BH Addons Server Reports
@all
Please post here for any suggestion or problems you find about BH server addons.
We will try to follow you :)
To the Blackhole Team
Beta 2 image is not compatable with TV ON DESI ZONE. Please help to fix this issue.
(TV ON DESI ZONE is on the fusion server http:/fusion.tvaddons.ag
Download Addon Installer, Select > World Section > AJ ADD-ONS (Indian)
Reboot Xbmc.
SYSTEM > addons > get addons > AJ add- ons (new look) > Video Addons then select TV ON DESI ZONE
I thought I'd pass this information so that you and the team can identify this addon.
Please could you help. So many people watch this addon on xbmc.
I hope the Blackhole Team can fix this. Thanks
Using Vu+ Duo. I have been installed the serienfilm extension, which collects recorded series into their own folder and also shows all folders under "movie" when displaying "recordings". On updating to BH 2.1.6 there is clearly a problem now with this extension. When installing it from the menu/addons/manage extension/multimedia it reports a successful installation and restarts enigma2. All looks fine. However, select "recordings" and none appears, all buttons are invalid, can't change channel, power off from the back required.
Anyone else come across this, and any solution?
I cant access to plugins,it says Connection failed!Image is up-to-date,I have internet acccess,I can only download channel setting list...
Why can't find picons of nilesat and Badr on server??
If you have all the picons files tested ... 220x132 transparent picons ... for that sat positions, i can repack it and ask for upload it to the " picon feeds ".
Upload the files on the picons section ... i will do the job, asap.
There is an autobouquetsmaker 2.4 available in Black Hole Addons Plugins, will there be an autobouquetsmaker 2.9 version available? or is there a suitable PFK file?
