today I'm at home (rest day) and I can make some tests.
