BH Vu+ Duo v. 1.6.2 beta Dolby Digital Plus & Subtitles fix
Can we expect in future fix for DTS audio,because still not working it on HD rip movies playing from HDD :( ?
If you speak about DTS downmix to stereo I don't know: DTS audio tracks with a digital compatible amplifier already works without problems.
I was still using 1.5.1 so it was high time to upgrade. I was about to put 1.6.1 on when I saw this one so thought let's give it a go. Installation went fine, I am using a Sundtek Media Pro tuner for DVB-T. Installed it like I always do, started it, started OK. But unfortunately I was getting the Tunning failed error message, please check tunner configuration. The configuration was correct.
I went back to 1.6.1 and all working correctly.
I am not sure if other sundtek users can confirm this is happening for them too. Would be good to know.
Thanks a lot
Anyone with Sundtek Media TV Pro tried this image, can you report if you could get your stick to work, I couldn't?
Cheers
many people are not amplifier , utility of this option is show MKV/DTS video via USB in the box . now sound DTS not work . for exemple
in the AZboxHD DTS sound work very well .
I understand the needs about the downmix from DTS to stereo.
So dreambox models have possibility for DTS downmix on stereo with some application (no licence) I think that VU+ need to implement same thing.
If the downmix needs a license, Vu+ need this license. It's into the interest of manufacturer to have a regular and licensed product.
If exists an image with this function for Vu+ please feedback me the URL via PM system :)
i am dissapointed you don't think of fixing that simple time problem :
user could select : time from NTP server or time from transponder
Will there be further development into subtitle fix, like support for original colors and choosing font & font size?
I had a crash when using subtitles on "live subtiteling" as in for exaple BBC news. Image freezed and green screen. Has been no problem before 1.6.2. Otherwise great improvments, thanks!
Is there someone that has been looking into this problem? I had another crash now On ITV news. There are no problems at all when watching synced subs like in movies or documentaries. It´s only when you have a small delay in subs like in news and sports programs.
Do you have a crashlog to upload here?
