Black Hole 3.0.1.F Vu+ Solo2 OE 3
Ok, ho usato la nuova immagine e riflashato!...Tutto ok!
Domanda: Ho installato tutto stock, lista canali compresa....Che succede se scarico vhannibal, mi ritrovo i canali doppi?
LeLe mi sa che sei nella sezione sbagliato, qui international, only english, you are on the right session of the forum for the solo2 :)
if you install Vhannibal I suppose this will overwrite the manual channel.
Ciao
Does anyone solve the issue with the recording of the IPTV? I love this image but I can't get freeze every time I set a rec.
Thanks
Black Hole 3.0.1.F OE 3
update driver(solo4k)
20160119
- Support Chromium OS
- Fix DiSEqC problem
- Improve power consumption
- Fix misc.
Chromium OS added (solo4k)
Youtube Tv added (solo4k)
Fix RC key position on help menu.
Fix tuner Loopthrough issue
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
LICENSE (TERM OF USE)
[/QUOTE
Hi can I try to install this on my bricked vu+SOLOse2
[ALINTI Ev0, post:"201378, üye: 4715="]
..... Kara Seçilen Seçilen Delik.3 F OE
(solo4k)da sürücüsü
20160119
- Destek Krom OS
- Düzeltme DiSEqC dil dil sorunu
- Güç tüketimi artırmak
- Düzeltme çeşitli.
Krom OS solo4k ekledi ()
Youtube Tv (solo4k)eklendi
Yardım menüsünden düzeltme RC anahtarı yerleştirin.
Düzeltme Loopthrough tuner dil dil sorunu
[/EKLE]25135[EKLE] Tam=
Black Hole serisinin 4 4 bu oğlum (tamamen yeniden yazılmıştır ve maksimum kararlılık ve performans için kod geliştirildi.
Tüm resimlerin Black Hole şimdi iyi epg sistemine sahip olduğuna dikkat ediniz:
- Entegre OpenEpg
- Rytec özel epg.dat
- Yeni sistem geçerli.dışarıda dat.
Bu evlat özelliği sevdikleri EPG veri dosyaları oluşturmak ve bir web alanı içine yük çeşitli forumlarda ya da topluluklar için imkanı verir.
Topluluk üyeleri daha sonra bizim sunuculardan indirebilirsiniz.
Bu özelliği gibi diğer yararları sağlar:
EPR indirme hızını artırın
Herhangi bir kanal indirin EPR
Hatta saat saat bekleme sırasında EPG çözücünün indirmek programı
Kullanıcıların Ekle / Kaldır ' fonksiyonunu kullanarak sağlayıcıları özelleştirebilirsiniz
Uzaktan kumanda üzerindeki düğmeler ana fonksiyonları
TAMAM = basit bir bilgi ile Cilt
OK butonuna x 2 = Ekstra Bilgi Skin
Mavi düğmeye = Black Hole Mavi Paneli
Mavi tuşa ve ardından Kırmızı tuşa = Black Hole Epg Paneli
Mavi tuşa ve ardından Sarı düğmeye = System Monitor Paneli
Mavi tuşa uzun basın = Uzantıları
Sarı düğmeye = Ses menüsü
Yeşil düğmeye = Black Hole Yeşil Paneli
Yeşil uzun basın = Subservices düğmesi
Yeşil düğmeye ve ardından Kırmızı tuşa = Hızlı Plugin Kur
Yeşil düğmeye x 2 = Hızlı Plugin
Kırmızı düğmeye kısa basın= erişim, HbbTv fonksiyonları
(Paralel Evrenler İşınlanma)Kırmızı düğmeye uzun basın= Kırmızı Paneli
201580, üye: 10734"Teşekkürler ALINTI=[Gggtggg, post:"]!!!
Bu en iyisidir.[/ALINTI]
Eklentileri
Yeşil düğmeye ve ardından Sarı düğmeye götürür:-
Kara seçilen seçilen delik eklentileri için özel Bildirisinin Bildirisinin sunucu'ya'ya
Black Hole sunucusundan ek paketleri indirin ve yükleyin
Bilgi Çubuğu / OSD
Analog Saat Gui
Kanal yörünge konumu
Gelişmiş Tuner Bilgi: Sr Freq Pol Fec
Sinyal SNR, BER
Bilgi Çubuğu picons
Kara seçilen seçilen delik Panel Özellikleri
Mavi Panel
Ekstra Ayarları
Siyah Hızlı Seçilen Seçilen Delik
(Zamanlamaları Yönet)Black Hole Cron Yöneticisi
(OSD konfigürasyon)OSD Ayarları
Cihazlar:
Usb Biçim Sihirbazı
(Kernel modülü operatör)çekirdek Modüller Yöneticisi
(Yapılandırma İnadyn)İnadyn Ayarları
(Dosyasını Swap Yapılandırma)Takas Dosyasını Ayarları
(Sabit Disk Yapılandırma)Sabit Disk Ayarlar
( OpenVPN Panel)OpenVPN Paneli
( Samba Panel)Samba / CIFS Paneli
( NFS sunucusu Panel)NFS Server Paneli
( Telnet Panel)Telnet Paneli
( FTP Panel)FTP Paneli
UPnP Client Djmount
Pcsc Paneli
Tuner Server
Ağa Göz & Mountpoints
Bilgi Paneli
1 (Gui yapılandırmaları) - Gui Ayarı
2 (Bilgi sistemi) Hizmet Bilgileri
3 (Bilgi) - Hakkında
(Hafıza) Bellek
(Kapasite) alanı
(İşlemci) CPU
(Süreç)süreci
EPR Paneli
(Genel Ayarlar EPR)Genel Ayarlar
(ISS ayarları)Ayar Sağlayıcı
Yeşil Paneli
Favori eklentisi (Yapılandırma hızlı erişim)hızlı Plugin Kur
(Favori eklentisi Erişim)hızlı Plugin
(Eklendi)eklentileri
Paket eklentileri Download Manager (indirme Yöneticisi)
Online Ayarlarını da Beslemeleri
Manuel (Black Hole paketlerin Manuel kurulum)BH packges Yükleyin
Manuel SAĞLAYİCİ paketleri (Manuel kurulum)SAĞLAYİCİ paketlerini Yükleyin
(Kaldırıldı paketleri)eklentileri Kaldır Paneli
(Bkz. bağlantıları, üst yüklemeler ve daha fazlası)Black Hole İstatistik
Kırmızı Panel
BH Paralel Evren İşınlanma
Avalon
Kaos
Hayalet
Kredi
Teşekkürler Yedekleme komut için Pedro_Newbie için
Beta testleri grubu sayesinde.
Teşekkürler tüm epr Ile Bildirisinin Bildirisinin sunucu'ya'ya bize sağlamış Rytec için.dat dosyaları.
Entegre EPG yükleyici için MaxZ4 için teşekkürler.
Çapraz EPG için Skaman sayesinde
OpenTV kaynak kodu için (VDR-İtalya) Lukkino sayesinde.
Dosyasını satellites.xml için Reinh@rd teşekkürler.
Orijinal autolanguage ve Altyazı Seçenekleri kod Takım Littlesat ve Pli teşekkürler
YASAL UYARİ
KARA SEÇİLEN SEÇİLEN DELİK GÖRÜNTÜ VU+ TARAFİNDAN YAYİNLANAN RESMİ ÜRÜN BİLGİSİ DAYANAN VE YASA GEREĞİ SADECE SİSTEMİ EK & GRAFİK DEĞİŞİKLİKLERİ İÇERİR.
KARA SEÇİLEN DELİK GÖRÜNTÜ İLE VEYA ÜCRETLİ ÜYELİK OLMADAN TV İZLEME ÖDEMEK İÇİN HERHANGİ BİR ÖYKÜNÜCÜSÜ, K E Y, S, EKLENTİYİ VEYA DİĞER SİSTEM İÇERMEZ.
OĞLU OLARAK, KARA SEÇİLEN SEÇİLEN DELİK GÖRÜNTÜ KART PAYLAŞİM GİBİ YASADİŞİ AMAÇLİ KULLANİLACAK OLABİLİR DIŞ SUNUCULAR VEYA YAZILIM DAN PLUGİNS ÖYKÜNÜCÜSÜNÜ VEYA İNDİRMEK İÇİN HERHANGİ BİR SİSTEM İÇERMEZ.
(KULLANİM SÜRESİ)LİSANS
KARA SEÇİLEN SEÇİLEN DELİK GÖRÜNTÜ HERHANGİ BİR ŞEKİLDE DEĞİŞTİRİLMEYECEK VE SADECE YASAL AMAÇLAR İÇİN KULLANİLAN OLACAĞİNİ VERİLEN TÜM KULLANİCİLAR İÇİN ÜCRETSİZ KULLANİM İÇİN VERİLİR.
BÖYLE KART PAYLAŞİMİ VE ÖYKÜNÜCÜSÜNÜ GİBİ GÖRÜNTÜ VE YASADİŞİ KULLANIMI DAHİL KARA SEÇİLEN SEÇİLEN DELİK GÖRÜNTÜ İÇİN HERHANGİ BİR DEĞİŞİKLİK VEYA EKLEMELER MÜSAADE YÜZEY VERİLMEZ VE BU LİSANSİN İPTAL NEDEN.
Bu özgür hobisi yazılım ve kesinlikle hiçbir garanti ile geliyor. Kendi risk Flash Web Sitesi, Bloglar.
[/ALINTI]
[201576 playboy54, post: üye: 20872"ALINTI="] [/ALINTI]sistem yedekleme kullanabilirsiniz
Do not fix backup program
the 3.29 version of the plugin works fine in all images of blackhole!
i deleted ddamir 401 from extensions with ftp.
i install 3.29 ipk file on temp but nothing happens.i get message that i cant downgrade package enigma2 ,plugin,extension,subtitle player on root from 401 to 329.
20160119
- Fix misc.
Addons
Infobar / OSD
Analog Clock Gui
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
UPnP Client Djmount
Pcsc Panel
Tuner Server
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
Vu+Solo2: Scam 3.60 not working with Smart HD+ PL with this BH, Black Hole 3.0.1.F OE 3
No problems with erler versions 2.17,2.14,2.13.....
This is a minor thing but there's no date on the front display in stand-by, only the clock. How can I fix that?
20160119
- Fix misc.
Addons
Infobar / OSD
Analog Clock Gui
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
UPnP Client Djmount
Pcsc Panel
Tuner Server
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
Thanks
