Black Hole 3.0.5 Vu+ Solo2
Я ьыл рад BH 3.0.5 но после устаговки разочаровался,пробовал два раза,но почему то начинается вечный boot, уважением ко всем-владимир33.
Hello.
Can anyone one guide me how can I install Kodi on this img?
Thank you.
When I start kodi I got the following error:
/usr/bin/kodi: line 180: 3630 Segmentation fault $LIBDIR/${bin_name}/${bin_name}.bin $SAVED_ARGS
What should do?
Thank you.
From the Log I could find:
CActiveAEResampleFFMPEG::Init - create context failed
Is anyone else facing the same problem?
Can anyone help me?
I'm back with more details.
I had a very old BH image on my box, installed years ago, and I decided to upgrade to BH 3.0.5, due the fact that the new image has embedded the KODI application.
So, all I did was back-up the settings (from the BH menu) to the internal HDD, then format the usb drive, copy the new image kit to to usb drive, install it... all clear till this point.
After the new image was installed, I tried the KODI application, and unfortunately it does not start.
I searched for a solution, and I found:
- delete the files from ~/.kodi, then start KODI -> same result (only a black screen is displayed for a little while
- delete the files from /media/hdd/.kodi, then start -> same as above
- insert a new fresh formatted stick USB, and mount it as /media/hdd -> same result, only a black screen for a while
What else should I try?
Because of this error from the kodi.log file , "CActiveAEResampleFFMPEG::Init - create context failed", I realized that the Audio Engine is not configured correctly, so I will try to copy all configuration files to /media/hdd/.kodi folder.
If I get same result, I will try to reinstall the BH 3.0.5, but without the hdd mounted and without restore the back-up settings.
My personal goal was to remove the cause of this problem, not only the effect.
Thank you all.
Have a nice day.
//swimm3r
