Black Hole 3.0.1C Vu+ Solo2 OE 3
i install this image 3.0.1 in my solo2 but some channels (acc-he) audio not working .. means this image not support audio (ACC-HE) type plesae help what i do
Black Hole 3.0.1C OE 3​
New drivers 20151128 (vu+ solo4k)
Fixed teletext
Fixed https streaming
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
LICENSE (TERM OF USE)
Have been enjoying version 3 for two weeks. Decided to do a software upgrade as there are ongoing upgrades. Install process ok then ask if I want to restart, yes, rebooted to the black screen BH icon and froze. Waited 15 minutes did an on/off switch but it froze again.
Can,t send log because DCC and VUCC can,t connect. Looks like a new flash and reinstall everything.
after 3 weeks test.. really this is the worst edition of Bh.. momentallly i return to 2.17 hoping fix several problems of transcoding; dtreaming; IPTV... ect
Does not help. You need to go back to 2.1.6 to get transcoding to work.
Strange thing is that none of the moderator here has mention it. No information on what is wrong, nor if some is working on this.
Strange
OP
Please fix this, or at least respond that you know its a problem.
I just installed BH 3.0.1C on Solo2. Did online update to 3.0.1E.
Streaming on port 8001 works perfect.
And also transcoding on port 8002 works perfect. I tried it using OpenWebif and also few apps on my iPhone and iPad.
So if it does not work for you, try to re-install.
As I install new image I always re-flash the VU+ original image first and then install BH image.
Wish you good luck.
One question. In open Black Hole when you press the button next to the menu for the recordings you can see the recordings on Vu hard drive . When you press it again you can choose to see an external hard drive or in my case my Synology NAS. Can this be done also in this version of Black Hole. Thanks in advance.
Anyone knows
Wish you good luck.
So you get the white and blue icon to the right after the channel name?
You there select normal or transcondig?
If not, how do you start the transcondig?
Yes, I have the white and blue icon to the right after the channel name in OpenWebif.
it should be 3 icons at the right first epg icon then streaming icon and last transcoding.Is this how you have it?
help... help... help !!!!! i have clicked on image update.. than my solo2 blocked on starting logo !!!!!
help me please !!!
( but i have telnet and ftp access !!!!!)
thank u
help me please !!!
thank u
I had the same problem. To many packages installed on flash. Need fresh install then upgrade then install packages you need
Sent from my D5803 using Tapatalk
You can install latest bh on your box as usual (loats of guides on here) then check online for updates and do them then install the addons u need after doing that
OH BUT THE PROBLEM MY SOLO2 CANT READ ANY USB DISK !! help please !!
