Black Hole 3.0.8 Vu+ SoloSE / SoloSE V2
ok va bene
Ecco il log:
login as: root
root@vusolo2:~# dmesg
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ata1: SATA link down (SStatus 0 SControl 300)
__clk_enable: usb [1]
bcm40nm_pm_usb_enable 00
ehci-brcm ehci-brcm.0: Broadcom STB EHCI
ehci-brcm ehci-brcm.0: new USB bus registered, assigned bus number 1
ehci-brcm ehci-brcm.0: irq 69, io mem 0x10480300
ehci-brcm ehci-brcm.0: USB 0.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
ehci-brcm ehci-brcm.1: Broadcom STB EHCI
ehci-brcm ehci-brcm.1: new USB bus registered, assigned bus number 2
ehci-brcm ehci-brcm.1: irq 70, io mem 0x10480500
ehci-brcm ehci-brcm.1: USB 0.0 started, EHCI 1.00
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
ehci-brcm ehci-brcm.2: Broadcom STB EHCI
ehci-brcm ehci-brcm.2: new USB bus registered, assigned bus number 3
ehci-brcm ehci-brcm.2: irq 74, io mem 0x10490300
ehci-brcm ehci-brcm.2: USB 0.0 started, EHCI 1.00
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 1 port detected
ehci-brcm ehci-brcm.3: Broadcom STB EHCI
ehci-brcm ehci-brcm.3: new USB bus registered, assigned bus number 4
ehci-brcm ehci-brcm.3: irq 75, io mem 0x10490500
ehci-brcm ehci-brcm.3: USB 0.0 started, EHCI 1.00
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 1 port detected
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
ohci-brcm ohci-brcm.0: Broadcom STB OHCI
ohci-brcm ohci-brcm.0: new USB bus registered, assigned bus number 5
ohci-brcm ohci-brcm.0: irq 71, io mem 0x10480400
hub 5-0:1.0: USB hub found
hub 5-0:1.0: 1 port detected
ohci-brcm ohci-brcm.1: Broadcom STB OHCI
ohci-brcm ohci-brcm.1: new USB bus registered, assigned bus number 6
ohci-brcm ohci-brcm.1: irq 72, io mem 0x10480600
ata2: SATA link down (SStatus 0 SControl 300)
hub 6-0:1.0: USB hub found
hub 6-0:1.0: 1 port detected
ohci-brcm ohci-brcm.2: Broadcom STB OHCI
ohci-brcm ohci-brcm.2: new USB bus registered, assigned bus number 7
ohci-brcm ohci-brcm.2: irq 76, io mem 0x10490400
usb 2-1: new high-speed USB device number 2 using ehci-brcm
hub 7-0:1.0: USB hub found
hub 7-0:1.0: 1 port detected
ohci-brcm ohci-brcm.3: Broadcom STB OHCI
ohci-brcm ohci-brcm.3: new USB bus registered, assigned bus number 8
ohci-brcm ohci-brcm.3: irq 77, io mem 0x10490600
hub 8-0:1.0: USB hub found
hub 8-0:1.0: 1 port detected
usbcore: registered new interface driver usb-storage
mousedev: PS/2 mouse device common for all mice
i2c /dev entries driver
Success! Registering the characther device  success with 0
blackhole initialised
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
hidraw: raw HID events driver (C) Jiri Kosina
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
TCP: cubic registered
Key type dns_resolver registered
PM: CP0 COUNT/COMPARE frequency does not depend on divisor
EBI CS0: setting up NAND flash (primary)
NAND device: Manufacturer ID: 0xec, Chip ID: 0xda (Samsung NAND 256MiB 3,3V 8-bi       t)
NAND device: 256MiB, SLC, page size: 2048, OOB size: 64
brcmnand brcmnand.0: 256MiB total, 128KiB blocks, 2KiB pages, 16B OOB, 8-bit, Ha       mming ECC
Bad block table found at page 131008, version 0x01
Bad block table found at page 130944, version 0x01
nand_read_bbt: bad block at 0x0000067e0000
nand_read_bbt: bad block at 0x00000c440000
nand_read_bbt: bad block at 0x00000f7c0000
Creating 4 MTD partitions on "brcmnand.0":
0x000001f00000-0x000010000000 : "rootfs"
0x000001f00000-0x000010000000 : "rootfs(redundant)"
0x000000200000-0x000000900000 : "kernel"
0x000000900000-0x000000a00000 : "mac"
UBI: attaching mtd0 to ubi0
random: nonblocking pool is initialized
UBI: scanning is finished
UBI: attached mtd0 (name "rootfs", size 225 MiB) to ubi0
UBI: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
UBI: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
UBI: VID header offset: 2048 (aligned 2048), data offset: 4096
UBI: good PEBs: 1793, bad PEBs: 7, corrupted PEBs: 0
UBI: user volume: 1, internal volumes: 1, max. volumes count: 128
UBI: max/mean erase counter: 37/17, WL threshold: 4096, image sequence number: 9       80763936
UBI: available PEBs: 0, total reserved PEBs: 1793, PEBs reserved for bad PEB han       dling: 33
UBI: background thread "ubi_bgt0d" started, PID 53
ALSA device list:
  No soundcards found.
UBIFS: parse sync
UBIFS: background thread "ubifs_bgt0_0" started, PID 56
UBIFS: recovery needed
UBIFS: recovery completed
UBIFS: mounted UBI device 0, volume 0, name "rootfs"
UBIFS: LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/20       48 bytes
UBIFS: FS size: 221573120 bytes (211 MiB, 1745 LEBs), journal size 9023488 bytes        (8 MiB, 72 LEBs)
UBIFS: reserved for root: 0 bytes (0 KiB)
UBIFS: media format: w4/r0 (latest is w4/r0), UUID 44EF3FAE-12A0-4F7C-9FDF-D08DB       FD2E1B8, small LPT model
VFS: Mounted root (ubifs filesystem) on device 0:12.
devtmpfs: mounted
Freeing unused kernel memory: 192K (80760000 - 80790000)
udevd[101]: starting version 182
WARNING: You are using an experimental version of the media stack.
        As the driver is backported to an older kernel, it doesn't offer
        enough quality for its usage in production.
        Use it with care.
Latest git patches (needed if you report a bug to linux-media@vger.kernel.org):
        b72c2640f72c92d3f8dac9b3c6e5fa4fe0b73dcc tryfix em28xx
        3e6e48d66efaf3478472914018dd2109e8ee7d00 tryfix em28xx
        650494dfa1ab1afeec0216a7bc76b16130f098cd tryfix em28xx
UBI error: ubi_open_volume: cannot open device 0, volume 0, error -16
        Use it with care.
usb 2-1: dvb_usb_af9035: prechip_version=83 chip_version=02 chip_type=9135
usb 2-1: bh_dvb_usb_v2: found a 'Avermedia A835B(1835)' in cold state
usb 2-1: bh_dvb_usb_v2: downloading firmware from file 'dvb-usb-it9135-02.fw'
usb 2-1: dvb_usb_af9035: firmware version=3.39.1.0
usb 2-1: bh_dvb_usb_v2: found a 'Avermedia A835B(1835)' in warm state
usb 2-1: dvb_usb_af9035: [0] overriding tuner from 38 to 60
usb 2-1: bh_dvb_usb_v2: will pass the complete MPEG2 transport stream to the sof       tware demuxer
DVB: registering new adapter (Avermedia A835B(1835))
i2c i2c-0: af9033: firmware version: LINK=0.0.0.0 OFDM=3.9.1.0
usb 2-1: DVB: registering adapter 1 frontend 0 (Afatech AF9033 (DVB-T))...
usbcore: registered new interface driver dvb_usb_af9035
procmk_init
bcm_event: module license 'Proprietary' taints kernel.
Disabling lock debugging due to kernel taint
DVB: registering new adapter (_vuplus_solo2_)
bcm7356: hotplug_callback():
Hotplug - status.connected 1:0:0
Hotplug - connecting HDMI to display 0xe
[GP]:brcm_pwm_init
Hotplug - status.connected 1:1:2
brcm_demux_init: $Id: bcm_demux.c,v 0.7 $
[MPVR]: >> misc_pvr_init
[VID]: 6bcm7335_video_init
[AUD]: 6bcm7335_audio_init
BRCM brcm_dvb0: DVB: registering adapter 0 frontend 0 (BCM7346 FE)...
BKNI_P_GetTrackAllocEntry_resize: resizing from 5376->8704
BKNI_Malloc(linuxkernel) top users:
    blocks,   bytes, filename:line
      1024,  176128, portinginterface/hsm/src/common/bhsm.c:500
       601,  132308, BSEAV/lib/utils/balloc.c:31
       388,   24832, magnum/commonutils/mrc/src/bmrc_monitor.c:666
input: dreambox advanced remote control (native) as /devices/virtual/input/input       0
[LCD]: registered
0:0
[CI]: registered ci0
[CI]: CI interface initialised
[DFP]: registered dbox fp
[DFP]: Scart 9597 is found 4
[SC]: registered sci0
[SC]: registered sci1
system_time_set wakeup mode get
system_time_set wakeup mode get 0xc4
[VID]: VIDEO_SET_STREAMTYPE 0
[VID]: VIDEO_SELECT_SOURCE 1  0
[VID]: VIDEO_PLAY 1  2 0
[VID]: VIDEO_CONTINUE 1  1
[VID]: VIDEO_CLEAR_BUFFER 1  1 0
[VID]: VIDEO_STOP 0  1
[VID]: VIDEO_SELECT_SOURCE 0  0
__clk_enable: network [1]
__clk_enable: enet [1]
bcm40nm_pm_genet_enable 00
bcmgenet bcmgenet.0 eth0: link up, 100 Mbps, full duplex
NET: Registered protocol family 10
[LCD]: unknown cmd 0x1015
[AUD]: AUDIO_SET_MUTE 0
[AUD]: AUDIO_SET_MIXER -867123728
[AUD]: AUDIO_SET_MIXER : amixl 0, amixr 0
[AUD]: AUDIO_SET_MIXER : next left volume 0, right volume 0
[AUD]: AUDIO_SET_MIXER : next left volume -70, right volume -70
usb 2-1: USB disconnect, device number 2
bcmgenet bcmgenet.0 eth0: link down
usb 2-1: new high-speed USB device number 3 using ehci-brcm
i2c i2c-4: af9033: firmware version: LINK=0.0.0.0 OFDM=3.9.1.0
root@vusolo2:~#
Fai gli ls /dev/adapter...... che avevo scritto qualche post fa
root@vusolo2:~# ls /dev/dvb/adapter0        audio0     ca2        ca6        demux1     demux5     dvr0       dvr4       dvr8       net1       net5       video0    audio1     ca3        ca7        demux2     demux6     dvr1       dvr5       frontend0  net2       net6       video1    ca0        ca4        ca8        demux3     demux7     dvr2       dvr6       frontend1  net3       net7                 ca1        ca5        demux0     demux4     demux8     dvr3       dvr7       net0       net4       net8                 root@vusolo2:~#
Era questa ?
sfila il tuner, riavvia
rm -f /lib/modules/*/modules.*
depmod -a
reinfila il tuner e riavvia
ora dovrebbe andare
depmod: WARNING: could not open /lib/modules/3.13.5/modules.order: No such file or directory
depmod: WARNING: could not open /lib/modules/3.13.5/modules.builtin: No such file or directory
root@vusolo2:~#
Non va... :(
Mi pare lo stesso problema della mia HDTV usb-dvb-t che non mi va... (Vedi la mia risposta sull'altro post)
Fatalità di 10 penne che ho provato ieri tu hai proprio quella che non va...
Se il intanto hai altre un altro tuner da provare...
Se hai sottomano un "dmesg" di un box appena riavviato con la 3.0.7 e una penna già collegata e funzionate sarebbe cosa gradita per aiutarmi ad individuare il prpblema...
Neppure da teamviewer remoto da qualche amico?
Oppure ssh?
Tanto dovevo mettere la 3.0.7, almeno funziona con DVB-T :)
Ecco il log:
__clk_disable: enet [0]
bcm40nm_pm_genet_disable 00
__clk_disable: network [0]
NAND device: Manufacturer ID: 0xec, Chip ID: 0xda (Samsung NAND 256MiB 3,3V 8-bit)
brcmnand brcmnand.0: 256MiB total, 128KiB blocks, 2KiB pages, 16B OOB, 8-bit, Hamming ECC
UBI: max/mean erase counter: 39/19, WL threshold: 4096, image sequence number: 62281663
UBI: available PEBs: 0, total reserved PEBs: 1793, PEBs reserved for bad PEB handling: 33
ALSA device list:
UBIFS: parse sync
UBIFS: LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
UBIFS: media format: w4/r0 (latest is w4/r0), UUID 1604FD75-52DC-4914-A337-EE7128B687DE, small LPT model
devtmpfs: mounted
udevd[105]: starting version 182
        Use it with care.
        b2d1467ad0461049c0de8f82f514447b0b8f016b tryfix v4l2_ctrl_check duplicate symbol #2
        64955823cf3bd80743f1f3a5f7d50bd599d8affc tryfix v4l2_ctrl_check duplicate symbol - modify header
        e8812dab0d410e2694451a73b421df6fd82b3b07 Merge branch 'bh-master_20140924_bh_dvb_usb_v2' of git.blackhole-community.net:repos/bh/vuplus_kernel into bh-master_20140924_bh_dvb_usb_v2
        Use it with care.
usb 2-1: dvb_usb_af9035: firmware version=3.40.1.0
usb 2-1: dvb_usb_af9035: overriding tuner from 60 to 60
usb 2-1: bh_dvb_usb_v2: will pass the complete MPEG2 transport stream to the software demuxer
i2c i2c-0: af9033: firmware version: LINK=0.0.0.0 OFDM=3.40.1.0
i2c i2c-0: tuner_it913x: ITE Tech IT913X successfully attached
IR keymap rc-it913x-v2 not found
Registered IR keymap rc-empty
input: Avermedia A835B(1835) as /devices/platform/ehci-brcm.1/usb2/2-1/bh-rc/rc0/input0
rc0: Avermedia A835B(1835) as /devices/platform/ehci-brcm.1/usb2/2-1/bh-rc/rc0
usb 2-1: bh_dvb_usb_v2: schedule remote query interval to 500 msecs
usb 2-1: bh_dvb_usb_v2: 'Avermedia A835B(1835)' successfully initialized and connected
procmk_init
[GP]:brcm_pwm_init
input: dreambox advanced remote control (native) as /devices/virtual/input/input1
[LCD]: registered
0:0
BRCM brcm_dvb0: DVB: registering adapter 0 frontend 0 (Afatech AF9033 (DVB-T))...
[AUD]: AUDIO_SET_MIXER -856941072
root@vusolo2:~#
Ecco il log:
        Use it with care.
Grazie, ho qualche indizio su dove controllare.
fai una prova?
opkg install media-tree-module-it913x
e poi riavvia
ho appena provato sul vuuno4k e la penna simile alla tua che ho è tornata a funzionare.
appena riusciamo lanciamo una ri-compilazione dell'immagine... una live update e torna a funzionare.
Certo, pero devo fare la prova domani.
Non sono a casa, torno tardi e comunque ho rimesso su il backup con 3.0.7.
Devo riflashare con 3.0.9 e poi fare la prova.
nel mentre sta compilando un aggiornamento... dovrebbe essere sufficiente installare la 3.0.9, applica gli aggiornamenti e già dovrebbe andare.... in alternativa prova il comando del post precedente
Allora...
Inserito 3.0.9.C (vergine) sulla chiavetta USB.
Installazione -> Configurazione -> Aggiornamento immagine (50 pacchetti aggiornati) 3.0.9.I -> Riavvio -> Inserito tuner USB DVB-T -> Riavvio -> VISTO !!!!! (Tuner C: unknown frontend (DVB-T) )...
Che dire, grazie per l'aiuto e per la pazienza :)
