Black Hole 3.0.2.F Kodi Vu+ Solo2
THis file Librtmp .so.1 in Blackhole is limited, does not open all IPTV streams, You should consider this file ATTACHED , it way better than this useless file in the image.
GOOD LUCK
does anyone have problem with free ram? after a few days the free ram is less than 50mb and the box starts to lag,i hit a button on the remote and the command execute after 2 seconds, the problem disappear if reboot the box
Free ram? That's a lot of 50mb
no it's not, as I said box lags with low memory and the commands from remote are taking 2 seconds to execute, when I reboot all returns to normal, sometimes doesn't even reboot with low memory and stacks in reboot screen and I have to switch the power switch behind the box
Hello,
I have been using this BH version for a couple days and no issues, but today I tried to use subtitles on Kodi and it was imposible, I tried on Exodus and SALTS, but there is no option to select or download them because the stream goes straight to the Vu+ player and not the normal one for Kodi. Do you have any other ideas or add-ons to have subtitles on Kodi?
Thanks a lot!
Hello,
Thanks a lot!
you have to use media player2 as defoult player in order to de able to download subs
N1 here knows why .nfo files are not read by Kodi on VuPlus Solo 2 Blackhole? I've created some but Kodi don't charge the info in .nfo files... ¿?
Finally I was able to use nfo files! I used XBNE to create it, so now it works!
In auto language selection I can't choice Ukrainian, also I try to edit file "settings" "config.autolanguage.audio_autoselect1=ukr", but it's not help.
