Black Hole 3.0.8 Vu+ Uno4K SE
Thank you very much!
As always, it works fine.
But the sound in the channel Festival 4K has not appeared.
I know that on another image there is sound support on this channel.
I do not want to use other images, because I am a big fan of this image.
I have 2 UNO4K and ZERO4K tuners and the sound does not work on both.
Tell me please, will this problem be solved?
Thanks for any reply.
is this Image a raw image and what ıs the difference between OpenBH 4.2 and Black Hole 3.0.8 Vu+ Uno4K SE. Thank you for answer
Good day. The mini tv does not work, by a long press on the blue button I choose to turn on the mini tv and there is no picture on the LCD as on the TV screen. Before that, version 3.0.5 was installed, everything works there. You can check? Thanks a lot in advance.
MiniTv works fine.
You have to enable PiP for it to work (not Quad PiP).
Thanks for the quick response, but when you turn on PiP, on mini TV when switching to other channels, nothing changes like on a TV, shows the same channel. In version 3.0.5, without switching on the PiP, but simply turning on the mini tv, when switching channels to mini tv, the picture also changes as on tv. Thanks again.
It has changed VU +
we can not change anything here.
Hello,
So i have vuuno4kse with bh 3.0.8B and MiniTv not working when i enable it but when i activate picture in picture MiniTv works????
Vu+ Uno4K SE trying to online update from Black Hole 3.0.8a to Black Hole 3.0.8c.
0 package updated.
What can i do to solve this ?
Best regards
