Black Hole 3.0.7 Vu+ Ultimo4K
Hi,
I have the same issue with this version as the one I had with 3.0.6. It concerns Quad PIP.
It doesn't work well eventhough the recording of 4 different channels works great.
However having 4 pictures in the quad PIP is almost impossible.
May be it comes from my configuration wich is a motorised dish with inverto Unicable LNB IDLU-32UL40-UNBOO-OPP but I don't think so since it works well when recording 4 different channels...
Any idea ?
found a bugs on Ultimo 4K signal with dB does not work. can you please to fix it as well. thanks
Is not BUG
dB does not work in VU + coding
so it does not work in Black Hole.
It's been like that for a long time.
You can send email to VU + , the question is whether this has priority for them.
We can not deviate from the VU + coding in BH image, because that would mean a break in the other elements of coding.
Some things you are looking for can only fix VU +
Blind scan , quad Pip ...
Hi,
Any idea ?
I'm not sure there's a problem with QuadPip
I have to test when I'm using Ultimo 4K
Hi,
Any idea ?
The picture in the post for QuadPiP was taken on Ultimo4K with same Unicable LNB as you have
I have also 2 other suggestions :
1- is it possible to update the Samba/Cifs server so as it uses SMB2 rather than SMB1 protocol ? since I updated my PC to windows 10 it becomes not possible to display the hardrive of the VU+ as a drive in Windows explorer. Windows 10 says that my VU+ uses SMB1 which is not a secure protocol...
2- is it possible to implement the following behaviour when displaying the channels list : a first "clic" just change the channel in the preview window but does not close the channel list. A second "clic" on the current selected channel hides the channels list and displays the channel in full screen. This behaviour is the same as the one that is implement in Open Black Hole.
Thanks.
I can not do anything unless you test with either Vu+ image or VTi image and confirm if there is sound or there is no sound with either of those images too.
OK. Done it too. VTi_14-0-0_vuultimo4k_201811291305_usb Channel Festival 4k on 36e working with sound. I hope now enough proofs for developers.
@Overix
The problem is we do not receive this channel.
Did you try to change settings in Auto language selection settings (in System Menu >>Auto language selection settings )
about Ac3 and prefered audio stream service and language.
@Overix
After ur message, now im check it, at this moment i back to BH 3.0.7, but this option do not change anything. BH image still not see audio track list on this channel, and this channel still has no sound.
No. Im also not used backup settings and all firmware installs get fresh settings and fresh scan all channels. An exception only if its firmware update from online.
I'm not sure. I'm not a specialist for this problems.
but within the BH image satellites.xml ,
i think there is no circular polarization on that transponder in satellites.xml.
But not sure Im using different satellites.xml
And you use circular polarization for that channel ??
Im use "User defined" settings for LNB on antenna for this satellite. As u can see package ntv plus required circular LNB. But signal so strong and with circular lnb working all channels on this satellite, include with Linear pol. if im right remember, for this satellite in country like France need antenna ~ 1.20-1.65
With my antenna and LNB it is impossible to test .
So I do not know what the cause of the problem is.
How i can help you? Maybe u need any info from this transponder like PIDs? I can give some technical info if it help. Also i can test fix if you try make it.
