Black Hole 3.0.1 Vu+ Duo2 OE 3
BH Team!
You'll have to work
The wifi network is not working (BH feeds, addons connection problem, youtube tv loading failed etc.)
BH Team!
You'll have to work
Try this:
- setup your router with an DHCP association for your box (specify an IP for a mac-address)
- enable DHCP on your box
The Wifi network on your box should takes the IP you have specified into your router and you should solve your problems about DNS.
Hi I problem with wlan network connection... DHCP is off ..because matrix say that ..please help me or solve the problem because when DHCP on or off the connection problem exist.thanks great team
Agn
If you have trouble installing wireless network
use only System Menu >> Wireless LAN Setup panel.
You can config DHCP (shot/picture 6 ) or Static IP ( shot/picture 7).
Hi black hole team coders,
is there any chance that one day we could find the second tv icon in openwebif,
i mainly bought that vu+duo2 for that specific feature, and now nearly a year that it
is no longer present in latest image.
Do you have any feedback about resolution for this .
thank you
x2....
Is this image reliable Matrix? im not too bothered about having the latest image for duo2 just want something reliable, i know its difficult to have image that is perfect but i cant seem to find any solid reliable images , 2.1.4 was reliable but eppg doesn't work these day, any advice on what image i could try?
What kind of EPG ?
Internet EPG does not depend much of image
but on the servers for EPG.
BH images uses the same Epg sources as well as other images.
for others
Of course OE3 images and transformation from OE2 to OE3
have problems to be solved but it is a price that will bring improvements.
I am having problems installing ******-1.35a in new image. I do everything as I have done in the previous image I install ipk file to temp - go to addons manager - manually install Ipk packages - ******-1.35a is there so I install it - after reboot I press blue button but there is only the 1 cam available (common interface)
Anyone any ideas?
