Black Hole 3.0.1 Vu+ Zero OE 3
A little one is an interest!
BH 3.0.1 put up
TS Panel worked well
On-line BH Image Update refreshed from the menu
Box restarted then TS panel already does not want work.....no an error message is attached to the server
BH 3.0.1 put up
Thiard party panels like the one you have working on, here are not welcome or supported.
:-( it trouble if TS Panel will not be a solution
TS Panel is not a solution.
It contains a lot of legal material and a lot of ILLEGAL. Only for these ones the panel is not welcome here.
You can add the content of Panel with your hands, but it's a very little more hard ... you should find the content and put them into your box.
So, no panels with illegal material welcome here.
No more posts about these fucking panels, please.
Thank your for your efforts but I have a problem with this version.
The problem with wifi. The first time works and after few minutes when I try to reach wlan setting message appears wireless lan plugin not installed
and when I back to the previous version everything work good.
I hope I can find a solution.
That's simple.
USE THE CORRECT WLAN CONFIGURATION PLUGIN!
Menu-Setup-System-WirelessLAN Setup
