BH official Norwegian Translation
I have a lot of plugin translations in this file
I know that, but some you can´t get it 100% translated without translate the plugin files itself.
By other way, you´ll increase enigma2 translation file, that in my opinion, must be the more clean possible.
@Ev0, can you make sure this last one gets in next update? Some changes, wont have time to make one alone for Subsupport in a while.
Hi Roddis
add:
msgid "Bluetooth Setup"
msgstr ""
msgid "Device is enabled."
msgstr ""
msgid "Please select scan mode."
msgstr ""
msgid "Scan and setup Vu+ Bluetooth RCU"
msgstr ""
msgid "Scan other bluetooth 3.0 device (A2DP, HID)"
msgstr ""
Regards
How do I set up these, several lines?
Try this:
msgid ""
"\"Wit.ai speech to text Setup\" gets the speech data from VUPLUS-BLE-RCU and converts it to text using wit.ai.\n"
"\n"
"1. Sign up for wit.ai (https://wit.ai)\n"
"2. Enter \"server access token\" under the settings menu to below.\n"
msgstr ""
@Roddis
this is the exact syntax
#: Satconfig.py:652
msgid ""
"\n"
"<This tuner is configured automatically>"
msgstr ""
"\n"
"<Denne tuneren blir konfigurert automatisk>"
Ciao Friend
