Black Hole 2.1.4 B solo
Explain why swapping ZRAM?
The 1920x1080 framebuffer support has required extra Ram usage.
Someone noticed the change? What to do to see the changes?
The 2.1.4b not works fine because the memory crashes...
If uou have memory crashed please write more infowhot is your setup ; whot plugin are you used, when yiu have crashed after used plugin record etc . all info help developer.
Hello Snowshoe:
i´m trying the 2.1.0 version of BH in my SOLO. I have a problem, the infobar channel doesnt update the info when the event changes...any solution? thanks for all ;)
Hello Snowshoe:
hi fooz, honestly i never paid attention to this thing. i will try to watch something and see if the infobar shows up when the next program shows and i will let you know.
other than that, is everything else working fine for you?
I did it, but that is not the solution...
That's sounds like epg or hdd problem wich satellite channels you looking for epg
Do you have full epg loaded on you box/hdd which skin you use
