Black Hole 3.0.3.H Kodi Vu+ Ultimo4K
Ev0
Admin
What is new ?
- [gstreamer1.0-plugin-subsink] fix SRC_URI.
- Support VUPLUS BLE RCU.
- update vuplus-bluetooth-util & bluetoothsetup.
- add new plugin wit.ai speech to text.
- [RcInput] handle key tape. (for VUPLUS BLE RCU)
- update chromiumos to support bt-rcu.
- [webkit-hbbtv] update hbbtv.
- [linux-vuplus] enable usb serial device drivers for ARM receivers.
1-png.28939
2-png.28934
3-jpg.28932
4-jpg.28933
5-jpg.28935
6-jpg.28936
7-jpg.28937
8-jpg.28938
INFO: This Image has the latest drivers but CAN be installed in OpenMultiboot. The image does not need to be installed in flash.
This latest version of the Black Hole series has been updated and improved for maximum stability and performance.
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
This last feature offers the possibility to various forums or communities to create their favorite EPG data files and load them into a web space.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
Thanks to plnick for help obtaining missing Ultimo4K files.
Thanks to Pedro_Newbie for Backup script.
DISCLAIMER
LICENSE (TERM OF USE)
  • BlackHole-3.0.3-vuultimo4k_usb_release_20170327_314dfbf.zip
slovaky22
Hi. I have a question, or it is a problem???
Problem with recording movies, I can not select a file to store recordings
See photos of the difference between the OBH and BH 3.0.3 H.
It's okay to OBH 1.0 we can choose the Location
here in BH 3.0.3 H is not possible to select a Location where it should be stored film.
Thanks for help
Matrix10
Thanks for help
Enable setup mode expert in System Menu >>Customise
Tocas
I have to restart the wlan everytime i boot...?
No problem if I only restart gui.
I have tried with a vu usb wlan - same result...
Can anyone help ?
donquixote
After updating to 3.0.3 H the LCD screen display has become tiny on the top left of the screen.
I can't find any setting to return the display to normal large size across the display.
I can switch it to mini TV and it displays in full screen, it's just the time/channel info that won't display properly. (it displays properly when switching to another image in multiboot, only BH problem)
Anyone know what the issue might be? Thanks.
Tocas
Can anyone help ?
I only have the problem using static ip.. when I am using dhcp I have no problems.
I really hope for an update solving the problem. I also have the Uno, Ultimo and the Duo2 with no problems...
Please help me someone with a Ultimo 4k...
Vuelta91
I have the same connection wifi problem using static ip.
I need restart four o five times the wifi net system in the receiver for I have connection.
wzbbstx
BlackHole-3.0.3-vuultimo4k_usb_release_20170327_314dfbf.zip ???????????
0327???
