BH Addons Server Reports
You can expand it via ftp, but it is better you use panel to see if you have problems.
Do you have picons installed? If yes, where?
Yes I have picons installed.
Because I am using MyMetrix Skin I have 2 lots -
/usr/share/enigma2/picon (1.8MB 100x60)
/media/usb/XPicons/picon (3.6MB 220x132)
Check in device manager if media/usb is properly mounted.
Don't use this /usr/share/enigma2/picon for picons, put them in /media/usb/picon, because /usr/share/enigma2/picon is in flash and you risk to fill it up.
Try to remove dir /usr/share/enigma2/picon and install a plug if it solve.
I will try that tonight and let you know how I get on.
Thanks again.
I looked in Sys Info page.
From memory my RAM usage was 45% and everything else (flash, USB, HDD) was much lower.
Is there a way for me to check it remotely?
I did just FTP a folder (12MB) from my work PC to the /usr/lib/enigma2/python/Plugins/Extensions folder and then copied it back again.
It transferred successfully.
try to give this command in telnet and tell me what you have
df
Thanks, I could try that again...
I installed 2.0.7.1 last Friday and then upgraded to 2.0.7.2. I then discovered that I couldn't install anything from BH Addon Server. I could connect to the server and view the packages but they would not download.
On Saturday I installed 2.0.7.1 again but decided to do a fresh install and to not restore any settings from my backup. After this I was able to install a plugin from the BH Addon Server. On Sunday when I tried to install another plug-in I discovered I was not able to install from BH Addon Server again. Tried several time since.
I can try upgrade to 2.0.7.2 again, but not sure my box will download the upgrade :).
Will try tonight.
I have some similar issues when I flash the BH 2.0.7.2 (flashed 2.0.7 but updated to 2.0.7.2).
1. check whether your network is good and to select a good time to do the update (Bussy hours [20:00-22:00] may be not the best time, network or server are too busy )
2. Try a different plugin to test the server and the plugin (LCD4linux3.8.R1 seems has problem with BH2.0.7.2 but the LCD4linux3.7.R8 is no problem, some other plugins may need other files before installation)
3. Easiest way to sort out problem is reflash image again, install your plugin then uplaod your channel list. Do not use the backup option. (my experience is that setting the box takes less than 10 minute without rescan, but figuring out some unknow issues may cost much more time.
Good luck!
df
Hi,
I tried to manually install the plugin - It installed but with problems. When I looked in the Plugins folder there was an error message saying the plugin cannot be displayed.
I checked that the USB stick was properly mounted - It was.
I used the df telnet command to display my memory usage - plenty of free memory.
I removed the dir /usr/share/enigma2/picon - this didn't resolve the issue.
I ended up re imaging.
I installed 2.0.7.1 from memory stick then did online upgrade to 2.0.7.2.
I installed my first plugin manually by dropping it into /tmp folder.
I then installed 1Channel and permanent timeshift from BH Addon Server.
Then I installed the MyMetrix Skin and Openstore from BH Addon Server.
From that point on I can't download and install content from the BH Addon Server again.
Perhaps it is an issue with the MyMetrix package.
Hi,
That is trange.
Try to uninstall mymetrix plugin and see if you can download other plug.
I don't think Mymetrix is your problem.
Post here the result of command df
root@vusolo2:~# [6df
Filesystem 1K-blocks Used Avaiable Use% Mounted on
ubi0.rootfs 200468 76512 123956 38% /
devtmps 2048 104 1944 5% /dev
tmpfs 285988 2144 283844 1% /var/volatile
udev 2048 104 1944 5% /dev
tmpfs 285988 0 285988 0% /dev/shm
/dev/sda1 976459900 136951428 839508472 14% /media/hdd
/dev/sdb1 3908720 57568 3851152 1% /media/usb
root@vusolo2:~# [6n
root@vusolo2:~# [6n
Seems to be ok.
Seems to be ok.
I've noticed a few instances of this now tamaki... Don't know what's causing it but its happening since online update bud. If you change the port setting in open webif strangely it works again? It happened to me and that's the only thing I've changed to get it working again. Its odd
