Black Hole 3.0.7 Vu+ Solo4K
ImportError: No module named PixmapLcd4linux
I/O error(2): No such file or directory
cannot load /usr/lib/enigma2/python/Plugins/Extensions/archivCZSK/resources/repositories/xbmc_doplnky/script.module.stream.resolver/resources/settings.xml file I/O error(2): No such file or directory
Addon(dmd-czech common python modules-1.5.2)[language] cannot load languages, missing language directory
[ArchivCZSK] ERROR: ToolsAddon(dmd-czech common python modules-1.5.2)[language] cannot set language en, language is not available
Just some of the bugs in your log
which are created not with BH image but with the plugins and skins you use.
How can we help you now ?
when you disrespect advice.
1.Install clean image from this forum
(make all updates online)
2.Use Black Hole skins from Black Hole image server
3.Install the LCD4Linux plugin from the Black Hole image server.
(before any configuration of LCD 4 Linux)
4.Ask the author of the plugin that does not work for help
But if you want to use external plugins and skins which cause a crash
then do not seek the help from us.
There is no single fatal error in your log,
caused by the image.
Your image log is full of plugins that cause the error
some other
[Errno 17] File exists: '/media/hdd/TURKvodXML'
IMPORT ERROR
** 449 iptv_streamse 448 **
No module named servicewebts
Skin that you use practically occupy image
To understand we are not against external skins that do not cause image problems.
What's happening here.
You use a skin that has dozens of python files
which may be in confrontation with image coding
Skin uses almost more python files than whole Black Hole coding added to VU+ coding.
All g17 py files is from your skin.
/usr/lib/enigma2/python/Components/Converter/g17ServiceNameEvent.py
7996b487a0b302c8164f51f3a3e2b1ae /usr/lib/enigma2/python/Components/Converter/g17ServiceInfo.py
fdebb6c7c063227c461ce173929f621f /usr/lib/enigma2/python/Components/Converter/g17GenerateMenuEntry.py
bec0121f0f75c324b80405f7fa73198c /usr/lib/enigma2/python/Components/Converter/g17ClockToText.py
b45b4118399e61c09430106472fd2157 /usr/lib/enigma2/python/Components/Converter/g17ConditionalShowHide.py
596de910404d4bb0e47a09a53f4d2d97 /usr/lib/enigma2/python/Components/Converter/g17extServiceName.py
cabe020871af37b5258816742293952d /usr/lib/enigma2/python/Components/Converter/g17GenerateMenuEntry2.py
bc5bafcbb64ba94f7853164d8c50eeed /usr/lib/enigma2/python/Components/Converter/g17ServiceNum.py
99497981e54abfb1493fdc1f10a67220 /usr/lib/enigma2/python/Components/Converter/g17EventTime.py
57b47cd0dbca8d1e7fa5cf4d5ea9bdfa /usr/lib/enigma2/python/Components/Converter/g17MiniTVDisplay.py
2f122fb6df17a8ca550c66092cb1036c /usr/lib/enigma2/python/Components/Converter/g17ExtraSource.py
d254050e333ef434ca78b399a0950201 /usr/lib/enigma2/python/Components/Renderer/g17Ahours.py
867b9dcff7a8102b85e7251b26ec870d /usr/lib/enigma2/python/Components/Renderer/g17MiniTV.py
0869e731aa223abfd0da129e6c7c6408 /usr/lib/enigma2/python/Components/Renderer/g17ShowExtEpg.py
d093fc63072198ed05dbb05a44c3c04f /usr/lib/enigma2/python/Components/Renderer/g17RefTV.py
3ef7558aeaac969eeb5cf51751471f04 /usr/lib/enigma2/python/Components/Renderer/g17ShowExtraEpg.py
4ac320dbad4a04261bb0b06ee6618833 /usr/lib/enigma2/python/Components/Renderer/g17RollName.py
903c48aaf038454178de4fb5dcdfd0cc /usr/lib/enigma2/python/Components/Renderer/g17ShowReference.py
cc7c079f7ec269b45fbf1f63cfc116e0 /usr/lib/enigma2/python/Components/Renderer/g17MenuEntry.py
5a3ae40521ac99db0e362c3a065ff897 /usr/lib/enigma2/python/Components/Renderer/g17showDev.py
e87fa6ed2104fc7b2830f1f2ac191473 /usr/lib/enigma2/python/Components/Renderer/g17TunersLabel.py
55e4d9bad787efb154b0c8045ee42a13 /usr/lib/enigma2/python/Components/Renderer/g17PicRef.py
4d27fcb3e51a7c5aa6495d1f2059c92e /usr/lib/enigma2/python/Components/Renderer/g17VolumePixmap.py
6aa4b78f544e7a3ddb86d204e56e0901 /usr/lib/enigma2/python/Components/Renderer/g17MetrixHDRunningText.py
33284eae9e4b2a0a2bc8a255726a2765 /usr/lib/enigma2/python/Components/Renderer/g17RefTV3.py
d472ef9124b9b67935af81a18cca9f15 /usr/lib/enigma2/python/Components/Renderer/g17dateFormat.py
a84058a23e7a4a9273244f9f8bc33875 /usr/lib/enigma2/python/Components/Renderer/g17Progress.py
177e65166fde5c71de21afca38014c3a /usr/lib/enigma2/python/Components/Renderer/g17EmptyEpg.py
f61dfbcbffd7ff0b5321a6a39f7994ea /usr/lib/enigma2/python/Components/Renderer/g17RollerChar.py
0f5119838626525c580e8b834c966128 /usr/lib/enigma2/python/Components/Renderer/g17trpm.py
af59793558bcabe3bd47451aa0ba9304 /usr/lib/enigma2/python/Components/Renderer/g17PicRef2.py
0c95daced8b21863832379ee32814722 /usr/lib/enigma2/python/Components/Renderer/g17Volume.py
667bd31082c1d0ba681fe69a135c7031 /usr/lib/enigma2/python/Components/Renderer/g17VolumeGauge.py
2cbad2ae772f5737ea325f909c7ce74c /usr/lib/enigma2/python/Components/Renderer/g17satTV.py
26564ff3ecee8eb86cd03a50542b3c7f /usr/lib/enigma2/python/Components/Renderer/g17ShowTP.py
2574c277ba8ac5cb1285d06729e44e53 /usr/lib/enigma2/python/Components/Renderer/g17cutCHSS.py
f684a4c19e10059a15a82e588b7b78a2 /usr/lib/enigma2/python/Components/Renderer/g17MenuEntry2.py
1cf98cf3daf4d07f33f6c957de1cb47a /usr/lib/enigma2/python/Components/Renderer/g17provTV.py
c80aead74bc5257580e6f33366ce3883 /usr/lib/enigma2/python/Components/Renderer/g17HDDstate.py
455a470bf796884de3cf5886fbbdbdb8 /usr/lib/enigma2/python/Components/FanControl.py
6b97ff9a5291eb296cfcefc28ceaceef /usr/lib/enigma2/python/Components/VariableValue.py
c61d354f8185a055945581d37e536386 /usr/lib/enigma2/python/Components/g17SelectionList.py
3e0a7244281c3019ee0322a182c8a62b /usr/lib/enigma2/python/Components/g17ConfigList.py
It is no longer a Black Hole image
Hello.
now a clean black hole installation
I repeat clean without any other installation
sending crash log.
the bug is somewhere else and not in plugins.
Hello,
let me share my experience with BH 3.0.7.
I had no problems with time zone and time. Probably because I am using chrony.
Nevertheless, I've experienced a weird problem with recording subsystem, I wasn't able to solve in a timely manner and thus ended up downgrading BH to 3.0.6.
I am using samba network shares for recordings (and others). After an upgrade to BH 3.0.7, my samba server running QNAP 419PII started to saturate its CPU. A deeper view showed that a recording subsystem on my VU+ Solo4k was writing a lot of small files when I put the receiver to standby. What is even weirder that there was no schedule to record anything and files being written resembled a recording that has been already recorded. This way, I ended up with couple of hundred thousand files being written onto a share, saturating CPU and consuming FS space and inodes.
If anyone has experienced a similar issue, and know a workaround/solution, please let me know.
I can install BH 3.0.7 as a dual boot and debug, but would need a hint how what information to take.
Thanks & BR
Pali
un mi me ha pasado lo mismo he instalado LCD4Linux en vu uno4kse y se bloqueo el deco baje el que indica
se quedo con la pantalla verde, lo recupere con una copia de segurid, hay otra forma de instalación, con la imagen 3.0.8 BlacHolo
Gracias
This is international section: PLEASE write in english.
I remember you that you are O.T. because in this TRD we discuss about Solo 4K and not Uno 4K Se.
Many thanks.
