Black Hole 3.0.1 Vu+ Duo2 OE 3
Great image but I cannot use it.
I have a problem to configure the wireless network,
I tried all the method without success.
I don't understand why the dns server cannot be saved.
When I activate the network ,it doesn't work and I see that the DNS server come back to 0.0.0.0 and not the IP i entered.
Regards
Can we hope that this new version correct the bug Inside the openwebif for the second
icon for transcoding , because it desappear since a couple of time.
Has anyone tested if this has been fixed? Can you stream easily over WebIF in this version and is there the second icon for transcoded stream? Thanks!
Black Hole 3.0.1 OE 3. When using a CAM- module CONTINENT is rebooting the receiver , on the other the image is not happening. Maybe someone knows why?
Regards
If you have trouble installing network
wireless network
use only NetworkWizard configuration panel.
Do not use adapter settings panel.
Hi black hole team coders,
is there any chance that one day we could find the second tv icon in openwebif,
i mainly bought that vu+duo2 for that specific feature, and now nearly a year that it
is no longer present in latest image.
Do you have any feedback about resolution for this .
thank you
I can not set the LAN. Nameserver is unconfirmed whatever I would do. Thanks for your hard work but you should test it before releasing.
All working good, super images, thanks.
Side note, will there ever be a day when installing a simple online plugin will not force us to restart the GUI?
Keep up it up :)
LAN. It's working now but I spent too much time to sort it out.
Verify please if there is an online update ... cause this morning i have updated my DUO2 ... 41 packages.
I think there´s an work around in it.
Test it and reply.
Test it and reply.
There have been 49 packages updates on my Duo2.
