Black Hole 3.0.2.F Kodi Vu+ Solo2
Hello
With E.0.2F i can't use ***** 2.3 only ***** 1.4
But with ***** 1.4 i can't use the second tuner then i record on the 1er tuner
Do you have a solution for use ***** on the both tuner?
Regard
David
SOLO2 + 1 antenna + BH 3.0.2F Kodi
Black Hole 3.0.2.F Kodi​
What is new ?​
-Update Solo4K Drivers
-Support fast channel change.
-Update chromiumos and youtubetv.
-Update libvugles2 and directfb
vu-new-release302-png.26855
captura-de-ecr%C3%A3-de-2016-04-07-10-14-12-1-png.26854
1-jpg.26848
2-jpg.26849
3-jpg.26850
4-jpg.26851
5-jpg.26852
6-jpg.26853
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
LICENSE (TERM OF USE)
Thanks for the great job, I have question,
I have tried kodi but there is not PVR add-ons and it is impossible to add?!
What is new ?​
1-jpg.26848
2-jpg.26849
3-jpg.26850
4-jpg.26851
5-jpg.26852
6-jpg.26853
Addons
Infobar / OSD
Analog Clock Gui
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
UPnP Client Djmount
Pcsc Panel
Tuner Server
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
When comes a fix to the pcsc panel. It has not byen working since launching of the first 3.0.x img on solo2?
When did you fix screen resolution on Kodi? On last images like VTi 9.0.3, OpenATV 5.3 Kodi 16.1-RC2 work perfect with FHD skin.
Hello,
Thanks for this great job.
This version of blackhole is enigma 3 ? if i make a upgrade by the software on the box i will get this image ? i want to try kodi.
My plugin which is already installed will work with enigma 3 ?
thanks you.
rgds
