BH Vu+ Duo v. 1.6.2 beta Dolby Digital Plus & Subtitles fix
it works! great job guys!
i just install it and try it on TF1 HD et france 2HD (AC3+) on atlantic bird 5°W
with that you just simply kill dreambox !!! (the dreambox's staff didn't even taked time to answer people who asked for AC3+ plugin....)
I think you refer to DTS downminx to stereo: I should make some tests around this issue because I've a recent amplifier (in my signature) who is capable to use the DTS track via HDMI cable :)
The picture quality is already very high :)
thanks
yes , a refer to DTS downminx to stereo , many people are patient to see this option in the box
We all have to thanks Vuplus for this that added the support for DDP in their drivers.
We will have the DDP support on all Vuplus boxes.
from spain: tve hd with dd+ now sounds in stereo, not 5.1 but works fine in stereo. A great news!!
only one thing, when i restore a config by personal backup, never active the usb tuner, i must activate it. this is normal??
this is not a problem, i active, reboot and then work perfect XD
thanks again!
thanks again!
Yes, it's normal to re-enable Usb tuner from dedicated panel after the restore :)
Hello
I can confirm that DD+ works well on terrestrial channels like TF1 HD, France2 HD and M6 HD.
A big thank you to VU+ and BH team.
I have som trubble with my new wlan stick.
I got this one: vu-wireless-usb-adapter-150-mbps
After a reboot i'll find it under network.
I activate it. Sett DHCP to no. Enter the ip adresse and nameserver. Set use gateway to yes and enter the gateway i use and press ok. Then i get a green screen. What do i do wrong?
Her is cut from my crash log:
  File "/usr/lib/enigma2/python/mytest.py", line 201, in processDelay
    callback(*retval)
  File "/usr/lib/enigma2/python/Screens/NetworkSetup.py", line 525, in keySaveConfirm
    self.applyConfig(True)
  File "/usr/lib/enigma2/python/Screens/NetworkSetup.py", line 573, in applyConfig
    iNetwork.writeNetworkConfig()
  File "/usr/lib/enigma2/python/Components/Network.py", line 160, in writeNetworkConfig
    fp.write(iface["configStrings"])
TypeError: argument 1 must be string or read-only character buffer, not None
(PyObject_CallObject(<bound method Session.processDelay of <__main__.Session instance at 0x17248c8>>,()) failed)
        </enigma2crashlog>
        <pythonMD5sum>
            <![CDATA[
Edit by staff: External link not admitted!
I got this one: http://www.hm-sat-shop.de/hdd-receiver-hdtv-vu/vu-wireless-usb-adapter-150-mbps.html
    callback(*retval)
        </enigma2crashlog>
        <pythonMD5sum>
            <![CDATA[
I've detected the same bug into beta 1.6.2 image and I've sent the same crashlog to BH coder to try to solve it.
I also have the same probleme. My usb wlan, when I activate it, enter my wlan key, I get green screen .. So I have to to go back to 1.6.1 version ,where everything seems fine ..
I have edit the file /etc/network/interfaces
After that the gateway is ok, but its not connecting to the wireless lan.
I have selected the right wlan and entered my key.
Are there something i have forgotten?
