Black Hole 3.0.6 Vu+ Ultimo4K
Import error No module named PixmapLcd4Linux.
This is the first plugin that I install afther flashing the image nothing else is installed and directly get green screen.
I installed LCD4Linux V5.0-r3 from BH plugin server and did not have this problem.
Or you did not download the file from the server properly.
Because of the big download problem or something else is not good.
You use backup ??
or you use bad configs ??
I do not know that
Plugin is on Plugin server
green button>>yellow>>addons download manager>>Black Hole Addons plugins>>Lcd4Linux v.5.0-r3
Tryed again and all work fine now, probably it was not download properly like you said.
Hi EVO/MATRIX10
BH addon manager picon is 2/3 yrs old no body updates please someone update the picon
Thank you
what about satfinder
On 3.0.5 I got green screen when i change transponders on satfinder. Is is that things ok on 3.0.6 or need to wait for fix?
I have found a bug in Quad PiP but I am not sure if lack of information caused it.
Parental control doesn't work on Quad PiP and it shows them lock free.
I put the +18 channels in Blacklist
In the Parental Control menu, I set four numbers as a token
I change the status of the channel lock to "YES"
In this case, go to the "Quad PIP" menu and select four +18 channels from the Blacklist
All 4 channels are displayed without lock.
I'm sorry for my weak English :)
Nothing we can do.
Quap PiP is controlled by Vu+, and therefore it bypasses the perental control that we added to the BH image.
