Black Hole 3.0.7 Vu+ Ultimo4K
Maybe the coder has some idea.
And I do not know that.
The biggest problem is the impossibility of testing.
Hello,
when I go to Information I get the following data :
How can I update the DVB drivers and the kernel version to have the same as yours ? (20181130.r0 and 4.1.45)
I made an online update but no changes...
May be it's a plugin I should install ?
Also why my processor frequency is 1.5 Ghz while yours is 2.1 Ghz ?
Thanks.
Today i found other bug. Firmware 3.0.7 got small online update. And after this online update receiver didnt correct set time zone from satellite. Im use UTC +3:00 time zone, but receiver still used time zone +00:00. because time on receiver is 3 hours late, and EPG didnt working correct. Before this small online update all working fine. Please check it small bug. Thanks
Hello,
Thanks.
The later kernel and 2.1 Ghz processor is from the new Duo 4K not Ultimo 4K
Hello,
Thanks.
Did you tried a fresh (USB ) install?
Thanks for overhauled firmware, but I cannot receive any EPG!!!!!!!
Why?
I tried enabling EPG from setting menu but still no way.
In previous version (3.0.6) it was OK.
Thanks for the answer. I normally do not read very much under issues related to other boxes other than Ultimo 4k that I have.
I, instead, read every single posts, not only the one related to other boxes different from mines, but also related to topics I'm really not interested as a field of applications, like IPTV or Kodi, for instance. This because you'll never know what you can learn from each post, even there ;)
Hi
I update my Black Hole vu+ Solo from version 1.6.6 to 3.0.7 using USB. (just Power Off BH Solo then plugin USB rare port and plug the power On when the Green Led blinking remove the USB and press the power button but there is no TV Signal) Can you help me please? No Menu or VU+ Solo Logo? What happen?
This is the Ultimo 4K section and you have a Solo: don't post in the wrong section, even if the question might be generic.
It's also more useful to create a specific thread instead of using an already existing one, especially if your question is not related to it.
