Black Hole 3.0.3.H Kodi Vu+ Ultimo4K
since the latest update to N Version, one again problem´s with auto resolution by switshing form 720P channel to 1080i channel, sometimes the screen is just black.
Hola, he instalado la imagen y la zona horaria está desfasada, no coincide con un fallo de unas 6 horas, no se si hay mas personas que tengan el mismo problema, o a lo mejor estoy haciendo algo mal,
Bought Ultimo4k was found fooled, the firmware update is too slow. Kernel version is also very low, no AX 51 box easy to use
This is the international section.
Write only in english language.
You turn off and turn on the vu +
And you press the touch button and wait until you see a countdown that takes out the USB disk and that's it
Hello! I really need a version of the image Black Hole 3.0.3.N. Where can I download this version of the image to update the receiver only by USB ?
Thank you, Mick12334! But I at this time need is version 3.0.3.N. If You have it, please share the link.
I doubt anyone has Black Hole 3.0.3N, as they were probably minor updates, carried out online, using the Black Hole image update option, equally, as it has now been surpassed, by Black Hole 3.0.5, I doubt many people have it on their receiver.
All you can do is load Black Hole 3.0.3H and hope you can still get online updates.
  • Like
Reactions: VVZ
