Black Hole 3.0.1C Vu+ Solo2 OE 3
@angelofsky1980
Can you confirm that Transcoding does not work on 3.0.1 nor 2.1.7?
I do see the plugin under yellow button, but do miss the white button in the web gui.
It works fine up to 2.1.6
opkg_install_cmd: Cannot install package enigma2-plugin-extensions-mytube_experimental-git20150616-r0_all.ipk
It seems there is an update online for this image. After updating my box, i found that you integrated the DNS names into the main configuration of the Wireless; and with that my problem is solve
Thanks for that
Best regards.
Unfortunately, v3.0.1 doesn't work properly with MaxTV Croatia CI+ CAM (Nagra w/ high bitrate support). V2.1.7 also doesn't work.
Enigma restarts every cca 1 minute without any error message in crash log.
V2.1.4 works as it should.
Does anyone know how to fix this or what could cause such behaviour?
Report it to Vu+ (www.vuplus.com).
Sorry to take this up again, but I still miss Transcoding since 2.1.6
Is there any one who have this working on 3.0.1?
Are someone working on this, or can confirm that its a problem?
And BH images, derived DIRECTLY from Vu+ images should work in the same way ......
I don't know, should they? If they should, then I don't understand why they don't in this case.
I can assure you, as I've tried installing both BH v2.1.7 and BH v3.0.1 from scratch many times in the last 24 hrs, that something isn't right.
I've been using BH images since I bought the receiver i. e. since march/2013. so I don't know what I could've possibly done to provoke this issue.
What we currently don't know is if VU+ maybe fixed the issue in that latest firmware (dated dec 08.), so maybe I'll take the time to find that out.
