Black Hole 3.0.1 Vu+ Uno OE 3
Everytime I rebbot I cant connect. I need to put DHCP ON AND OFF or change ip address. I keep DHCP off with fixed address. This was not the case with BH 2.1.7
Any solution ?
Any solution ?
The image has been updated.
Install the Black Hole 3.0.1C Vu+ Uno OE 3 and then make an online update, the issue should be fixed.
However you can use a trick.
If you can manage your router you can book a specific IP address for your UNO and leave the DHCP enabled.
only soulution is add primary dns 8.8.8.8 with that it works so its a bug. I have tested this on solo2 and uno both need this addition on DNS or else after reboot its gone again
On my uno opera browser is not working. I see only black screen and menu. Nothing happens when try to hit some url.
