Black Hole 3.0.1 Vu+ Uno OE 3
Clean install with all black hole speed up plugins disabled. Still my flash is showing as 99% in use!!!
Why is this happening? I cant install no plugins as it says there is no space and i get green crash screen
A mí se me ha quedado pillado 2 veces al meterle ECM Time (libgcc_s.so.1). Vuelvo a la 2.1.7. Gracias de todas formas.
Thanks for this new realease.
CrossEPGDownload is very long, it seem to repeat download and parse.
Some plugins are not working.
Flash with nothing installed is 96 %
Regards
hello
thanks a lot for all your works
But I have a problem with the last release,
after having flashed there is very little space on flash
is this the end for these models?
I used Universes, in the past. No more.
Try Open Back Hole and use Multiboot. You can have several OS's guests on board and the flash limit is your USB pen memory limit.
Enjoy !
Done ! I have installed thei new relase under Multiboot (Open Bacl Hole in flash) and have lots of memory available yet (the limit is only the USB pen memory limit).
Hauppage WIN TV DTT stick works properly.
Some blocks sometime happen with satellite. Looking forward for future updates.
Good luck
Thanks for this lovely new firmware
Ciao !
