Black Hole 3.0.1 Vu+ Solo2 OE 3
Per il curl che non si installa su 3.0.1, non si sa ancora niente?!
In che senso scusa?
Sulla mia si è installato ....
root@vusolo4k:~# opkg list | grep curl
curl - 7.42.1-r0 - Command line tool and library for client-side URL transfers  Command line
curl-dbg - 7.42.1-r0 - Command line tool and library for client-side URL transfers - Debugging
curl-dev - 7.42.1-r0 - Command line tool and library for client-side URL transfers - Development
curl-doc - 7.42.1-r0 - Command line tool and library for client-side URL transfers -
curl-staticdev - 7.42.1-r0 - Command line tool and library for client-side URL transfers - Development
curlftpfs - 0.9.2-r1 - curlftpfs version 0.9.2-r1  This is a filesystem client based on the FTP
curlftpfs-dbg - 0.9.2-r1 - curlftpfs version 0.9.2-r1 - Debugging files  This is a filesystem client
curlftpfs-dev - 0.9.2-r1 - curlftpfs version 0.9.2-r1 - Development files  This is a filesystem
curlftpfs-doc - 0.9.2-r1 - curlftpfs version 0.9.2-r1 - Documentation files  This is a filesystem
enigma2-plugin-extensions-curlytx - experimental-git20110215-r13-bh2 - extensions-curlytx  Fetch and display remote text files via HTTP
gstreamer1.0-plugins-bad-curl - 1.4.5-r0 - GStreamer plugin for curl  GStreamer plugin for curl
gstreamer1.0-plugins-bad-curl-dev - 1.4.5-r0 - GStreamer plugin for curl (development files)  GStreamer plugin for curl
libcurl4 - 7.42.1-r0 - Command line tool and library for client-side URL transfers  Command line
root@vusolo4k:~# opkg install curl
Installing curl (7.42.1-r0) on root.
Downloading http://feeds.vuplus-community.net/3.0.1/vusolo4k/armv7ahf-vfp-neon/curl_7.42.1-r0_armv7ahf-vfp-neon.ipk.
Configuring curl.
root@vusolo4k:~# opkg list-installed | grep curl
curl - 7.42.1-r0
grazie per la risposta angeloofsky.
con il 2.1.7 scaricavo il curl da telnet e poi lo installavo upgrade,update,install curl
invece con 3.0.1 non riesco?!
La mia 3.0 mi ha installato curl da telnet senza colpo ferire.
Che messaggio di errore ti viene restituito?
ciao angelo
ecco la risposta da telnet
root@vusolo2:~# opkg upgrade curl
root@vusolo2:~# opkg update curl
Downloading http://feeds.vuplus-community.net/3rd-party-settings/Packages.gz.
wget: bad address 'feeds.vuplus-community.net'
Downloading http://feeds.vuplus-community.net/3.0.1/vusolo2/all/Packages.gz.
Downloading http://feeds.vuplus-community.net/3.0.1/vusolo2/mips32el/Packages.gz.
Downloading http://feeds.vuplus-community.net/3.0.1/vusolo2/vusolo2/Packages.gz.
Collected errors:
* opkg_download: Failed to download http://feeds.vuplus-community.net/3rd-party-settings/Packages.gz, wget returned 1.
* opkg_download: Failed to download http://feeds.vuplus-community.net/3.0.1/vusolo2/all/Packages.gz, wget returned 1.
* opkg_download: Failed to download http://feeds.vuplus-community.net/3.0.1/vusolo2/mips32el/Packages.gz, wget returned 1.
* opkg_download: Failed to download http://feeds.vuplus-community.net/3.0.1/vusolo2/vusolo2/Packages.gz, wget returned 1.
root@vusolo2:~# opkg install curl
Package curl (7.42.1-r0) installed in root is up to date.
root@vusolo2:~#
ciao angelo
Collected errors:
root@vusolo2:~#
Hai problemi di DNS. Verifica che siano configurati correttamente.
effettuato il nuovo aggiornamento e con piacere ho visto che si installava una nuova versione di xbmc.pensavo quindi di aver risolto i problemi sui master.m3u.
grosso errore.con la versione precedente la riproduzione si arrestava dopo 2 minuti ma bastava premere il tasto ok per ripartire(come se fosse stata messa in pausa) ora con quello che credo nuova versione del mediaplayer la riproduzione si arresta di botto buttandoti fuori dal plugin e facendo ripartire tutto da zero sia con rai on demand che con fluzz player sia guardando i canali in diretta sia guardandoli in repèlay
Buon giorno ho scaricato l'aggiornamento della BH 3.0.1.E installato 41 pacchetti , ma al riavvio mi da schermata verde con error al media player ed alla lingua Italiana ho provato a staccare Hardisk ma non ho risolto qualche soluzione in merito !!!!!! Grazie
media/hdd trovi il crash
il file lingua italiana è stao aggiornato con i pacchetti di 10 gg. fa ...
e NON con questi ultimi.
Allega il crash che vediamo se si riesce a leggere di che si tratta.
<?xml version="1.0" encoding="utf-8"?>
<opendreambox>
<enigma2>
<crashdate>Thu Jan 1 01:03:41 1970</crashdate>
<compiledate>Dec 19 2015</compiledate>
<contactemail>crashlog</contactemail>
<skin>Default Skin</skin>
<sourcedate>2015-12-09</sourcedate>
<branch>master</branch>
<rev>2.1.4-109-gdce5ade</rev>
<version>3.0.0</version>
</enigma2>
<image>
<kernelcmdline>ubiroot rootflags=sync bmem=192M@64M bmem=256M@512M ubi.mtd=rootfs rootfstype=ubifs root=ubi0:rootfs</kernelcmdline>
<imageversion>
<![CDATA[
version=1000201511241351
</imageversion>
<imageissue>
<![CDATA[
BlackHole 3.0.1 %h
</imageissue>
</image>
<software>
<enigma2software>
<![CDATA[
enigma2 - experimental-git20121128-r130-bh23-bsp5
enigma2-defaultservices - 1.0-r8
enigma2-meta - experimental-git20121128-r130-bh23-bsp5
enigma2-plugin-cams-*****-ymodv18-56 - blackhole
enigma2-plugin-extensions-addstreamurl - 2.0+git4+99b945b-r0
enigma2-plugin-extensions-cccaminfo - svn-2940-r0
enigma2-plugin-extensions-cutlisteditor - experimental-git20121128-r130-bh23-bsp5
enigma2-plugin-extensions-dlnabrowser - experimental-git20121128-r130-bh23-bsp5
enigma2-plugin-extensions-dlnaserver - experimental-git20121128-r130-bh23-bsp5
enigma2-plugin-extensions-graphmultiepg - experimental-git20121128-r130-bh23-bsp5
enigma2-plugin-extensions-hbbtv - experimental-git20121128-r130-bh22-bsp5
enigma2-plugin-extensions-iptvplayer - 84.08.00.00
enigma2-plugin-extensions-mediaplayer - experimental-git20121128-r130-bh22-bsp5
enigma2-plugin-extensions-mediascanner - experimental-git20121128-r130-bh23-bsp5
enigma2-plugin-extensions-ngsetting - 1.2
enigma2-plugin-extensions-openmultiboot - 1.1+git6+6e6d9ec-r9
enigma2-plugin-extensions-openwebif - 1+git1319+3131639-r1
enigma2-plugin-extensions-oscamstatusview - 0.7rc1
enigma2-plugin-extensions-pictureplayer - experimental-git20121128-r130-bh23-bsp5
enigma2-plugin-extensions-remotestreamconvert - 2.0+git22+6f45040-r0
enigma2-plugin-extensions-satipclient - experimental-git20121128-r130-bh23-bsp5
enigma2-plugin-extensions-streamtv - experimental-git20121128-r130-bh23-bsp5
enigma2-plugin-extensions-xbmc - 1.0-20150506.0_beta_r0-bh3
enigma2-plugin-systemplugins-animationsetup - experimental-git20121128-r130-bh23-bsp5
enigma2-plugin-systemplugins-audioeffect - experimental-git20121128-r130-bh23-bsp5
enigma2-plugin-systemplugins-autoresolution - experimental-git20110215-r13-bh2
enigma2-plugin-systemplugins-autoshutdown - 0.3+git11+406e54c-r2
enigma2-plugin-systemplugins-blindscan - experimental-git20121128-r130-bh23-bsp5
enigma2-plugin-systemplugins-commoninterfaceassignment - experimental-git20121128-r130-bh23-bsp5
enigma2-plugin-systemplugins-crossepg - 0.8.1+gitr423+7cff40b-r2-bh2
enigma2-plugin-systemplugins-firmwareupgrade - experimental-git20121128-r130-bh23-bsp5
enigma2-plugin-systemplugins-hdmicec - experimental-git20121128-r130-bh23-bsp5
enigma2-plugin-systemplugins-hotplug - experimental-git20121128-r130-bh23-bsp5
enigma2-plugin-systemplugins-manualfancontrol - experimental-git20121128-r130-bh23-bsp5
enigma2-plugin-systemplugins-netdrive - experimental-git20121128-r130-bh23-bsp5
enigma2-plugin-systemplugins-networkbrowser - experimental-git20110215-r13-bh2
enigma2-plugin-systemplugins-networkwizard - experimental-git20121128-r130-bh22-bsp5
enigma2-plugin-systemplugins-positionersetup - experimental-git20121128-r130-bh23-bsp5
enigma2-plugin-systemplugins-remotecontrolcode - experimental-git20121128-r130-bh23-bsp5
enigma2-plugin-systemplugins-satfinder - experimental-git20121128-r130-bh23-bsp5
enigma2-plugin-systemplugins-skinselector - experimental-git20121128-r130-bh23-bsp5
enigma2-plugin-systemplugins-softwaremanager - experimental-git20121128-r130-bh23-bsp5
enigma2-plugin-systemplugins-transcodingsetup - experimental-git20121128-r130-bh22-bsp5
enigma2-plugin-systemplugins-uipositionsetup - experimental-git20121128-r130-bh23-bsp5
enigma2-plugin-systemplugins-videoenhancement - experimental-git20121128-r130-bh22-bsp5
enigma2-plugin-systemplugins-videomode - experimental-git20121128-r130-bh23-bsp5
enigma2-plugin-systemplugins-videotune - experimental-git20121128-r130-bh23-bsp5
enigma2-plugin-systemplugins-wirelessaccesspoint - experimental-git20121128-r130-bh23-bsp5
enigma2-plugin-systemplugins-wirelesslansetup - experimental-git20121128-r130-bh23-bsp5
enigma2-plugin-systemplugins-zappingmodeselection - experimental-git20121128-r130-bh23-bsp5
enigma2-plugins-meta - experimental-git20110215-r13-bh2
enigma2-skins-bhdreamym - 1.1
enigma2-streamproxy - 1.0+git15+37a3f19-r5
enigma2-transtreamproxy - 0.1+git38+7675a1e-r11
packagegroup-vuplus-enigma2 - 1.0-r10-bh8
</enigma2software>
<dreamboxsoftware>
<![CDATA[
libdreamdvd0 - 0.9+git91+ee7b0b4-r0
</dreamboxsoftware>
<gstreamersoftware>
<![CDATA[
gstreamer1.0 - 1.4.5-r0
gstreamer1.0-libav - 1.4.5-r0
gstreamer1.0-plugin-dvbmediasink - 1.0+git63+e839734-r5
gstreamer1.0-plugin-subsink - 1.0+git6+d239267-r0-bh0
gstreamer1.0-plugins-bad - 1.4.5-r0
gstreamer1.0-plugins-bad-faad - 1.4.5-r0
gstreamer1.0-plugins-bad-fragmented - 1.4.5-r0
gstreamer1.0-plugins-bad-mms - 1.4.5-r0
gstreamer1.0-plugins-bad-mpegpsdemux - 1.4.5-r0
gstreamer1.0-plugins-bad-mpegtsdemux - 1.4.5-r0
gstreamer1.0-plugins-bad-rtmp - 1.4.5-r0
gstreamer1.0-plugins-bad-videoparsersbad - 1.4.5-r0
gstreamer1.0-plugins-base - 1.4.5-r0
gstreamer1.0-plugins-base-alsa - 1.4.5-r0
gstreamer1.0-plugins-base-app - 1.4.5-r0
gstreamer1.0-plugins-base-audioconvert - 1.4.5-r0
gstreamer1.0-plugins-base-audioresample - 1.4.5-r0
gstreamer1.0-plugins-base-ogg - 1.4.5-r0
gstreamer1.0-plugins-base-playback - 1.4.5-r0
gstreamer1.0-plugins-base-subparse - 1.4.5-r0
gstreamer1.0-plugins-base-typefindfunctions - 1.4.5-r0
gstreamer1.0-plugins-base-vorbis - 1.4.5-r0
gstreamer1.0-plugins-good - 1.4.5-r0
gstreamer1.0-plugins-good-apetag - 1.4.5-r0
gstreamer1.0-plugins-good-audioparsers - 1.4.5-r0
gstreamer1.0-plugins-good-autodetect - 1.4.5-r0
gstreamer1.0-plugins-good-avi - 1.4.5-r0
gstreamer1.0-plugins-good-flac - 1.4.5-r0
gstreamer1.0-plugins-good-flv - 1.4.5-r0
gstreamer1.0-plugins-good-icydemux - 1.4.5-r0
gstreamer1.0-plugins-good-id3demux - 1.4.5-r0
gstreamer1.0-plugins-good-isomp4 - 1.4.5-r0
gstreamer1.0-plugins-good-matroska - 1.4.5-r0
gstreamer1.0-plugins-good-rtp - 1.4.5-r0
gstreamer1.0-plugins-good-rtpmanager - 1.4.5-r0
gstreamer1.0-plugins-good-rtsp - 1.4.5-r0
gstreamer1.0-plugins-good-souphttpsrc - 1.4.5-r0
gstreamer1.0-plugins-good-udp - 1.4.5-r0
gstreamer1.0-plugins-good-wavparse - 1.4.5-r0
gstreamer1.0-plugins-ugly - 1.4.5-r0
gstreamer1.0-plugins-ugly-amrnb - 1.4.5-r0
gstreamer1.0-plugins-ugly-amrwbdec - 1.4.5-r0
gstreamer1.0-plugins-ugly-asf - 1.4.5-r0
gstreamer1.0-plugins-ugly-cdio - 1.4.5-r0
gstreamer1.0-plugins-ugly-dvdsub - 1.4.5-r0
gstreamer1.0-plugins-ugly-mad - 1.4.5-r0
libgstapp-1.0-0 - 1.4.5-r0
libgstaudio-1.0-0 - 1.4.5-r0
libgstcodecparsers-1.0-0 - 1.4.5-r0
libgstmpegts-1.0-0 - 1.4.5-r0
libgstpbutils-1.0-0 - 1.4.5-r0
libgstriff-1.0-0 - 1.4.5-r0
libgstrtp-1.0-0 - 1.4.5-r0
libgstrtsp-1.0-0 - 1.4.5-r0
libgstsdp-1.0-0 - 1.4.5-r0
libgsttag-1.0-0 - 1.4.5-r0
libgsturidownloader-1.0-0 - 1.4.5-r0
libgstvideo-1.0-0 - 1.4.5-r0
</gstreamersoftware>
</software>
<crashlogs>
<enigma2crashlog>
<![CDATA[
uet... /etc/enigma2/userbouquet.vh159.tv
135 entries in Bouquet userbouquet.vh159.tv
resolve: resolve ${sysconfdir}/enigma2/
resolve: -> /etc/enigma2/
loading bouquet... /etc/enigma2/userbouquet.vh160.tv
109 entries in Bouquet userbouquet.vh160.tv
loading bouquet... /etc/enigma2/userbouquet.vh161.tv
55 entries in Bouquet userbouquet.vh161.tv
loading bouquet... /etc/enigma2/userbouquet.vh162.tv
39 entries in Bouquet userbouquet.vh162.tv
loading bouquet... /etc/enigma2/userbouquet.vh163.tv
37 entries in Bouquet userbouquet.vh163.tv
loading bouquet... /etc/enigma2/userbouquet.vh164.tv
23 entries in Bouquet userbouquet.vh164.tv
loading bouquet... /etc/enigma2/userbouquet.vh165.tv
63 entries in Bouquet userbouquet.vh165.tv
loading bouquet... /etc/enigma2/userbouquet.vh166.tv
35 entries in Bouquet userbouquet.vh166.tv
loading bouquet... /etc/enigma2/userbouquet.vh167.tv
39 entries in Bouquet userbouquet.vh167.tv
loading bouquet... /etc/enigma2/userbouquet.vh168.tv
12 entries in Bouquet userbouquet.vh168.tv
loading bouquet... /etc/enigma2/userbouquet.vh169.tv
17 entries in Bouquet userbouquet.vh169.tv
loading bouquet... /etc/enigma2/userbouquet.vh170.tv
47 entries in Bouquet userbouquet.vh170.tv
loading bouquet... /etc/enigma2/userbouquet.vh172.tv
1 entries in Bouquet userbouquet.vh172.tv
loading bouquet... /etc/enigma2/userbouquet.vh173.tv
129 entries in Bouquet userbouquet.vh173.tv
loading bouquet... /etc/enigma2/userbouquet.vh174.tv
117 entries in Bouquet userbouquet.vh174.tv
loading bouquet... /etc/enigma2/userbouquet.vh175.tv
3 entries in Bouquet userbouquet.vh175.tv
loading bouquet... /etc/enigma2/userbouquet.vh176.tv
15 entries in Bouquet userbouquet.vh176.tv
loading bouquet... /etc/enigma2/userbouquet.vh177.tv
1 entries in Bouquet userbouquet.vh177.tv
loading bouquet... /etc/enigma2/userbouquet.vh178.tv
263 entries in Bouquet userbouquet.vh178.tv
loading bouquet... /etc/enigma2/userbouquet.vh179.tv
22 entries in Bouquet userbouquet.vh179.tv
loading bouquet... /etc/enigma2/userbouquet.vh180.tv
1 entries in Bouquet userbouquet.vh180.tv
loading bouquet... /etc/enigma2/userbouquet.vh181.tv
176 entries in Bouquet userbouquet.vh181.tv
loading bouquet... /etc/enigma2/userbouquet.vh182.tv
114 entries in Bouquet userbouquet.vh182.tv
loading bouquet... /etc/enigma2/userbouquet.vh183.tv
55 entries in Bouquet userbouquet.vh183.tv
loading bouquet... /etc/enigma2/userbouquet.vh184.tv
7 entries in Bouquet userbouquet.vh184.tv
loading bouquet... /etc/enigma2/userbouquet.vh185.tv
1 entries in Bouquet userbouquet.vh185.tv
loading bouquet... /etc/enigma2/userbouquet.vh186.tv
32 entries in Bouquet userbouquet.vh186.tv
loading bouquet... /etc/enigma2/userbouquet.vh187.tv
213 entries in Bouquet userbouquet.vh187.tv
loading bouquet... /etc/enigma2/userbouquet.vh188.tv
43 entries in Bouquet userbouquet.vh188.tv
loading bouquet... /etc/enigma2/userbouquet.vh189.tv
36 entries in Bouquet userbouquet.vh189.tv
loading bouquet... /etc/enigma2/userbouquet.vh190.tv
201 entries in Bouquet userbouquet.vh190.tv
loading bouquet... /etc/enigma2/userbouquet.vh191.tv
150 entries in Bouquet userbouquet.vh191.tv
loading bouquet... /etc/enigma2/userbouquet.vh192.tv
1 entries in Bouquet userbouquet.vh192.tv
loading bouquet... /etc/enigma2/userbouquet.vh193.tv
123 entries in Bouquet userbouquet.vh193.tv
loading bouquet... /etc/enigma2/userbouquet.vh194.tv
3 entries in Bouquet userbouquet.vh194.tv
loading bouquet... /etc/enigma2/userbouquet.vh195.tv
91 entries in Bouquet userbouquet.vh195.tv
loading bouquet... /etc/enigma2/userbouquet.vh196.tv
12 entries in Bouquet userbouquet.vh196.tv
loading bouquet... /etc/enigma2/userbouquet.vh197.tv
228 entries in Bouquet userbouquet.vh197.tv
loading bouquet... /etc/enigma2/userbouquet.vh198.tv
15 entries in Bouquet userbouquet.vh198.tv
loading bouquet... /etc/enigma2/userbouquet.vh199.tv
31 entries in Bouquet userbouquet.vh199.tv
loading bouquet... /etc/enigma2/userbouquet.vh200.tv
8 entries in Bouquet userbouquet.vh200.tv
loading bouquet... /etc/enigma2/userbouquet.vh201.tv
63 entries in Bouquet userbouquet.vh201.tv
loading bouquet... /etc/enigma2/userbouquet.vh202.tv
1 entries in Bouquet userbouquet.vh202.tv
loading bouquet... /etc/enigma2/userbouquet.vh203.tv
1 entries in Bouquet userbouquet.vh203.tv
loading bouquet... /etc/enigma2/userbouquet.vh204.tv
74 entries in Bouquet userbouquet.vh204.tv
loading bouquet... /etc/enigma2/userbouquet.vh205.tv
34 entries in Bouquet userbouquet.vh205.tv
loading bouquet... /etc/enigma2/userbouquet.vh206.tv
20 entries in Bouquet userbouquet.vh206.tv
loading bouquet... /etc/enigma2/userbouquet.vh207.tv
1 entries in Bouquet userbouquet.vh207.tv
loading bouquet... /etc/enigma2/userbouquet.vh208.tv
2 entries in Bouquet userbouquet.vh208.tv
loading bouquet... /etc/enigma2/userbouquet.favourites.tv
0 entries in Bouquet userbouquet.favourites.tv
211 entries in Bouquet bouquets.tv
loading bouquet... /etc/enigma2/bouquets.radio
loading bouquet... /etc/enigma2/userbouquet.vh01.radio
54 entries in Bouquet userbouquet.vh01.radio
loading bouquet... /etc/enigma2/userbouquet.vh02.radio
45 entries in Bouquet userbouquet.vh02.radio
loading bouquet... /etc/enigma2/userbouquet.vh03.radio
243 entries in Bouquet userbouquet.vh03.radio
loading bouquet... /etc/enigma2/userbouquet.vh04.radio
184 entries in Bouquet userbouquet.vh04.radio
loading bouquet... /etc/enigma2/userbouquet.vh05.radio
79 entries in Bouquet userbouquet.vh05.radio
loading bouquet... /etc/enigma2/userbouquet.vh06.radio
34 entries in Bouquet userbouquet.vh06.radio
loading bouquet... /etc/enigma2/userbouquet.vh07.radio
103 entries in Bouquet userbouquet.vh07.radio
loading bouquet... /etc/enigma2/userbouquet.vh08.radio
78 entries in Bouquet userbouquet.vh08.radio
loading bouquet... /etc/enigma2/userbouquet.vh09.radio
61 entries in Bouquet userbouquet.vh09.radio
loading bouquet... /etc/enigma2/userbouquet.vh10.radio
13 entries in Bouquet userbouquet.vh10.radio
loading bouquet... /etc/enigma2/userbouquet.vh11.radio
67 entries in Bouquet userbouquet.vh11.radio
loading bouquet... /etc/enigma2/userbouquet.vh12.radio
52 entries in Bouquet userbouquet.vh12.radio
loading bouquet... /etc/enigma2/userbouquet.vh13.radio
197 entries in Bouquet userbouquet.vh13.radio
loading bouquet... /etc/enigma2/userbouquet.vh14.radio
180 entries in Bouquet userbouquet.vh14.radio
loading bouquet... /etc/enigma2/userbouquet.vh15.radio
6 entries in Bouquet userbouquet.vh15.radio
loading bouquet... /etc/enigma2/userbouquet.vh16.radio
40 entries in Bouquet userbouquet.vh16.radio
loading bouquet... /etc/enigma2/userbouquet.vh17.radio
17 entries in Bouquet userbouquet.vh17.radio
loading bouquet... /etc/enigma2/userbouquet.vh18.radio
73 entries in Bouquet userbouquet.vh18.radio
loading bouquet... /etc/enigma2/userbouquet.vh19.radio
8 entries in Bouquet userbouquet.vh19.radio
loading bouquet... /etc/enigma2/userbouquet.vh20.radio
92 entries in Bouquet userbouquet.vh20.radio
loading bouquet... /etc/enigma2/userbouquet.vh21.radio
133 entries in Bouquet userbouquet.vh21.radio
loading bouquet... /etc/enigma2/userbouquet.vh22.radio
75 entries in Bouquet userbouquet.vh22.radio
loading bouquet... /etc/enigma2/userbouquet.vh23.radio
11 entries in Bouquet userbouquet.vh23.radio
loading bouquet... /etc/enigma2/userbouquet.vh24.radio
12 entries in Bouquet userbouquet.vh24.radio
loading bouquet... /etc/enigma2/userbouquet.vh25.radio
32 entries in Bouquet userbouquet.vh25.radio
loading bouquet... /etc/enigma2/userbouquet.vh26.radio
18 entries in Bouquet userbouquet.vh26.radio
loading bouquet... /etc/enigma2/userbouquet.vh27.radio
223 entries in Bouquet userbouquet.vh27.radio
loading bouquet... /etc/enigma2/userbouquet.vh28.radio
43 entries in Bouquet userbouquet.vh28.radio
loading bouquet... /etc/enigma2/userbouquet.vh29.radio
3 entries in Bouquet userbouquet.vh29.radio
loading bouquet... /etc/enigma2/userbouquet.vh30.radio
13 entries in Bouquet userbouquet.vh30.radio
loading bouquet... /etc/enigma2/userbouquet.vh31.radio
12 entries in Bouquet userbouquet.vh31.radio
loading bouquet... /etc/enigma2/userbouquet.vh32.radio
10 entries in Bouquet userbouquet.vh32.radio
loading bouquet... /etc/enigma2/userbouquet.favourites.radio
0 entries in Bouquet userbouquet.favourites.radio
33 entries in Bouquet bouquets.radio
Renumbering...
[eDVBLocalTimeHandler] enable sync local time with transponder time!
add dreampackage scanner plugin
added
[FONT] adding font /usr/share/fonts/nmsbd.ttf...OK (Display)
- double buffering available!
10800kB available for acceleration surfaces.
resolution: 1280 x 720 x 32 (stride: 7680)
[FONT] adding font /usr/share/fonts/nmsbd.ttf...OK (xRegular)
[FONT] adding font /usr/share/fonts/ae_AlMateen.ttf...OK (Replacement)
[FONT] adding font /usr/share/fonts/tuxtxt.ttf...OK (Console)
[FONT] adding font /usr/share/fonts/titles.ttf...OK (titles)
[FONT] adding font /usr/share/enigma2/bDreamy/fonts/verdana.ttf...OK (Regular)
[FONT] adding font /usr/share/enigma2/bDreamy/fonts/verdana.ttf...OK (BigRegular)
[iInputDevices] getInputDevices <ERROR: ioctl(EVIOCGNAME): [Errno 25] Inappropriate ioctl for device >
[iInputDevices] getInputDevices <ERROR: ioctl(EVIOCGNAME): [Errno 21] Is a directory: '/dev/input/by-path' >
Unknown device type: AVerMedia HD Volar (A867)
cannot open /proc/stb/avs/0/input_choices
--> setting scaler_sharpness to: 0000000D
Renumbering...
couldn't open /proc/stb/misc/12V_output
resolve: resolve ${datadir}/enigma2/keymap.xml
resolve: -> /usr/share/enigma2/keymap.xml
[ePopen] command: ip -o addr show dev eth0
setLCDBrightness 25
setLCDBrightness 127
resolve: resolve ${datadir}/keymaps/
resolve: -> /usr/share/keymaps/
Activating keymap: Keyboard English
[ePopen] command: loadkmap < /usr/share/keymaps/eng.kmap
Activating language Italian
language set to it_IT
FIXME: request for unknown slot
[XBMC] Desktop size [1280x720]
main thread is non-idle! display spinner!
Plugin MediaPlayer doesn't have 'Plugin'-call.
PC: 773c324c
00000000 30108700 64958264 64958280
64958264 00000000 00000018 9b6a7d9c
64958264 80349f78 00000004 00000000
cf5f8b84 00000047 00003000 00000027
01355550 00000002 7fd4f5e8 773d92e8
64958280 7fd4f600 7fd4f7c8 00000003
773d92e8 773c3200 00002012 00000000
773e1000 7fd4f5b0 7fd4f660 773ac6e8
</enigma2crashlog>
<pythonMD5sum>
<![CDATA[
ab2eef0ec82f8afbd8e5f6ed5128f02c /usr/lib/enigma2/python/Components/Keyboard.py
0f0d4c2ed60e31e6593abaacc601c87c /usr/lib/enigma2/python/Components/EpgList.py
4b27f5f16806fde8c7e6b0528082319f /usr/lib/enigma2/python/Components/Scanner.py
7be136b6d1eaa13aaa08832390bd53ca /usr/lib/enigma2/python/Components/Ipkg.py
fda2884a50d71cf31c89a54de97be5a2 /usr/lib/enigma2/python/Components/ResourceManager.py
ed446633b70188c44fcd2d4866044bbe /usr/lib/enigma2/python/Components/VideoWindow.py
cbc39aa5935ab3119f74e97329d4fef7 /usr/lib/enigma2/python/Components/SetupDevices.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Components/components.py
4b43daadcd4728b9b688c14c36062240 /usr/lib/enigma2/python/Components/Renderer/Picon.py
c947108f65672842ac96be1bf179690f /usr/lib/enigma2/python/Components/Renderer/Pixmap.py
f43a627a5e8fb9b7a4a5ca67db7bb42a /usr/lib/enigma2/python/Components/Renderer/Progress.py
7dcaf7bebd1b96408b3b13f90a61d512 /usr/lib/enigma2/python/Components/Renderer/PositionGauge.py
aa1249c9a1ce56691a227df891da902b /usr/lib/enigma2/python/Components/Renderer/FrontpanelLed.py
7779d00ec0633251a4b83020ef55551a /usr/lib/enigma2/python/Components/Renderer/Label.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Components/Renderer/__init__.py
1d37518d1e9e86746b3167f8aaed0945 /usr/lib/enigma2/python/Components/Renderer/Renderer.py
6323d455dc129dd91927759a129a8766 /usr/lib/enigma2/python/Components/Renderer/PiconUni.py
6395adaf7ec9bd78244c6f24baf7489f /usr/lib/enigma2/python/Components/Renderer/Listbox.py
fdc2c0963d41b40e55dcbb2bc34caeaa /usr/lib/enigma2/python/Components/Renderer/ChannelNumber.py
83384daaed9da756f7866d192d26b4b2 /usr/lib/enigma2/python/Components/Renderer/Canvas.py
307cbe1c7396024115dbf83e5b77ef53 /usr/lib/enigma2/python/Components/Renderer/Pig.py
ae4183381040270c96baa391d91fb26b /usr/lib/enigma2/python/Components/Renderer/Bhclock.py
7b0aa9b18eb25016e3b5b3f250281731 /usr/lib/enigma2/python/Components/Renderer/FixedLabel.py
80b15609a3888689d42affe5e64fb864 /usr/lib/enigma2/python/Components/Harddisk.py
b1849862a81e9abe67116d8be9abaebf /usr/lib/enigma2/python/Components/AVSwitch.py
b0e458255e15f1a8aec85f6288ef085d /usr/lib/enigma2/python/Components/Button.py
1c4cac0789e596a771af1c7d358f2f84 /usr/lib/enigma2/python/Components/Console.py
4a5d006fa9b187e5008608b1b89bbff0 /usr/lib/enigma2/python/Components/ActionMap.py
c49b29929b4e4162394dc2f7a8c772f8 /usr/lib/enigma2/python/Components/ScrollLabel.py
464c8a0e511dc879697d1a0d9766ef3c /usr/lib/enigma2/python/Components/Pixmap.py
a0ee417c4b6315857b9a2eef5d2b1a0d /usr/lib/enigma2/python/Components/ServiceScan.py
6feeba1843947ec6baaeef017ad68230 /usr/lib/enigma2/python/Components/HTMLComponent.py
1f4cca2ae97c0322cc9e23acfca76276 /usr/lib/enigma2/python/Components/InputDevice.py
5e62e10eb42e7d7a0389834485be420f /usr/lib/enigma2/python/Components/TimerList.py
58fee00295729a2adb7033bf68371de7 /usr/lib/enigma2/python/Components/Converter/ProgressToText.py
da60ed1a4fde0806990486a01bd727e9 /usr/lib/enigma2/python/Components/Converter/ClockToText.py
450c953359065349aac382f76b21fdae /usr/lib/enigma2/python/Components/Converter/Poll.py
c34a0a1a3f90265b36cbf8336ea7b7c1 /usr/lib/enigma2/python/Components/Converter/ConditionalShowHide.py
a6ecc808c0328a437c61eb2ade05bea6 /usr/lib/enigma2/python/Components/Converter/ServiceTime.py
15bea5fc9dbe47aac657be4a34439961 /usr/lib/enigma2/python/Components/Converter/Streaming.py
4078e76e1346d8f2a5e874efd2b904ac /usr/lib/enigma2/python/Components/Converter/RdsInfo.py
38362c2c04914861eb86b7a7d69afa4b /usr/lib/enigma2/python/Components/Converter/ServiceName.py
28dde32d3346086a1ec64dc3ee1627f9 /usr/lib/enigma2/python/Components/Converter/FrontendInfo.py
e90e83fd0a8fc7b634792ecd2a6edbda /usr/lib/enigma2/python/Components/Converter/StaticMultiList.py
17956139931985e8f54cb633cc1af8e4 /usr/lib/enigma2/python/Components/Converter/EventTime.py
87e4bbae4ce58464d0c7ca9319726cd7 /usr/lib/enigma2/python/Components/Converter/MovieInfo.py
ac89bc29566c391499126b1a6f4500f6 /usr/lib/enigma2/python/Components/Converter/EventName.py
3176888cde9c0efeed9ae52282e73dec /usr/lib/enigma2/python/Components/Converter/TemplatedMultiContent.py
87c95b795e765d0651b875064d114541 /usr/lib/enigma2/python/Components/Converter/ServicePosition.py
58b6e06f16433368d76847d3aba80372 /usr/lib/enigma2/python/Components/Converter/ValueToPixmap.py
dc9a4c4fc79c6e128e0179fc30d19895 /usr/lib/enigma2/python/Components/Converter/StringListSelection.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Components/Converter/__init__.py
2c2d157ea7d28a4a43f20b6408ac0394 /usr/lib/enigma2/python/Components/Converter/TunerInfo.py
305a207d38d183ec9a56ae5a5079c068 /usr/lib/enigma2/python/Components/Converter/YWeather.py
2f5e9df85dd9c531dcf62a3aab5ecfe1 /usr/lib/enigma2/python/Components/Converter/Combine.py
5d971edffdd2cd735683bb4c9093ef35 /usr/lib/enigma2/python/Components/Converter/ConfigEntryTest.py
088bd12c66a5fe4c2b87678e274fc13a /usr/lib/enigma2/python/Components/Converter/MenuEntryCompare.py
a7de7fb276c23533cff437f8c978a4af /usr/lib/enigma2/python/Components/Converter/StringList.py
b13c107d6ad058ba60856abcb94cb0c2 /usr/lib/enigma2/python/Components/Converter/BhAnalogic.py
af3845fb48965e926fd51a7439c85ee6 /usr/lib/enigma2/python/Components/Converter/Converter.py
4b8d476929f2c17190baf9d38fa70afc /usr/lib/enigma2/python/Components/Converter/SensorToText.py
eaed56c6a23994929aea79152f256c91 /usr/lib/enigma2/python/Components/Converter/BhRefString.py
6028ba4c8f7d61199ff5b7930089058f /usr/lib/enigma2/python/Components/Converter/HbbtvApplicationInfo.py
73a07616a11fe77a022194d58b0940e7 /usr/lib/enigma2/python/Components/Converter/ValueRange.py
4c78fa5f5bf79d7fffe80a9a568043c0 /usr/lib/enigma2/python/Components/Converter/RemainingToText.py
919b568ec0ddeddd7798d2641e444c9e /usr/lib/enigma2/python/Components/Converter/StaticText.py
42b16b575d76c0e130ff3f007497d354 /usr/lib/enigma2/python/Components/Converter/ValueBitTest.py
12ce3af4bd6cd4a42268832d6863333a /usr/lib/enigma2/python/Components/Converter/ServiceInfo.py
740cfba1ec935bde6fcf238d13cf103c /usr/lib/enigma2/python/Components/TimerSanityCheck.py
8bcf68f46c11af120dcfc5e51ee0e720 /usr/lib/enigma2/python/Components/Playlist.py
630323f4905e84479b1ba21efdc799bd /usr/lib/enigma2/python/Components/PluginComponent.py
6d4f8f7e30285110a59c0e30c62640fd /usr/lib/enigma2/python/Components/PerServiceDisplay.py
c498dfaa263d90bd6f75430b02ab7ee4 /usr/lib/enigma2/python/Components/MenuList.py
0660039b7b6e30b0f2274b222ead3741 /usr/lib/enigma2/python/Components/ConditionalWidget.py
9f0161d7c0504b6ef817767d2bed97d5 /usr/lib/enigma2/python/Components/Label.py
8a0fe43501d2ad168ea15b4b4f147b84 /usr/lib/enigma2/python/Components/ServicePosition.py
649caa4cffbd6098fc301b1e6cc49ade /usr/lib/enigma2/python/Components/Network.py
1bd1c3e110097a9e5e15b7a7ccd225ee /usr/lib/enigma2/python/Components/GUIComponent.py
467c4bfc1494992cceb8003b58b285c8 /usr/lib/enigma2/python/Components/PluginList.py
b0869deccb48eb53982607aef33c3978 /usr/lib/enigma2/python/Components/Gauge.py
0e01a1e3e304e69f8d1b89a8ef22cd31 /usr/lib/enigma2/python/Components/About.py
aef22114ab5ec5233d363994f8c87b6f /usr/lib/enigma2/python/Components/SystemInfo.py
5e205aa70b27dc66758821903f18ef5d /usr/lib/enigma2/python/Components/ServiceList.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Components/__init__.py
24d7a0e6c32db9731a60dd1b5b66ca76 /usr/lib/enigma2/python/Components/TunerInfo.py
4ef56c7d42734f87b3d5c4c3571f1301 /usr/lib/enigma2/python/Components/FileList.py
60b611b79da4d8d1099c344565670575 /usr/lib/enigma2/python/Components/ConfigList.py
ee73da21a06410074bb749968c680955 /usr/lib/enigma2/python/Components/TuneTest.py
5f0b35419c901af9d211dc93b84e55d0 /usr/lib/enigma2/python/Components/HdmiCec.py
4fdc9ae13b1284850d6f4153d44213cf /usr/lib/enigma2/python/Components/ProgressBar.py
3b5dc0f7bf90523b8401499ae1c7aaec /usr/lib/enigma2/python/Components/VariableText.py
4bb6712fcb467e24fbe9f4aec3ca4f0a /usr/lib/enigma2/python/Components/FIFOList.py
a08636829f357ad582d52b123921b7ac /usr/lib/enigma2/python/Components/Lcd.py
293601b503ad89e0ebe9bc8ef85c9dd8 /usr/lib/enigma2/python/Components/MultiContent.py
3b2edd9b322ed121c8f2e88cf76fa11f /usr/lib/enigma2/python/Components/RecordingConfig.py
eaed1748abf9a6eda5113f38bc77031f /usr/lib/enigma2/python/Components/GUISkin.py
4bb39ca2744867c41ff9d4230599e144 /usr/lib/enigma2/python/Components/Input.py
0d707152124791c90b82fbc6e844918d /usr/lib/enigma2/python/Components/HTMLSkin.py
f2da3d8ed048eff55fe51e7401477d52 /usr/lib/enigma2/python/Components/HelpMenuList.py
11000ec9591b9e5a9f5bed4037d2c91f /usr/lib/enigma2/python/Components/VolumeBar.py
fdd79c3bfa2aae2a5d0b6fe8951ce439 /usr/lib/enigma2/python/Components/Sensors.py
c9da57a45f2d4465e16b51dd994bc79e /usr/lib/enigma2/python/Components/DiskInfo.py
2e5c620136817ebddfa7b3331244113b /usr/lib/enigma2/python/Components/Task.py
6907f11457e0a0694f1a3a00a2b40490 /usr/lib/enigma2/python/Components/UsageConfig.py
a0185f66b4b197a347e9b10038323958 /usr/lib/enigma2/python/Components/ParentalControl.py
7d06bd081dd0e10b7019d8ac58708949 /usr/lib/enigma2/python/Components/Element.py
9b323ecd29a78693c3fbd015f1136d4b /usr/lib/enigma2/python/Components/MediaPlayer.py
bc97eb5963b13419cfe4f1d9dc4a7c6f /usr/lib/enigma2/python/Components/DreamInfoHandler.py
455a470bf796884de3cf5886fbbdbdb8 /usr/lib/enigma2/python/Components/FanControl.py
912a9e2628776ccb2e83363fcc9c6e78 /usr/lib/enigma2/python/Components/SelectionList.py
6b97ff9a5291eb296cfcefc28ceaceef /usr/lib/enigma2/python/Components/VariableValue.py
9624c59a9aff6a9bd343386939e8cef2 /usr/lib/enigma2/python/Components/ChoiceList.py
7cce05e920a7a78949e4149a5eae7444 /usr/lib/enigma2/python/Components/MovieList.py
41e413d2ffa48a03fd0547df3b9a948b /usr/lib/enigma2/python/Components/config.py
f2edeec29b502db62369e2283816ead4 /usr/lib/enigma2/python/Components/Sources/Event.py
7c307f1c09f73fbd61de82c2e2544d3d /usr/lib/enigma2/python/Components/Sources/EventInfo.py
b2b638612aa61f66e5c729d969dc96b6 /usr/lib/enigma2/python/Components/Sources/RdsDecoder.py
47312dcaaea9e981b3e22b2363898485 /usr/lib/enigma2/python/Components/Sources/FrontendInfo.py
11bd6ef9d574ab79c97d9f5160cabece /usr/lib/enigma2/python/Components/Sources/CanvasSource.py
c2929a5e2de2d1b3a94e2c38cd7274c5 /usr/lib/enigma2/python/Components/Sources/Progress.py
78c43ab613a6166cf5858eb963ba62bd /usr/lib/enigma2/python/Components/Sources/Config.py
1da1958b336de06b874c9facb97d8e3e /usr/lib/enigma2/python/Components/Sources/ServiceEvent.py
5723d19be11ccbffd48502ade1010767 /usr/lib/enigma2/python/Components/Sources/List.py
6a85468d2ac38a7f37dbc5f73415ca8f /usr/lib/enigma2/python/Components/Sources/ServiceList.py
647e2f65fb79b2fae4a1c2ce5007b656 /usr/lib/enigma2/python/Components/Sources/CurrentService.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Components/Sources/__init__.py
f68dc995f78cfc88e26483ea787746ab /usr/lib/enigma2/python/Components/Sources/TunerInfo.py
8962f4fa89d8ff7fb8097e84ea120158 /usr/lib/enigma2/python/Components/Sources/HbbtvApplication.py
c6f7285e3f449c301dab92d92cfb1fce /usr/lib/enigma2/python/Components/Sources/FrontendStatus.py
ab296b833f2d34f06b5ac2a16c782df3 /usr/lib/enigma2/python/Components/Sources/Source.py
ce001a44e6f7098624a6df98c1c5761b /usr/lib/enigma2/python/Components/Sources/Boolean.py
3059a135ceb0c3fca0867698f21fc2b7 /usr/lib/enigma2/python/Components/Sources/StreamService.py
d421be00754d02d85df804e4faea908f /usr/lib/enigma2/python/Components/Sources/RecordState.py
b8b12180202bc1ca61007fd6b7ec7009 /usr/lib/enigma2/python/Components/Sources/StaticText.py
44460c27e2763fb358898dc34907c140 /usr/lib/enigma2/python/Components/Sources/Clock.py
56c35c1b2af81757e84913b3eb816e6e /usr/lib/enigma2/python/Components/Sources/Sensor.py
db075a06a00091ac91dfdaae6fc66e37 /usr/lib/enigma2/python/Components/language_cache.py
bd6e1b1d7ce8418c98695c1985f3d468 /usr/lib/enigma2/python/Components/ParentalControlList.py
5ca34b71f3b1f9f09d32a4a150498935 /usr/lib/enigma2/python/Components/Timezones.py
dd5333e99f6943d5736c99b8a798c73f /usr/lib/enigma2/python/Components/NimManager.py
62c655bbacc907e84cd14c4dc9972546 /usr/lib/enigma2/python/Components/BlinkingPixmap.py
ae9baee8c742036b23345f88e775a15f /usr/lib/enigma2/python/Components/Slider.py
b2fe45714c4a542dc0aea365aabd3bb1 /usr/lib/enigma2/python/Components/ServiceEventTracker.py
eff3a2b1612845f6e9193f4a89796a7a /usr/lib/enigma2/python/Components/VolumeControl.py
8a566189add219ba26e3204f2eb21164 /usr/lib/enigma2/python/Components/Language.py
2c1bd3117309881fef653c59d6d3b858 /usr/lib/enigma2/python/Components/RFmod.py
f1f6813a4facb45790dd174263513312 /usr/lib/enigma2/python/enigma.py
cfac1258e71864b1ce1e0874fd70d854 /usr/lib/enigma2/python/Screens/LocationBox.py
b5bc1d71a6b661898d46e07c8152d592 /usr/lib/enigma2/python/Screens/Ipkg.py
6b68c3e2070a4cadf05548549a43c785 /usr/lib/enigma2/python/Screens/Globals.py
586378f913a22adf52d797d07007e082 /usr/lib/enigma2/python/Screens/MovieSelection.py
6ca7aaac688af8fd97714fed42b0c771 /usr/lib/enigma2/python/Screens/ChoiceBox.py
697d7162de091ecf6dc24abdd1e2334b /usr/lib/enigma2/python/Screens/VirtualKeyBoard.py
524fa9ce443eae4668e581cb996f7364 /usr/lib/enigma2/python/Screens/Console.py
996c103a8e800a0b466a19a1128a5a1b /usr/lib/enigma2/python/Screens/InfoBarGenerics.py
ca0361953b30f5fc919c4b77abfca0fb /usr/lib/enigma2/python/Screens/TextBox.py
83b202a5fc1de29fc9c5921d5bfeca0e /usr/lib/enigma2/python/Screens/ServiceScan.py
5c836403cce8a029cdec5afa8538eb3c /usr/lib/enigma2/python/Screens/PiPSetup.py
4c7cdc559cb51a0281d41d4a3da63592 /usr/lib/enigma2/python/Screens/StartWizard.py
ea2059cb31c2fefd5efde328536ebd89 /usr/lib/enigma2/python/Screens/AudioSelection.py
262b973b6346f1669ad83e2c67400a09 /usr/lib/enigma2/python/Screens/PVRState.py
3c44a1bb0a6687a3e8c4decd65b9fa43 /usr/lib/enigma2/python/Screens/MinuteInput.py
21b0cca3002cf88fa8868bce113ab96c /usr/lib/enigma2/python/Screens/SessionGlobals.py
e7bc2feca9f12a9169bc74c79d034e65 /usr/lib/enigma2/python/Screens/TimerSelection.py
616e4f5f8d67699c3564ac495ea4e091 /usr/lib/enigma2/python/Screens/ClockDisplay.py
3d02e244781570049d5813d9f5178542 /usr/lib/enigma2/python/Screens/Ci.py
00e41ec48fdea2fc1ec7ff36fb80fbf9 /usr/lib/enigma2/python/Screens/PluginBrowser.py
2fbb9c8d85a3144ac01a5d09e5219a6e /usr/lib/enigma2/python/Screens/TutorialWizard.py
fafa8e1cdfb5c7994ec52f7a627e58bd /usr/lib/enigma2/python/Screens/HelpMenu.py
1d812b4508da64c54eaf3aafe30eb1c5 /usr/lib/enigma2/python/Screens/Rc.py
b0b2b95a755c5d9d15975fe028821f3e /usr/lib/enigma2/python/Screens/EventView.py
2348eb5cf08ee69a16de2f1815d3618b /usr/lib/enigma2/python/Screens/About.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Screens/__init__.py
74dcf98e11a972d249ce5fd011b97cb8 /usr/lib/enigma2/python/Screens/SimpleSummary.py
15b19e6f30826c97c7fdfe0b35ad71c2 /usr/lib/enigma2/python/Screens/UnhandledKey.py
89e899c61850b93498c2fbf2574db01a /usr/lib/enigma2/python/Screens/Standby.py
d189f053b000b612c630638cca19912c /usr/lib/enigma2/python/Screens/LanguageSelection.py
d501bc67ff36572c521ab3bd01da6cca /usr/lib/enigma2/python/Screens/WizardLanguage.py
9fd6f2768180b538d3f35ce3e8cebcab /usr/lib/enigma2/python/Screens/SubtitleDisplay.py
e5a84350b94e7e7c27dc57fcd00dff1c /usr/lib/enigma2/python/Screens/TimerEntry.py
3fe046757ebdbe062517190b33c226d1 /usr/lib/enigma2/python/Screens/ChannelSelection.py
2026309d4bb26a778822e85541918335 /usr/lib/enigma2/python/Screens/Volume.py
372ed995725f003f56e3f231e0b3636c /usr/lib/enigma2/python/Screens/HarddiskSetup.py
c5c0ac1908fd39967894d1044d32520f /usr/lib/enigma2/python/Screens/RecordPaths.py
796833f63a98ce6cb2284242c8a23689 /usr/lib/enigma2/python/Screens/Subtitles.py
2c371a88055a052e82401b97646771e5 /usr/lib/enigma2/python/Screens/Mute.py
5c715725c78fb2a0f4133663291994c9 /usr/lib/enigma2/python/Screens/Wizard.py
910794de58e03cb7a9e68b5b15900fd5 /usr/lib/enigma2/python/Screens/InputBox.py
bccc795a82aab24bd114c264706fedeb /usr/lib/enigma2/python/Screens/TaskView.py
494d95e3c66df7ead1bf1adb38f7d2b1 /usr/lib/enigma2/python/Screens/Scart.py
f09c91475b4d47bac3112605a1d520e1 /usr/lib/enigma2/python/Screens/InputDeviceSetup.py
feb6b7a31bb9716fd322cec27a4166cb /usr/lib/enigma2/python/Screens/MessageBox.py
e59f49df2e8ff48a45fc865e24e63308 /usr/lib/enigma2/python/Screens/PictureInPicture.py
a470453fae4245fc4905c768066384ae /usr/lib/enigma2/python/Screens/Screen.py
211f268cfa597d7eb6b1f17891224bcd /usr/lib/enigma2/python/Screens/SubservicesQuickzap.py
1caf3058700bdc87bc00c54f2a85eceb /usr/lib/enigma2/python/Screens/NumericalTextInputHelpDialog.py
6b8536bae8bf29fc9bc49c5ada69389d /usr/lib/enigma2/python/Screens/Menu.py
a1887da61746d8c7b190c1f9a6f79a5e /usr/lib/enigma2/python/Screens/Dish.py
f49c2918da9b1870bac153faa8717f91 /usr/lib/enigma2/python/Screens/TimeDateInput.py
a6c418ca660943e42fa2b2c72b8c2f7e /usr/lib/enigma2/python/Screens/FactoryReset.py
ea3df01e230dfb0e76fe1f6b8755b247 /usr/lib/enigma2/python/Screens/TimerEdit.py
d8ab85121817e311e336d530942f4e0c /usr/lib/enigma2/python/Screens/FixedMenu.py
30ace57c455e7f9755a5d1738671ba62 /usr/lib/enigma2/python/Screens/ConfigMenu.py
d0f876e8eb9172806e98e8bb849aadb2 /usr/lib/enigma2/python/Screens/SleepTimerEdit.py
4b4246ba0ca9bf6b3f9ea8cf788dc7aa /usr/lib/enigma2/python/Screens/ServiceStopScreen.py
8b057db8457ecf581ca6d028bafdc9e4 /usr/lib/enigma2/python/Screens/Setup.py
5c995a40de39886c79d9fe3c3d45d7f7 /usr/lib/enigma2/python/Screens/RdsDisplay.py
bed413fe393934eb983fa308f27ae712 /usr/lib/enigma2/python/Screens/ScanSetup.py
2690da67e19ff3dc9c5bf2e9674c3353 /usr/lib/enigma2/python/Screens/ParentalControlSetup.py
4cf34751a5b205bb18e44f4eef40350d /usr/lib/enigma2/python/Screens/Satconfig.py
a45a8111127038c94fe76acdcdf0cf3e /usr/lib/enigma2/python/Screens/ServiceInfo.py
42b427e6a8d1780a031949c731b16255 /usr/lib/enigma2/python/Screens/InfoBar.py
202a551180e1dfdcf4e7ae135d8de685 /usr/lib/enigma2/python/Screens/EpgSelection.py
32afe8c8ca5e3bb865af86a296951d12 /usr/lib/enigma2/python/Screens/DefaultWizard.py
0f567032df96cb79a9e7443cfb896682 /usr/lib/enigma2/python/Screens/NetworkSetup.py
1c0cc241a9d4237f9ee663fe101eb379 /usr/lib/enigma2/python/skin.py
0b4897696936a4c0799525c7f1e73166 /usr/lib/enigma2/python/timer.py
5aa4cd0daae7d5ca56895527b5ef10c9 /usr/lib/enigma2/python/ServiceReference.py
27d752afe9f1f12d9732f09b6122ce3b /usr/lib/enigma2/python/mytest.py
c8cb7ffe121f512968813014bcabf0cd /usr/lib/enigma2/python/e2reactor.py
0ff6b1d31b6b25a6b7745658f179b22f /usr/lib/enigma2/python/RecordTimer.py
bda1854fa7c66bbf581db1ec7d60b04c /usr/lib/enigma2/python/Tools/Transponder.py
dbbb881f6c856e4cab017f518ba4a68a /usr/lib/enigma2/python/Tools/CList.py
8c8b3e4062f8e5e9c72cceac90320a2f /usr/lib/enigma2/python/Tools/Profile.py
fec44e3c680135b636adcbc71044cab4 /usr/lib/enigma2/python/Tools/Event.py
2bb2eab34660b5fcdf0b30f9bd1e8f44 /usr/lib/enigma2/python/Tools/Notifications.py
a0639de72e3006e1001f4bf549017bb9 /usr/lib/enigma2/python/Tools/Directories.py
fc8e1e93a7429fba50acb0261f7f5268 /usr/lib/enigma2/python/Tools/RedirectOutput.py
5e58ee8495c6b18b588e7c5b6069fa4c /usr/lib/enigma2/python/Tools/Downloader.py
cbe6d03d0dd9d165c8ec776c5c9adcce /usr/lib/enigma2/python/Tools/ASCIItranslit.py
a2218e726395499f00c72c393da3ba2c /usr/lib/enigma2/python/Tools/LoadPixmap.py
e3356c99fc63880d7cbe4495a03adb68 /usr/lib/enigma2/python/Tools/__init__.py
d9d83467815003e745113b9a16a1473d /usr/lib/enigma2/python/Tools/DreamboxHardware.py
b3422d679770a129342e52f6ca2978ad /usr/lib/enigma2/python/Tools/NumericalTextInput.py
a428aeab8edfef7d2dc4025084898ac4 /usr/lib/enigma2/python/Tools/HardwareInfo.py
0f292c2f68d9da26d688abc4f4f3a10d /usr/lib/enigma2/python/Tools/Alternatives.py
b4011bd490319162c0bb7ab1fe0816f9 /usr/lib/enigma2/python/Tools/BoundFunction.py
c542bb10e8db238b1bd7cf3e2ca06aa9 /usr/lib/enigma2/python/Tools/XMLTools.py
27e29d713faf67c3a1ea3feb0018841e /usr/lib/enigma2/python/Tools/KeyBindings.py
b59a24f3c4925c36ab2b5c20a47d70cd /usr/lib/enigma2/python/Tools/ISO639.py
09af65390e201fdc839573e5a5bc43f6 /usr/lib/enigma2/python/Tools/FuzzyDate.py
d364549956b3cfabe13d9b6b561232df /usr/lib/enigma2/python/Tools/Import.py
4dfeff5bd95f61c49ef403cdceb1fb68 /usr/lib/enigma2/python/Navigation.py
46cf5439c0702ae3d52adf1e0df028af /usr/lib/enigma2/python/NavigationInstance.py
2847ae9cd6ce7ef306501d30d1b675d3 /usr/lib/enigma2/python/SleepTimer.py
9ff38d1fbf23999885065144d273019f /usr/lib/enigma2/python/keyids.py
41d347a6305f5523347e1d4e7b5e9989 /usr/lib/enigma2/python/GlobalActions.py
3ca804f1c54bd4faaa654ebbe1c07795 /usr/lib/enigma2/python/keymapparser.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/DemoPlugins/__init__.py
2d87993fb574529065eccca11b63d743 /usr/lib/enigma2/python/Plugins/Plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/__init__.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/DLNABrowser/__init__.py
c8ef66b79e32aa1abdfd1d1034b4e6fd /usr/lib/enigma2/python/Plugins/Extensions/DLNABrowser/plugin.py
944ad0baa783245f100c3f33c50785be /usr/lib/enigma2/python/Plugins/Extensions/XBMC/pipc.py
9f9107e9d0ddc7efd0a6699c9951340b /usr/lib/enigma2/python/Plugins/Extensions/XBMC/__init__.py
c91932d70a5688014ae2407f1eca9419 /usr/lib/enigma2/python/Plugins/Extensions/XBMC/plugin.py
683b48ca286432ef10ffe6bd129151de /usr/lib/enigma2/python/Plugins/Extensions/XBMC/plogger.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/CutListEditor/__init__.py
150f218b4461c255a04f694ad68dc75a /usr/lib/enigma2/python/Plugins/Extensions/CutListEditor/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/Altadefinizione/__init__.py
65c82095c9fab1955e46e00525289730 /usr/lib/enigma2/python/Plugins/Extensions/Altadefinizione/Moduli/imports.py
79779398381d862a8751e7d81b5ed67e /usr/lib/enigma2/python/Plugins/Extensions/Altadefinizione/Moduli/Moduli.py
62ca2d876952ba456719cb66068af7f6 /usr/lib/enigma2/python/Plugins/Extensions/Altadefinizione/Moduli/MultiFormato.py
67edb82f64f87698b886b95fe890c662 /usr/lib/enigma2/python/Plugins/Extensions/Altadefinizione/Moduli/packer.py
c5ee4ef9f253a546855b290c63163dba /usr/lib/enigma2/python/Plugins/Extensions/Altadefinizione/Moduli/Parse.py
3936df30237d217fafe9dc3f027896bf /usr/lib/enigma2/python/Plugins/Extensions/Altadefinizione/Moduli/ListParse.py
14634d8af8f955c4acaf3ab48c15d87a /usr/lib/enigma2/python/Plugins/Extensions/Altadefinizione/Moduli/MenuList.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/Altadefinizione/Moduli/__init__.py
037722146a3b2d6c80861db0e4a791b9 /usr/lib/enigma2/python/Plugins/Extensions/Altadefinizione/Moduli/Unpak.py
9e8d9160cb757e23d548623e6bc61950 /usr/lib/enigma2/python/Plugins/Extensions/Altadefinizione/Moduli/Player.py
d2c8960f9cb7a50d3b0a847f9ef74596 /usr/lib/enigma2/python/Plugins/Extensions/Altadefinizione/Moduli/BarPlay.py
1c87137934439f02ef7cafe1bd82e668 /usr/lib/enigma2/python/Plugins/Extensions/Altadefinizione/Moduli/Setup.py
2ccbe1858de3c05519bdd51c327e9efd /usr/lib/enigma2/python/Plugins/Extensions/Altadefinizione/plugin.py
11c98dfc050b677530b33c0c0f345354 /usr/lib/enigma2/python/Plugins/Extensions/IPTVPlayer/iptvdm/pwget.py
e2458f2c0f0f052194748dcb6b55eba8 /usr/lib/enigma2/python/Plugins/Extensions/IPTVPlayer/iptvdm/reporthostcrash.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/MediaScanner/__init__.py
2ae0e1640ea4267540f2922afab4eb5b /usr/lib/enigma2/python/Plugins/Extensions/MediaScanner/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/BhFullBackup/__init__.py
12dd9033895bbf2329cc437cc4eb86bc /usr/lib/enigma2/python/Plugins/Extensions/HbbTV/__init__.py
96f23745fca5bea86ae8b42794f29ee8 /usr/lib/enigma2/python/Plugins/Extensions/HbbTV/vbcfg.py
db371b0d5b3d25d44ab7842395b9d8fa /usr/lib/enigma2/python/Plugins/Extensions/HbbTV/aitreader.py
ad7d1b0d844ed90e83bc6ddbf332bcda /usr/lib/enigma2/python/Plugins/Extensions/HbbTV/browser.py
d412c26ac3056b44160964ec25dac7df /usr/lib/enigma2/python/Plugins/Extensions/HbbTV/hbbtv.py
e48c059c6c8075908c788d7842d857a9 /usr/lib/enigma2/python/Plugins/Extensions/HbbTV/youtube.py
b9a4c14628b98c7e73faf8cc5d996c2e /usr/lib/enigma2/python/Plugins/Extensions/HbbTV/plugin.py
be7d58aee08e87f45f827ad2c7d78de3 /usr/lib/enigma2/python/Plugins/Extensions/HbbTV/vbipc.py
cc9b1ef6b60a5dd02a2a280784ad11d6 /usr/lib/enigma2/python/Plugins/Extensions/HbbTV/bookmark.py
d784fa8b6d98d27699781bd9a7cf19f0 /usr/lib/enigma2/python/Plugins/Extensions/SatipClient/__init__.py
360fa49bfd3d8517529ecfff44ba7347 /usr/lib/enigma2/python/Plugins/Extensions/SatipClient/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/StreamTV/__init__.py
325cbbddf515e2c0b07eb8773a19d9f8 /usr/lib/enigma2/python/Plugins/Extensions/StreamTV/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/AddStreamUrl/__init__.py
d1e9446c69b2747c127cf37efe03cf7b /usr/lib/enigma2/python/Plugins/Extensions/AddStreamUrl/plugin.py
d784fa8b6d98d27699781bd9a7cf19f0 /usr/lib/enigma2/python/Plugins/Extensions/MediaPlayer/__init__.py
7bf99b4b797254f0536fbd08fef66f6f /usr/lib/enigma2/python/Plugins/Extensions/MediaPlayer/settings.py
dcee59373d6a0ff0f166cbe2e248238b /usr/lib/enigma2/python/Plugins/Extensions/MediaPlayer/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/BhPersonalBackup/__init__.py
de13890a7a87818a991c43ef6146978e /usr/lib/enigma2/python/Plugins/Extensions/GraphMultiEPG/GraphMultiEpg.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/GraphMultiEPG/__init__.py
e495f59341b9d41c810732b50b001dc1 /usr/lib/enigma2/python/Plugins/Extensions/GraphMultiEPG/plugin.py
e3f2b4c944c3506d87e4a2fed889e7ed /usr/lib/enigma2/python/Plugins/Extensions/RemoteChannelStreamConverter/__init__.py
bd5c5ee5a860cd29927ac464bc974356 /usr/lib/enigma2/python/Plugins/Extensions/RemoteChannelStreamConverter/FTPDownloader.py
e47cd7ab03331e4d54a15eac1cc5dbbb /usr/lib/enigma2/python/Plugins/Extensions/RemoteChannelStreamConverter/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/__init__.py
adf495b2a8fb6972ae24bcf9785c3360 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/httpserver.py
ec99af80f1eae414c6fdda2361e9032e /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/stream.py
1ea5e1b1df3e64bf46b8c88c1dce905c /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/AT.py
caaf4889ea3a0ebcad060d41c29b4a22 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/volume.py
f7e9d66dbbf98309dd09705b95f72348 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/owibranding.py
4701f2dbc8cc695f64e7c320443ec22b /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/services.py
10c62cddf1a45d6eb16f0ed30f722ff3 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/stream.py
c97e280db47552107c28b3f7ae749f96 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/audiotrack.py
24cc5871e2fe7114d877a6e82b582c0a /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/control.py
513a9d947f0aaaa2609d29e89dd8c7f6 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/message.py
8be55e5d80c748b250bd8e5379d4237b /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/movies.py
ad612539245c4072638b16288024c1b1 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/servicelist.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/__init__.py
64291e5c09671db69934f6ea236045f1 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/locations.py
cca8be220f8fd882e3315e1eefb364f5 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/info.py
b9415d4fabca92c961e8ebf8761d256c /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/grab.py
e96c2191ea52666e12ceb876be67614e /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/mediaplayer.py
0af930f15ab213aef8ed0927617489e4 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/plugins.py
6252f96167c1625b2a05926bb980454b /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/config.py
a5a7d7c93f5c5a6987ad580b5014f307 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/timers.py
bd1fae049837d70d52bc8334234c07a5 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/ER.py
96a04c6daec7bf74e8c016e3acb7dbbb /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/SR.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/__init__.py
f13f1ab6b280dc0fcb254a9918ddf047 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/file.py
4c09a8846b40ab541f78e4a5685b1684 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/external.py
fa3be9a3de44389d2c6fece3edd2770e /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/removelocation.py
561e93bd3219ebadadedf22e0e9aa797 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/timertogglestatus.py
5e0cd2067c2acc3664a1d726dbaf2d19 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/epgsearchrss.py
208f0c0d5c96980708cadfa4a840e21f /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/movielisthtml.py
2f62765914041f03ee30dc460559d599 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/timerchange.py
86ae12b178a333f0669909a134a96f43 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/mediaplayerfindfile.py
e70059691f9f0afbcd60b2204139bcea /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/getcurrlocation.py
9429b4970ac61404ea039311f937512c /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/tvbrowser.py
a7046a3c220b769479e71ed5b29abf96 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/mediaplayeradd.py
da0bd76034e53deb97c1e666afa55703 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/mediaplayerwrite.py
a4c786db7568a4b5ceb45e646cb1cd89 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/getservices.py
e99255afa855d46bf4741139d3ce89d4 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/timerdelete.py
d4664ac711b8e01826f5578f82a06500 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/getpid.py
1e208f02306fda70f7c20f9f0c7319fd /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/epgnext.py
a6fdd25ffc1c2dd620ea11032c3f448c /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/mediaplayercmd.py
e0ac0d51d627cc53cc4a682a89c8529f /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/messageanswer.py
38f49c322577dd160f3bc4cd40599058 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/epgsearch.py
9fa8ca737ef6f025bd726a4c990d0322 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/parentcontrollist.py
79187d8de2b65abee93e5e87ebed4f34 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/loadepg.py
ef8a0fac3513207fa637592994ba2bec /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/restarttwisted.py
1a08d8125b940c4895bb0ad6d29d6640 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/mediaplayercurrent.py
ca547ba32972aab6c0278b13368a7461 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/movielistm3u.py
3022dab7f891c05d8babab27ac8dfcc0 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/mediaplayerremove.py
d0b39b20125fa8f8412d7a5e5a97852e /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/timerlistwrite.py
eba1eea6c652c7c30c7a42d4d576928f /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/epgservice.py
57c3a1ec6ed68ff6d7afe31c3fd4f584 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/currenttime.py
3b91f78b77223267e542a40283f34ea6 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/getcurrent.py
9c1b845efea0ce2ac1eb4ff401780ff3 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/message.py
bd50f625bb77a4ded4c99435ace21f76 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/gettags.py
8623968eaadff0d0fa43fa352d6a8e72 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/subservices.py
9d54e9a6a196d5ae53db3296a662d9df /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/servicesm3u.py
dc3599a66c9c74f3e250b9e7eee16e88 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/timeradd.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/__init__.py
1e28d8ef07f705cd3838786ee5bbd8d0 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/settings.py
b0cf8d8d25b80273fe620fd02a588b9c /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/mediaplayerlist.py
25e1defb506ec4d78c5dbcea94d2f831 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/moviemove.py
9fca8c2c67392857cd719a2673062d83 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/moviedelete.py
268aabf4c0964d9be6ba9aa6850572f8 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/getallservices.py
410e14db0347d2ee36fa1f2b387ecad2 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/bouquets.py
d86d77239b65e3f41a41c2458ec469ec /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/epgservicenow.py
b7650276f8b63817c6cbdc7aa5ee89ae /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/streamsubservices.py
882fdd6d0cbdb0906b0761ba01b9d00c /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/epgnow.py
bd1f0217e272f31d6dc11921effd4741 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/signal.py
78f7607a1405e3bd4f9e6b237dcb4a79 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/movielist.py
2fce709feb2bf308e7cc00141a03d87c /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/recordnow.py
e1049ec3ca37f33c8a8f60668f99b26d /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/servicelistreload.py
0619e4733ff99c17706fc7d3fbf9daf0 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/movierename.py
491d4737e1cf2b05cf0c29932133c920 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/epgsimilar.py
240ba79e66d0d20194d0fe19c8f69223 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/about.py
ea601ac24c6c4c1b5e56f7fff7dc4c7e /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/deviceinfo.py
dd62eebf943735c30787b5da7dbb9e3a /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/mediaplayerload.py
9d52a86a28408ba44172a33bcdfe8e3b /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/serviceplayable.py
0eca191b9faff9067114c0056a555824 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/pluginlistread.py
e95c26cacc810a95dd4d717868514648 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/epgbouquet.py
139130cd417d46680a37d1cae7e59262 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/timercleanup.py
9fdaed759e9c961bdf58d0ad158f1f7d /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/timeraddbyeventid.py
e0c723cab8fb9c1fcdee88be518ca814 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/movietags.py
1f3e76fcdcc8d8e2fd48c1a7cef9bd41 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/getaudiotracks.py
fe5135ea76ae6f4a6d22028024be2e33 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/vol.py
614c7c44ee9d7891eb59295dbc8e9ced /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/getipv6.py
a3dc870227c2c4117dee29a55bc5c020 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/powerstate.py
cf59afb7339f67508fd4dcc686e6eebb /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/addlocation.py
48e109184e113289c86682adc37434ec /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/saveepg.py
51fd73f11805b481578770d33ef4e9b9 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/movielistrss.py
67bad1e1aed05f52b0255c2199a1d41c /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/getlocations.py
c3e80754d6f34398390f94f1c4d4c2e3 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/servicelistplayable.py
8e8c322382397a527986c29d03109adc /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/epgmulti.py
fe893c1a483cf27317dceff878a5f8e3 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/remotecontrol.py
6dbae87d3146f88026266f3f6cd21616 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/sleeptimer.py
6dd01be022c2722efa67fd6b70e9ee32 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/mediaplayerplay.py
6f26f7767556cc9bb9c7bdf8d8efa041 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/epgnownext.py
f8e39b563a6ad1187b3542e30f4e1ec3 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/timerlist.py
a77724c87aed50e102cc79b94687928c /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/epgservicenext.py
1f48bfa62341a596ce9c52802707511d /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/zap.py
8fddc64a29a5950e2dc894e4daca9718 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/selectaudiotrack.py
51d880f40b19b0212b3304bd3106fe16 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/channels.py
9399c3c260a57e97002cf0e9e713e7e3 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/satellites.py
d09bd608e8fdb1f11bd7f291e6b838e7 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/eventdescription.py
0d39dc673fd36e3c17b010ec708df2ad /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/epgdialog.py
8d44d881b38087e70e045836c6ea94cb /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/workinprogress.py
1c292c8935dfaa9fec9834952f58616e /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/screenshot.py
9d241161f6bc991949c6e60dccf987b0 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/edittimer.py
be64308dc74f3960dbc0d271bcc64ecc /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/event.py
1b4e86b565794ad37fa4ff92a6fb59ba /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/epgr.py
50fe9a0930939ed1920269aa4ba65e9a /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/providers.py
e832fa883f1312bffb2fbf6a0a7dc3e4 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/rebootdialog.py
c94635a9e98007d2427f6cc8a4d32009 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/message.py
518acb09b9560f209bc57d4b20f51a6d /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/movies.py
52c4e4b139bcf24dac24cef3cbf56549 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/radio.py
793f8eacb1ac8268d24d3e5bb4e23556 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/current.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/__init__.py
41c7c245c75271f2a99574208b7d45e7 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/settings.py
e12148c86b20631b6e578b9dc733770f /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/at.py
6c8a10772feca7811e4369cba77dffde /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/bouquets.py
f5f5fcd4e101981a4187eac2ca2769cf /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/multiepg.py
a7c96a4a5c6092e0d785c863c5e1f086 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/tv.py
314293bbdc08274631dce5db457ef502 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/multiepg2.py
b7114d730f7741939e603642893d2f22 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/about.py
55ee6b115e9af0e4be741a7b4bf575c5 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/epgpop.py
9643f296cd115a6fce21ceaf5f805855 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/bqe.py
80a804dcb5bb40a1bc87e5577b8df807 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/renderevtblock.py
1507832305aee02010837519c39d3808 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/powerstate.py
6e2572ca75e0df48752aded22839bc5b /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/config.py
c7976f5a4409c8ab44351509a9b01868 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/boxinfo.py
33f5c07580766d4c5955ec7a006e03d0 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/timers.py
253e40f8f944ccb04fcc88d7f9f717c9 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/index.py
9db9e08e1148e489344cedf7cc9a2883 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/main.py
dafe52daeae64cbc6ccc3f91d52ff9df /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/mobile/channels.py
4ebee2b37b5d44e3158e2d5ee89e63b4 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/mobile/channelzap.py
9de2a8dffe7a4aa9ee8eb4978486f3e9 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/mobile/index.py
ffefcbe327156df16f579dd6b7422a76 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/mobile/screenshot.py
06f11cf553d3079ed24cb1f5db8d0db0 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/mobile/eventview.py
9373d5b9285667f1447b6c00c0c2a28c /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/mobile/control.py
4ce40b33a1d580011d38360925832af6 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/mobile/satfinder.py
ef22a5b0a5bbe1b48e7590020cfc14e4 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/mobile/movies.py
056f46bb69c145eeb2bc245a586a9ac6 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/mobile/timeradded.py
6b99256e82fceb7037b677911c40e4e7 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/mobile/bouquets.py
0d0f82192e653d2ed37126c402a1e5c5 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/mobile/about.py
d1e72107dc426758e3c4be851cfb116c /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/mobile/channelinfo.py
0c9dcb19fcab9c404124ee5ab0bc6814 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/mobile/timerlist.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/__init__.py
32cf285f055f16871a9b1c611ab5c477 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/bouqueteditor/web/getservices.py
88185a4ef28f26ff38a936d758ec542c /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/bouqueteditor/web/getprotectionsettings.py
c6490b1e1e0c584c6c748b5ef8abfccc /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/ajax.py
e49edbc75b3bcd8b94c9ab1d7147ba75 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/ipkg.py
ecbf4fbf65e7dbb6cdcbda0aa9009726 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/BouquetEditor.py
36082b395498b3a7d834f09ae477f9e2 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/api.py
26adffb86769888f24d805b35bc0ddeb /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/mobile.py
21e8dc5b66b8128ed41347e477f6a1f7 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/web.py
9ef5cff7f69a5fa50b74a4c3a8e9462d /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/base.py
3b818dbd521732b5e808113332f358cd /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/transcoding.py
778d9117c1a1f4577c086a362e2014a9 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/wol.py
cb000fb11986d1ee928236e438ae986e /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/BQE.py
48922a9613ae776c0444311106dacd0c /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/root.py
784196d32b5284e434340978b980e2da /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/__init__.py
a968e836df31fea63bb4adcbf12906c9 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/sslcertificate.py
c6e5150d93f6e9c127541ea8e81287c3 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/local.py
86a2d7eab5788d8523bb8346b28a8512 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/backport/__init__.py
0d1aedd2f897f09061ae6bfc78c4b61f /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/backport/OrderedDict.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/BhEpgBackup/__init__.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/__init__.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/WebChilds/External/__init__.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/WebChilds/__init__.py
f66e93ef0623fc4838c3757df3159ebb /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/WebChilds/Toplevel.py
d23e956ce4f1bfd66f297766158e15dc /usr/lib/enigma2/python/Plugins/Extensions/Weather/Search_Id.py
7215ee9c7d9dc229d2921a40e899ec5f /usr/lib/enigma2/python/Plugins/Extensions/Weather/__init__.py
702a7eae4b6149fa18e4e673cb51312f /usr/lib/enigma2/python/Plugins/Extensions/Weather/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/PicturePlayer/__init__.py
9a3dea767136381f50f9c1d440032596 /usr/lib/enigma2/python/Plugins/Extensions/PicturePlayer/plugin.py
2b567aa940f4431bc0ef9f781225287f /usr/lib/enigma2/python/Plugins/Extensions/OpenMultiboot/open-multiboot-branding-helper.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/xhamster/Function/__init__.py
e1ddb1d542e1c8b9d3f20b112b7423c4 /usr/lib/enigma2/python/Plugins/Extensions/xhamster/Function/MainListA.py
a32a5ee244219682e2daa20cb92820b9 /usr/lib/enigma2/python/Plugins/Extensions/xhamster/Function/FindVideo.py
f77c2168b9d492dd1e17ce334ec3d9ad /usr/lib/enigma2/python/Plugins/Extensions/xhamster/Function/PrimoPianoList.py
4650b6df0ae1d8544425eff4874a314a /usr/lib/enigma2/python/Plugins/Extensions/xhamster/Function/MediaScreen.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/xhamster/__init__.py
1663f6f4c6217cfc43d6ae2bc22d5cb6 /usr/lib/enigma2/python/Plugins/Extensions/xhamster/Moduli/Core/AntiCloudFlare.py
48044e2cca3b80f07657fc95f583e7b1 /usr/lib/enigma2/python/Plugins/Extensions/xhamster/Moduli/Core/__init__.py
bb115712cbedd6fa3bb146298a4c0f7b /usr/lib/enigma2/python/Plugins/Extensions/xhamster/Moduli/Core/scrapertools.py
8e72486768a6e601182fbcb053d20167 /usr/lib/enigma2/python/Plugins/Extensions/xhamster/Moduli/imports.py
8cf411a7bf4964d6b9630e9dc0d2444d /usr/lib/enigma2/python/Plugins/Extensions/xhamster/Moduli/Moduli.py
14634d8af8f955c4acaf3ab48c15d87a /usr/lib/enigma2/python/Plugins/Extensions/xhamster/Moduli/MenuList.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/xhamster/Moduli/__init__.py
9e8d9160cb757e23d548623e6bc61950 /usr/lib/enigma2/python/Plugins/Extensions/xhamster/Moduli/Player.py
d2c8960f9cb7a50d3b0a847f9ef74596 /usr/lib/enigma2/python/Plugins/Extensions/xhamster/Moduli/BarPlay.py
b8214fb8dc347547d2ebf597005e8cd5 /usr/lib/enigma2/python/Plugins/Extensions/xhamster/Moduli/Setup.py
be0a0213c6011a1d101145975ba63813 /usr/lib/enigma2/python/Plugins/Extensions/xhamster/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/OSCamStatusView/__init__.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/CCcamInfo/__init__.py
8acce6c43ee32b0d9608cccd7b35d62a /usr/lib/enigma2/python/Plugins/Extensions/CCcamInfo/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/BhFastEpg/__init__.py
8905ca88f7a8379ecb0118ecee9d46b2 /usr/lib/enigma2/python/Plugins/Extensions/BhFastEpg/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/BhWeather/__init__.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/DLNAServer/__init__.py
24e81ac913b5983c0acf0b2e3c537d41 /usr/lib/enigma2/python/Plugins/Extensions/DLNAServer/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/NGsetting/__init__.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/AnimationSetup/__init__.py
01df99479502b3f82b288d27e87774b4 /usr/lib/enigma2/python/Plugins/SystemPlugins/AnimationSetup/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/CommonInterfaceAssignment/__init__.py
fed4a705f0c1d9569302bb55d04c5d59 /usr/lib/enigma2/python/Plugins/SystemPlugins/CommonInterfaceAssignment/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/Satfinder/__init__.py
61f98a769c5ded0c8a64451697891120 /usr/lib/enigma2/python/Plugins/SystemPlugins/Satfinder/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/TransCodingSetup/__init__.py
bc8ff24be494b4bbf21f792a846c4927 /usr/lib/enigma2/python/Plugins/SystemPlugins/TransCodingSetup/plugin.py
dad0227408777290e6c56afc03cf6e12 /usr/lib/enigma2/python/Plugins/SystemPlugins/NetDrive/__init__.py
76d4fc9c9dc116285294f9b79adadbc0 /usr/lib/enigma2/python/Plugins/SystemPlugins/NetDrive/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/FirmwareUpgrade/__init__.py
7ddd093fda61b1b25d19282e3f5b0ea3 /usr/lib/enigma2/python/Plugins/SystemPlugins/FirmwareUpgrade/plugin.py
d784fa8b6d98d27699781bd9a7cf19f0 /usr/lib/enigma2/python/Plugins/SystemPlugins/ZappingModeSelection/__init__.py
34014a1e03557b2ea809a95f8ab2e1f6 /usr/lib/enigma2/python/Plugins/SystemPlugins/ZappingModeSelection/plugin.py
6f1ce94f2a5dc88d14a3ae515727ec1e /usr/lib/enigma2/python/Plugins/SystemPlugins/SoftwareManager/SoftwareTools.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/SoftwareManager/__init__.py
b7c161d59170e825a894dec1d8b8c951 /usr/lib/enigma2/python/Plugins/SystemPlugins/SoftwareManager/ImageWizard.py
da25b111fad50c4bd0e4ad9e244e3837 /usr/lib/enigma2/python/Plugins/SystemPlugins/SoftwareManager/plugin.py
d1e4f463eeb0272a2f86f40c3a77a7aa /usr/lib/enigma2/python/Plugins/SystemPlugins/SoftwareManager/BackupRestore.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/PositionerSetup/__init__.py
1440586470e4335ea4e9838d1c785379 /usr/lib/enigma2/python/Plugins/SystemPlugins/PositionerSetup/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/Blindscan/__init__.py
73f624c3a4471cfaff8f186d87e217aa /usr/lib/enigma2/python/Plugins/SystemPlugins/Blindscan/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/BlackHoleApi/__init__.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/Hotplug/__init__.py
d8f9b54aeb4984c2c49cb649196d3b30 /usr/lib/enigma2/python/Plugins/SystemPlugins/Hotplug/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/__init__.py
1200a4aa4fee8133ba0e92ad2294b8df /usr/lib/enigma2/python/Plugins/SystemPlugins/VideoEnhancement/VideoEnhancement.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/VideoEnhancement/__init__.py
32c8cd91fd3121c63b54ad244bc8fdea /usr/lib/enigma2/python/Plugins/SystemPlugins/VideoEnhancement/plugin.py
9e711050efee4fb877ac961ea365ce7f /usr/lib/enigma2/python/Plugins/SystemPlugins/ManualFancontrol/InstandbyOn.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/ManualFancontrol/__init__.py
62a6e087cbeccb7610d1aaa11aa4701d /usr/lib/enigma2/python/Plugins/SystemPlugins/ManualFancontrol/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/UIPositionSetup/__init__.py
bb663a3aaf5263f588caac6c28b6844e /usr/lib/enigma2/python/Plugins/SystemPlugins/UIPositionSetup/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/NetworkWizard/__init__.py
027bd31cb0ddaaeb9cc6e967ae45403c /usr/lib/enigma2/python/Plugins/SystemPlugins/NetworkWizard/NetworkWizard.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/NetworkWizard/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/WirelessAccessPoint/__init__.py
2b6755e19e20fc3f062799435b8aa325 /usr/lib/enigma2/python/Plugins/SystemPlugins/WirelessAccessPoint/plugin.py
345624ddf9502612303aed3023d9e86d /usr/lib/enigma2/python/Plugins/SystemPlugins/NetworkBrowser/MountEdit.py
a9c118f12d3b3f4f0339c95f7778074e /usr/lib/enigma2/python/Plugins/SystemPlugins/NetworkBrowser/AutoMount.py
6a352b0bfe8173ec89e5ce895b01eb6d /usr/lib/enigma2/python/Plugins/SystemPlugins/NetworkBrowser/MountView.py
286db9f715fa9c074016e0132750128e /usr/lib/enigma2/python/Plugins/SystemPlugins/NetworkBrowser/NetworkBrowser.py
7010636521d6a0183f317e43ace396e2 /usr/lib/enigma2/python/Plugins/SystemPlugins/NetworkBrowser/__init__.py
340b79e10fdf7e759e103704b12fa2a9 /usr/lib/enigma2/python/Plugins/SystemPlugins/NetworkBrowser/MountManager.py
19b45c6ada80382a72629591ba86580a /usr/lib/enigma2/python/Plugins/SystemPlugins/NetworkBrowser/UserDialog.py
da2d19e7d6c97c2f645bd34ce7fa7ff8 /usr/lib/enigma2/python/Plugins/SystemPlugins/NetworkBrowser/plugin.py
2fd13d35fa6df0843208e85cfcf3bef7 /usr/lib/enigma2/python/Plugins/SystemPlugins/NetworkBrowser/UserManager.py
b96ca0dcf09802b54a49653c799cafdd /usr/lib/enigma2/python/Plugins/SystemPlugins/AutoShutDown/__init__.py
ed5d1f3ba620894f6bf7ff9acc46dccf /usr/lib/enigma2/python/Plugins/SystemPlugins/AutoShutDown/plugin.py
9f565e180deab436b5175874ee919ca6 /usr/lib/enigma2/python/Plugins/SystemPlugins/VideoTune/VideoFinetune.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/VideoTune/__init__.py
6307b4f8a6952cfd3532bc8bed7cb817 /usr/lib/enigma2/python/Plugins/SystemPlugins/VideoTune/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/RemoteControlCode/__init__.py
8fe76cf5ebed103471750987128bc9f5 /usr/lib/enigma2/python/Plugins/SystemPlugins/RemoteControlCode/plugin.py
f025dbeed240fdfafb16763bfc93da58 /usr/lib/enigma2/python/Plugins/SystemPlugins/Videomode/VideoHardware.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/Videomode/__init__.py
bb75aa44fc4c2c264890c1987759971b /usr/lib/enigma2/python/Plugins/SystemPlugins/Videomode/plugin.py
557df59d0d09a31064e9b2c68865b9fe /usr/lib/enigma2/python/Plugins/SystemPlugins/Videomode/VideoWizard.py
dad0227408777290e6c56afc03cf6e12 /usr/lib/enigma2/python/Plugins/SystemPlugins/AudioEffect/__init__.py
0905898c9d2b681bde797d42cc60e63f /usr/lib/enigma2/python/Plugins/SystemPlugins/AudioEffect/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/SkinSelector/__init__.py
867018726f190427b7a3e2060dd67396 /usr/lib/enigma2/python/Plugins/SystemPlugins/SkinSelector/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/AutoResolution/__init__.py
b9711f9f6bbc5c63fe41cb89447b7adc /usr/lib/enigma2/python/Plugins/SystemPlugins/AutoResolution/plugin.py
d784fa8b6d98d27699781bd9a7cf19f0 /usr/lib/enigma2/python/Plugins/SystemPlugins/WirelessLanSetup/__init__.py
195ddbb7b2dbb1bdb5a304b19ac74621 /usr/lib/enigma2/python/Plugins/SystemPlugins/WirelessLanSetup/plugin.py
ecaa88f7fa0bf610a5a26cf545dcd3aa /usr/lib/enigma2/python/Plugins/SystemPlugins/HDMICEC/__init__.py
b753599eda3eb9e205b33fa3a52135c2 /usr/lib/enigma2/python/Plugins/SystemPlugins/HDMICEC/plugin.py
943167eb90dc3145e1b9f61dbd098c3b /usr/lib/enigma2/python/tools.py
</pythonMD5sum>
</crashlogs>
</opendreambox>
