Black Hole 3.0.2.H Kodi Vu+ Duo2
What do you mean , was no point to change the main menu options order ??
Maybe for you..
Update by update, image by image. All main menu options usually stayed the same so far, till now. The new image came out and main menu options are kind of up side down. We used to the old layout of main menu options but now we have to start learning again.
Thank you for the new Update....
I have tried the new skins MX HQ10x & XC, but in the Cool TV Guide I don´t have Full screen in my previous skin (DarkSky) was OK the full Screen
Regards
Install new skin MX HQ10XC or MXHQ10X and tell me if this fix the problem if not 100% than 99%.
Regards
If this plugin is coded in old skins format 1080 x 720
then you can not have a full HD skin format 1920 x 1080
and Full screen.
So the author should code plugin in the new HD format 1920 x 1080
or you can use an old skin in the old format 1080 x 720 to have full screen.
HI
please add " delete option " in main channel of satellite list .
i want delete the old channel in main of sat list but it is impposible in the box .
( i know i must delete from dreamboxEDIT from computer )
thanks
Image update online starting to be on server (from today )
There is an option to delete channel from favourites. But if you want to get rid of old channels displayed in the satellite channel list (not favourite) then there is no other way than scan your satellites and after that the old channels will be replaced by the new ones.
Hello, the new version works kodi? The problem corrected? Just in previous versions kodi not rabotal.film Shoal exactly one minute on and off and so sovsemi playlists
Hi
Thanks for this image.
Could it be possible to inculde Single transport scanner?
Thanks in advance
J.
I updated my Duo2 online and the system menu is not on two rows as was supposed to be.
As there was not comment on this, and the System Menu is still on 1 too long row in the new update 3.0.2I, is it that only me has this problem? Appreciate any reply.
I haven't updated my Duo2 for a long time now (still using v2.17). And i'm wondering if I should install this version or the latest Open Black Hole version. If I update to this version, can I do it without loosing my personal settings, picons (usb partition) etc? Use online or backup? But if I choose updating to Open Black Hole it's not possible right? And the big question, should I install Open Black Hole or this one? Which one is the best? Most stable, userfriendly, compatible etc? Also, I must thank you for all this nice work with VU software.
