Black Hole 3.0.2.H Kodi Vu+ Duo2
Ieri ho provato l immaggine ma mi va in crash con il modulo ci+ di skyde ef il crashlog e vuoto con openatv ed vti non ho problemi. Se riesco stasera provo a fare un log da seriale
Gesendet von meinem Nexus 5X mit Tapatalk
hai impostato le priorità dei canali ?
prova a mettere su questo, mi sembra si trovi in etc/enigma2 previo dezippamento
Ps: il topic tratta altri argomenti, la prossima volta aprine uno ad hoc.
Grazie della attenzione
euxaristo poli
Teşekkür
This does not seem to be English. This is a total mess. Posts should be deleted.
How to enable Mediatomb for tuner server to ps3? I cannot find it anywhere and i use to stream to ps3 and LG tv.
I try also to install mediatomb_0.12.1-r3_mips32el.ipk and r8 but i get error on install and cannot see mediatomb afterwards.
Somebody has a solution for this?
I am sorry if this has already been answered: are there two stream icons next to each channel in WebIF (one for standard and one for transcoded stream)? Thank you.
I seem to recall someone getting this to work, as they wanted to stream to their phone, and they downloaded VU+ Player, to get it working.
I haven't personally tried it.
No vuplus player dont work on duo2 on oe3 only 2.17
But on duo its work and on obh latest
