Black Hole 3.0.5 Vu+ Solo2
Personally I run Open Black Hole, on my Duo2, because it has the latest version, Kodi 17.6, installed, but you shouldn't be experiencing any problems, with Black Hole.
Please do a fresh installation, of Black Hole, and don't use any backups.
The only thing, you need to back up, is your channel list, and bouquets, using dreamboxedit, or dreamset.
You then install Kodi, in Open Black Hole it's located in Black Hole Speed Up.
Once enabled you just start Kodi from the Plugins menu.
Please post back with the results.
I find myself using Kodi, on my Duo2, more than viewing satellite channels, as you can view what you want, when you want to, and you can find some great classic television series.
Enhanced Movie Center not work
It perfectly works, as it have done for years. If you don't explain your issue, such messages are simply useless. Please explain how did you install and what happens. Have you setup it, after installation?
How can choose from the channel subtitles by the yellow botten? The blue botten only open the audio section !
If I'm not wrong, in BH, from the AUDIO menu you have the Subtitles menu, probably by the red button. But I can't check it now. Or, in some remote controls, you have a specific k_ey for subtitles.
Push 2 times yellow bottom and if there are subtitles, you will report them.
You will then have to choose the one you are interested in.
