Black Hole 3.0.1.F Vu+ Solo2 OE 3
Black Hole 3.0.1.F OE 3
update driver(solo4k)
20160119
- Support Chromium OS
- Fix DiSEqC problem
- Improve power consumption
- Fix misc.
Chromium OS added (solo4k)
Youtube Tv added (solo4k)
Fix RC key position on help menu.
Fix tuner Loopthrough issue
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
LICENSE (TERM OF USE)
Hi
When i search astra 19 E
Ferequency 11720 H 27500 and 11758 H 27500
Sky select and blue movie and etc
I have signal quality and my receiver searched it but when i go to satellite i cant show these channel
Why?
Hi
Why?
Press and hold Green button when on those channels and it should bring up the Sub-Menu
Thanks Ev0. I've got an issue after updating my box. The transcoded streaming is not working any more. Anyone else is experiencing the same behaviour? Thanks
You didnt understand my mind
I search this ferequency but i cant show this channel in my channel list(satellite)
That is because they are scanned in as data channels I believe.
You might be able to edit your channel list with opendbedit or similar to convert them from data to tv channels.
thanks ;)
It's possible to watch one channel while recording another? I have set the tuner A loopthrough to Tuner B but I do not get it to work. With BH2 work fine.
Thanks
great job , but think to make a version without xbmc since the flash memory is almost full of SOLO2 , thank you for your understanding
NB:
latest version of the image VTI : remove from xbmc image ( solo4k , DUO2 , SOLO2 , Solose )
I can't delete my mount point for network hard drive. I get a notice to wait until delete the mountpoint network but stuck there..
Can u help me?
Stavo cercando come fare il backup (non ho trovato da nessuna parte il plugin per farlo), ma poi ho deciso di rimandare qualche minuto avendo trovato ed installato i picon e aggiornato (me lo ha chiesto il box) alcune estensioni (non so quali) poi si è riposizionato sul canale che stavo guardando e c'era già la picon del canale stesso....cambio canale...e...ed improvvisamente non ho visto più nulla. Mi dava errori relativi al satellite...
Vado sul menù e vedo che non è più presente il satellite astra nella configurazione tuner...
Così spengo tramite telecomando (pressione lunga-->spegni), riaccendo e pam! Rimane su starting e l'immagine BLACK HOLE nera....e non si sposta....
Ho già provato a riflashare usando la chiavetta che ho usato la prima volta, ma niente, resta li...
Ora sto scaricando la nuova immagine al primo post, sperando funzioni...
Diversamente, che posso fare?
